MMA - Praytime
10 Posts 3 Posters 1.6k Views 2 Watching
  • G Offline
    govabm
    Hello ,
    I have a Problem with the config file Can someone Help me
    Thats my config file
    this is my config file
    /*************** DO NOT EDIT THE LINE BELOW **************/
    if (typeof module !== “undefined”) {module.exports = config;}
    / Magic Mirror Config Sample
    By Michael Teeuw http://michaelteeuw.nl
    MIT Licensed.
    For more information how you can configurate this file
    See https://github.com/MichMich/MagicMirror#configuration
    var config = {
    // - “”, “0.0.0.0”, “::” to listen on any interface
    // Default, when address config is left out, is “localhost”
    port: 8080,
    ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
    // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
    // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
    language: “de”,
    timeFormat: 24,
    units: “metric”,
    module: ‘MMM-PrayerTime’,
    position: ‘bottom_right’, .
    apiVersion: ‘1.0’,
    lat: 31.972836,
    lon: 35.898916,
    timezone: ‘Asia/Dubai’, // please refer to http://php.net/manual/en/timezones.asia.php
    timeFormat: 12,
    method: 5,
    playAdzan: [‘fajr’, ‘dhuhr’, ‘asr’, ‘maghrib’, ‘isha’],
    notDisplayed: [‘midnight’, ‘sunset’],
    useUpdateInterval: true,
    updateInterval: 86400 * 1000, // How often do you want to fetch new praying time? (milliseconds)
    animationSpeed: 2.5 * 1000, // Speed of the update animation. (milliseconds)
    language: config.language | ‘en’,
    showAdzanAlert: true,
    alertTimer: 15000
    module: “alert”,
    	module: "updatenotification",
    	position: "top_bar"
    	module: "clock",
    	position: "top_left"
    	header: "Ferien NRW",
    				symbol: "calendar-check-o ",
    	module: "compliments",
    	position: "lower_third"
    	module: "currentweather",
    		locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
    	module: "weatherforecast",
    	header: "Weather Forecast",
    		locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
    	module: "newsfeed",
    	position: "bottom_bar",
    		feeds: [
    				title: "New York Times",
    		showSourceTitle: true,
    		showPublishDate: true
    J 2 Replies Last reply Aug 2, 2018, 12:43 AM Reply Quote 0
      justjim1220 Module Developer @govabm
      @govabm
      there where a few syntax errors,
      But the biggest issues I am finding is your quotes and double quotes…
      this is what is showing for in the cofig I copied from your config…
      ‘bottom_right’
      “alert”
      this is what it should look like…
      ‘bottom_right’
      “alert”
      you can see there is a difference by the slant of the quotes…
      Hope this helps!
      "Life's Too Short To Dance With Ugly People"
      Jim Hallock - 1995
      G 1 Reply Last reply Aug 5, 2018, 7:14 PM Reply Quote 0
        @govabm
        Made a few modifications…
        Will leave the quotes to you to fix!
        /* Magic Mirror config.js
         * MIT Licensed.
        var config = {
            address: "localhost",
            port: 8080,
                // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"]
            language: “de”,
            timeFormat: 24,
            units: “metric”,
                apiVersion: ‘1.0’,
                lat: 31.972836,
                lon: 35.898916,
                timeFormat: 12,
                method: 5,
                alertTimer: 15000
            module: “alert”
            position: "top_bar"
            module: "clock",
            module: "newsfeed",
                feeds: [
        Jim Hallock - 1995
        B 1 Reply Last reply Aug 2, 2018, 1:06 AM Reply Quote 0
          bhepler Module Developer @justjim1220
          @govabm - Take @justjim1220 example of a fixed config.js and remove the " from in front of the lat: value. The values being passed are real numbers and not strings. So they do not need quotes around them.
          Additionally, you specify both German and English as your language. You should probably pick one and stick with it.
          J 1 Reply Last reply Aug 2, 2018, 1:32 AM Reply Quote 0
            justjim1220 Module Developer @bhepler
            @bhepler
            Thanks for the catch!
            didn’t even noticed That I had put that there!!!
            Jim Hallock - 1995
            B 1 Reply Last reply Aug 2, 2018, 1:37 AM Reply Quote 0
              @justjim1220 - It just sort of jumped out at me. Of course, now that I think about it, it’s entirely possible that the module needs quotes around those values. I don’t think so, based upon my quick glance at the source code. But I could be wrong. And I don’t have the time to install that module and try it out.
              But hey, @govabm can try it without quotes and then with quotes and let us know what works. The module readme really should provide a working example other than just listing the default of false.
              J 1 Reply Last reply Aug 2, 2018, 1:40 AM Reply Quote 0
                @bhepler
                My issue with it is not knowing why I would put just the first quotes and not finish it with quotes…
                Jim Hallock - 1995
                • G Offline
                  govabm @justjim1220
                  @justjim1220 i installed complete Sm mirror again now its work i config now the moduls on the screen do you know all the position on the screen witch i can select ?
                  • G Offline
                    govabm
                    ou no i have some mistakes
                    i edit the possition on the screen know its show me i shoud config the file
                    G 1 Reply Last reply Aug 5, 2018, 8:11 PM Reply Quote 0
                    • G Offline
                      govabm @govabm
                      thats a working file know
                      /* Magic Mirror Config Sample
                       * MIT Licensed.
                      var config = {
                      	port: 8080,
                      	language: "de",
                      	timeFormat: 24,
                      	units: "metric",
                      		module:'MMM-PrayerTime',
                      		position: 'bottom_left',
                      			apiVersion: "1.0",
                      			lat: 55.841727,
                      			lon: 13.303381,
                      			timezone: 'Europe/Berlin',
                      			timeFormat: 24,
                      			method: 2,
                      			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
                      			notDisplayed: ['midnight', 'sunset'],
                      			language: "en",
                      			alertTimer: 15000
                      			module: 'MMM-RandomQuranAyah',
                      			position: 'top_bar',
                      			apiVersion: '1.0',
                      			showArabic: true,
                      			showTranslation: true,
                      			surahArabicName:false,
                      			translationLang:'de.Aburida',
                      			updateInterval: 3600 * 100,
                      			module: "alert",
                      			position: "top_bar"
                      			module: "clock",
                      			position: "top_right"
                      			header: "Ferien Deutschland",
                      			module: "newsfeed",
                      				feeds: [
