    Help choosing more than one item from an array
    18 Posts 4 Posters 8.5k Views 4 Watching
    • Mykle1M
      I have this array in my MMM-EOL module
      lifeFormArray: {
                  "Tigers": "328674",
                  "Hummingbirds": "8021",
                  "Lions": "328672",
                  "Jaguar": "328606",
                  "Leopard": "328673",
                  "Cheetah": "328680",
                  "Fox": "19076",
                  "Deaths-head Moth": "50688",
                  "Great White Shark": "213726",
                  "Seals": "7666",
                  "Mosquitos": "473",
                  "Venus Flytrap": "71355",
                  "Cardinals": "19590",
                  "Humpback Whale": "328575",
                  "Praying Mantis": "487055",
                  "Dragonfly": "42274802",
                  "Tarantulas": "170",
                  "Bats": "7631",
                  "Bears": "7631",
                  "Cicadas": "2645413",
                  "Striped Bass": "211032",
                  "Alligators": "796029",
                  "Crocodiles": "1739",
                  "Snakes": "2815988",
                  "Cats": "7674",
                  "Birds": "695",
                  "Eagles": "8016",
                  "Bald Eagle": "1049121",
                  "Cactus": "4228",
                  "Anemones and Corals": "1746",
                  "Crabs, Lobsters, and Shrimps": "1183",
                  "Sequoia": "42665",
                  "Sea Horse": "218966",
      	    "Hominidae": "1653",
      	    "Primates": "1645",
                  "Otters": "328044",
      In the config option you would enter, for instance:
      lifeForm: "Cats",
      This enters the id number for “Cats” (from the array) into the url like this:
      + this.config.lifeFormArray[this.config.lifeForm] +
      How can I modify this so that I can enter more than one lifeForm in the config, for instance, lifeForm: "Cats,Bats,Bears", so that the module enters the three id numbers from the array into the url, comma seperated with no spaces? I hope I have explained myself clearly. The url does work manually in a browser when using several id numbers, comma seperated, no spaces. I just don’t know how to call more than one item from the array.
      Many thanks ahead of time.
      strawberry 3.141S 1 Reply Last reply
      Reply Quote 1
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @Mykle1
        @mykle1 what you describe above is actually not an array, it’s an object (hash). Arrays are always defined with [] not {}.
        Now to your problem. you can create an array from your config value and save it in a variable e.g. var lifeForms = this.config.lifeForm.split(',');. it would look like this ['Cats', 'Bats', 'Bears']. Then you can loop over it to get the ids and save it into another variable
        var lifeFormIds =[];
        for (let lifeForm of lifeForms) {
          if (this.config.lifeFormArray[lifeForm]) {
            lifeFormIds.push(this.config.lifeFormArray[lifeForm]);
        To create the id list you just join it comma seoerated like lifeFormIds.join(',');
        justjim1220J Mykle1M 5 Replies Last reply
        Reply Quote 1
        • justjim1220J
          justjim1220 Module Developer @strawberry 3.141
          @strawberry-3-141
          just to be sure you understand…
          He’s not looking for it to show all the lifeforms at the same time, but different ones in intervals set by the user.
          Like with Cats, Bats, Bears… Say at an hourly interval show each one individually.
          I’m looking at this as well, I brought up the idea with @Mykle1. I see what you are getting at, and I’ve been looking at the same thing, just not sure how to call them up individually at intervals…
          “Life’s Too Short To Dance With Ugly People”
          Jim Hallock - 1995
          • justjim1220J
            @strawberry-3-141
            Oh, and I think it needs to be placed without spaces…
            [“Cats”,“Bats”,“Bears”]
            Not sure if that makes a difference with what you are pointing out, but I think it does.
            Jim Hallock - 1995
            • justjim1220J
              @strawberry-3-141
              This Is what I’ve been working on so far…
              getLiforms: function () {
              		var url = "http://eol.org/api/pages/1.0.json?batch=false&id=";
              		var requestUrls = [];
              		var LifeformsArray = this.config.Lifeforms.split(",");
              		LifeformssArray.forEach(function(lifeform) {
              			var requestUrl = url + lifeform;
              			requestUrls.push(requestUrl);
              Am I even close to the right track???
