    MMA - Praytime
    10 Posts 3 Posters 2.2k Views 2 Watching
    • bheplerB Offline
      bhepler Module Developer @justjim1220
      @justjim1220 - It just sort of jumped out at me. Of course, now that I think about it, it’s entirely possible that the module needs quotes around those values. I don’t think so, based upon my quick glance at the source code. But I could be wrong. And I don’t have the time to install that module and try it out.
      But hey, @govabm can try it without quotes and then with quotes and let us know what works. The module readme really should provide a working example other than just listing the default of false.
      • justjim1220J Offline
        justjim1220 Module Developer @bhepler
        @bhepler
        My issue with it is not knowing why I would put just the first quotes and not finish it with quotes…
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
        • G Offline
          govabm @justjim1220
          @justjim1220 i installed complete Sm mirror again now its work i config now the moduls on the screen do you know all the position on the screen witch i can select ?
          • G Offline
            govabm
            ou no i have some mistakes
            i edit the possition on the screen know its show me i shoud config the file
            • G Offline
              govabm @govabm
              thats a working file know
              /* Magic Mirror Config Sample
               * MIT Licensed.
              var config = {
              	port: 8080,
              	language: "de",
              	timeFormat: 24,
              	units: "metric",
              		module:'MMM-PrayerTime',
              		position: 'bottom_left',
              			apiVersion: "1.0",
              			lat: 55.841727,
              			lon: 13.303381,
              			timezone: 'Europe/Berlin',
              			timeFormat: 24,
              			method: 2,
              			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
              			notDisplayed: ['midnight', 'sunset'],
              			useUpdateInterval: true,
              			updateInterval: 86400 * 1000,
              			animationSpeed: 2.5 * 1000,
              			language: "en",
              			showAdzanAlert: true,
              			alertTimer: 15000
              			module: 'MMM-RandomQuranAyah',
              			position: 'top_bar',
              			apiVersion: '1.0',
              			showArabic: true,
              			showTranslation: true,
              			surahArabicName:false,
              			translationLang:'de.Aburida',
              			updateInterval: 3600 * 100,
              			module: "alert",
              			module: "updatenotification",
              			position: "top_bar"
              			module: "clock",
              			position: "top_right"
              			header: "Ferien Deutschland",
              						symbol: "calendar-check-o ",
              			module: "compliments",
              			position: "bottom_bar"
              			module: "currentweather",
              				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
              			module: "weatherforecast",
              			header: "Weather Forecast",
              				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
              			module: "newsfeed",
              			position: "bottom_bar",
              				feeds: [
              						title: "New York Times",
              				showSourceTitle: true,
              				showPublishDate: true
