How to Troubleshoot
you can test your software in a browser using the webserver:
http://mirror_ip_adress:8080install in firefox a tool called
Firebughttps://addons.mozilla.org/de/firefox/addon/firebug/
it will show you errors on the fly.
Changes in node_helper.js requires a restart of your mirror software. -
Is there a way to see the log via a module?
One command that has been a lifesaver for me when I’ve munged up the config.js is: “npm run config:check”. The key is to be in the MagicMirror directory when you run it. It’ll check out your config.js and is much more convenient than pasting into jslint.com.
For example here is one instance when I had multiple issues and even left the letter “v” at the bottom of my config.js file (on line 255). I would have never found that…The symptom was some modules would load and other would just say “loading” perpetually.
pi@raspberrypi:~/MagicMirror $ npm run config:check
magicmirror@2.1.3 config:check /home/pi/MagicMirror
node tests/configs/check_config.jsChecking file… /home/pi/MagicMirror/config/config.js
Line 201 col 24 Duplicate key ‘classes’.
Line 223 col 20 Duplicate key ‘classes’.
Line 255 col 1 Expected an assignment or function call and instead saw an expression.
Line 255 col 2 Missing semicolon. -
@Lexingtonian Thank you for that tip with
npm run config:check. Should be in the dev docs… -
While trying to debug modules, I’ve been given quite mixed feedback regarding what to use to print messages to console, on either local system or in remote browser DevTools.
So far, I have found the only reliable way that always seem to print something in the browser, is using
console.error(). The others have varied. I’m on MMv2.2.2 (master). -
I was pulling my hair out trying to figure out why my modules weren’t loading. The npm run config:check tip is a total lifesaver - found a missing comma in two seconds.
@BiaGen the latest 2 releases run config check as part of startup, and fail if there is an error like that
I always recommend using manual start whenever changing config, for this very purpose
Stop pm2 mgmt if managing the app
Then
cd ~/MagicMirror
npm startIf any problems they are right there
Once good, ctrl-q MagicMirror
And then use pm2 to launch