              Jim Hallock - 1995
              • justjim1220J
                @strawberry-3-141
                Yours looks better!
                :smiling_face_with_sunglasses:
                Jim Hallock - 1995
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @justjim1220
                  @justjim1220 It looks like you are trying to do multiple request, as mykles description sounds like one request with a comma seperated list.
                  justjim1220J Mykle1M 2 Replies Last reply
                  Reply Quote 1
                  • justjim1220J
                    @strawberry-3-141
                    Yeah, I got that while trying to write what I had going. Your example looks more correct.
                    So, now I’m looking at your example but not exactly sure where to insert it into the code to get it to work.
                    in the config.js, I am looking at the lifeforms array as such:
                    lifeForms: "Striped Bass,Praying Mantis,Tigers,Hummingbirds,Venus Flytrap,Fox,Bald Eagle",
                    then I added this to the defaults in the MMM-EOL.js:
                    lifeForms: ["", "", ""],
                    then I added your example to the start function:
                            var lifeFormIds = this.config.lifeForms.split(',');
                            //  Set locale.
                            this.url = "http://eol.org/api/pages/1.0.json?batch=false&id=" + this.config.lifeFormIds.join(',') +
                    I know this is definitely NOT right. This is where I am getting confused…
                    Having 2 separate < var lifeFormIds > declared doesn’t look right.
                    And, placing the ‘join’ part after the URL doesn’t look right either…
                    Jim Hallock - 1995
                      sdetweil
                      ok, your source ‘lifeFormArray’ is a hash… good for looking up randomly
                      now to get the user specified list into something usable, split is the way as already posted
                      // if user specified something
                      if(this.config.lifeForms.length >0 )
                           // split will return an array with only one entry if no comma found
                           this.config.user_keys=this.config.lifeForms.split(',');
                      else
                           // add an entry to a special lifeFormArray entry for missing config info
                           this.config.user_keys.push("none");
                      now, you want random, or walk the array of user_keys?
                      function getRandomInt(max) {
                        return Math.floor(Math.random() * Math.floor(max));
                      // get one of the user specified data keys, using random
                      var key=this.config.user_keys[this.getRandomInt(this.config.user_keys.length)];
                      // append that id value to the url.
                      this.url = "http://eol.org/api/pages/1.0.json?batch=false&id=" +this.lifeFormArray.key;
                      its unclear if u wanted all or just one…
                      justjim1220J 1 Reply Last reply
                      Reply Quote 1
                      • justjim1220J
                        justjim1220 Module Developer @sdetweil
                        Random would be great!
                        I’ll give it a try, Thanks!
                        Jim Hallock - 1995
                          sdetweil @justjim1220
                          @justjim1220 make sure to add an entry to the lifeFormArray that matches the string you define for ‘none’ (no user entry supplied)
                          justjim1220J 2 Replies Last reply
                          Reply Quote 1
                          • justjim1220J
                            So, would the entry be like this: “Cats”, “Bats”, “Bears”,
                            or like This: “Cats,Bats,Bears”,
                            Jim Hallock - 1995
                            • justjim1220J
                              Well, at the moment it is throwing the following error:
                              I’ll look at it some more here in a little bit…
                              Thanks for your input!
                              Jim Hallock - 1995
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @strawberry 3.141
                                @strawberry-3-141
                                I am extremely grateful to both of you for your assistance and guidance. I thank you both. :thumbsup:
                                @justjim1220
                                Jim, as it seems you’ve taken over this topic, I will leave it to you.
                                • justjim1220J
                                  justjim1220 Module Developer @Mykle1
                                  @mykle1
                                  I don’t know about taking it over, LOL.
                                  Just trying to help!
                                  Jim Hallock - 1995
                                  • Mykle1M
                                    @strawberry-3-141 said in Help choosing more than one item from an array:
                                    Object. Array. What’s the difference? (That’s a joke. Laugh) :-D
                                      @justjim1220 that error looks like from the constructed url failing
                                        @justjim1220 the second. Don’t depend on users to do multiple entries
