    MMA - Praytime
    10 Posts 3 Posters 2.1k Views 2 Watching
    • G Offline
      govabm
      Hello ,
      I have a Problem with the config file Can someone Help me
      Thats my config file
      this is my config file
      /*************** DO NOT EDIT THE LINE BELOW **************/
      if (typeof module !== “undefined”) {module.exports = config;}
      / Magic Mirror Config Sample
      By Michael Teeuw http://michaelteeuw.nl
      MIT Licensed.
      For more information how you can configurate this file
      See https://github.com/MichMich/MagicMirror#configuration
      var config = {
      // - “”, “0.0.0.0”, “::” to listen on any interface
      // Default, when address config is left out, is “localhost”
      port: 8080,
      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
      language: “de”,
      timeFormat: 24,
      units: “metric”,
      module: ‘MMM-PrayerTime’,
      position: ‘bottom_right’, .
      apiVersion: ‘1.0’,
      lat: 31.972836,
      lon: 35.898916,
      timezone: ‘Asia/Dubai’, // please refer to http://php.net/manual/en/timezones.asia.php
      timeFormat: 12,
      method: 5,
      playAdzan: [‘fajr’, ‘dhuhr’, ‘asr’, ‘maghrib’, ‘isha’],
      notDisplayed: [‘midnight’, ‘sunset’],
      useUpdateInterval: true,
      updateInterval: 86400 * 1000, // How often do you want to fetch new praying time? (milliseconds)
      animationSpeed: 2.5 * 1000, // Speed of the update animation. (milliseconds)
      language: config.language | ‘en’,
      showAdzanAlert: true,
      alertTimer: 15000
      module: “alert”,
      	module: "updatenotification",
      	position: "top_bar"
      	module: "clock",
      	position: "top_left"
      	header: "Ferien NRW",
      				symbol: "calendar-check-o ",
      	module: "compliments",
      	position: "lower_third"
      	module: "currentweather",
      		locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
      	module: "weatherforecast",
      	header: "Weather Forecast",
      		locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
      	module: "newsfeed",
      	position: "bottom_bar",
      		feeds: [
      				title: "New York Times",
      		showSourceTitle: true,
      		showPublishDate: true
      justjim1220J 2 Replies Last reply Reply Quote 0
      • justjim1220J Offline
        justjim1220 Module Developer @govabm
        @govabm
        there where a few syntax errors,
        But the biggest issues I am finding is your quotes and double quotes…
        this is what is showing for in the cofig I copied from your config…
        ‘bottom_right’
        “alert”
        this is what it should look like…
        ‘bottom_right’
        “alert”
        you can see there is a difference by the slant of the quotes…
        Hope this helps!
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
          @govabm
          Made a few modifications…
          Will leave the quotes to you to fix!
          /* Magic Mirror config.js
           * MIT Licensed.
          var config = {
              address: "localhost",
              port: 8080,
                  // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"]
              language: “de”,
              timeFormat: 24,
              units: “metric”,
                  apiVersion: ‘1.0’,
                  lat: 31.972836,
                  lon: 35.898916,
                  timeFormat: 12,
                  method: 5,
                  alertTimer: 15000
              module: “alert”
              position: "top_bar"
              module: "clock",
              module: "newsfeed",
                  feeds: [
          Jim Hallock - 1995
          • bheplerB Offline
            bhepler Module Developer @justjim1220
            @govabm - Take @justjim1220 example of a fixed config.js and remove the " from in front of the lat: value. The values being passed are real numbers and not strings. So they do not need quotes around them.
            Additionally, you specify both German and English as your language. You should probably pick one and stick with it.
              justjim1220 Module Developer @bhepler
              @bhepler
              Thanks for the catch!
              didn’t even noticed That I had put that there!!!
              Jim Hallock - 1995
              • bheplerB Offline
                @justjim1220 - It just sort of jumped out at me. Of course, now that I think about it, it’s entirely possible that the module needs quotes around those values. I don’t think so, based upon my quick glance at the source code. But I could be wrong. And I don’t have the time to install that module and try it out.
                But hey, @govabm can try it without quotes and then with quotes and let us know what works. The module readme really should provide a working example other than just listing the default of false.
                  @bhepler
                  My issue with it is not knowing why I would put just the first quotes and not finish it with quotes…
                  Jim Hallock - 1995
                  • G Offline
                    govabm @justjim1220
                    @justjim1220 i installed complete Sm mirror again now its work i config now the moduls on the screen do you know all the position on the screen witch i can select ?
                    • G Offline
                      govabm
                      ou no i have some mistakes
                      i edit the possition on the screen know its show me i shoud config the file
                      • G Offline
                        govabm @govabm
                        thats a working file know
                        /* Magic Mirror Config Sample
                         * MIT Licensed.
                        var config = {
                        	port: 8080,
                        	language: "de",
                        	timeFormat: 24,
                        	units: "metric",
                        		module:'MMM-PrayerTime',
                        		position: 'bottom_left',
                        			apiVersion: "1.0",
                        			lat: 55.841727,
                        			lon: 13.303381,
                        			timezone: 'Europe/Berlin',
                        			timeFormat: 24,
                        			method: 2,
                        			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
                        			notDisplayed: ['midnight', 'sunset'],
                        			language: "en",
                        			alertTimer: 15000
                        			module: 'MMM-RandomQuranAyah',
                        			position: 'top_bar',
                        			apiVersion: '1.0',
                        			showArabic: true,
                        			showTranslation: true,
                        			surahArabicName:false,
                        			translationLang:'de.Aburida',
                        			updateInterval: 3600 * 100,
                        			module: "alert",
                        			position: "top_bar"
                        			module: "clock",
                        			position: "top_right"
                        			header: "Ferien Deutschland",
                        			module: "newsfeed",
                        				feeds: [
