    Updating problem: "commit your changes or stash them before you can merge" ???
    6 Posts 4 Posters 9.4k Views 5 Watching
    • A
      amanzimdwini
      SHOULD have been easy (and yes, I am patched / updated / upgraded / have node v10 etc)
      pi@bathMM2:~/MagicMirror $ sudo git pull && npm install
      error: Your local changes to the following files would be overwritten by merge:
              .gitignore
              CHANGELOG.md
              Gruntfile.js
              README.md
              js/main.js
              js/module.js
              modules/default/alert/alert.js
              modules/default/calendar/README.md
              modules/default/calendar/calendar.js
              modules/default/calendar/calendarfetcher.js
              modules/default/compliments/README.md
              modules/default/compliments/compliments.js
              modules/default/currentweather/currentweather.js
              modules/default/newsfeed/README.md
              modules/default/newsfeed/fetcher.js
              modules/default/newsfeed/newsfeed.js
              modules/default/newsfeed/node_helper.js
              modules/default/weatherforecast/README.md
              modules/default/weatherforecast/weatherforecast.js
              package-lock.json
              package.json
              translations/de.json
              translations/en.json
              translations/it.json
              translations/nl.json
              translations/translations.js
              vendor/package-lock.json
      Please, commit your changes or stash them before you can merge.
      error: The following untracked working tree files would be overwritten by merge:
              translations/pt-br.json
              translations/zh-cn.json
              translations/zh-tw.json
      Please move or remove them before you can merge.
      Aborting
      Interesting - but (a) what does it mean and (b) how do I proceed?
      Thanks,
      Karl
      • eniacE
        eniac
        Same Problem here, but only css/main.css is effected.
        What can we do ?
        justjim1220J 1 Reply Last reply Reply Quote 0
        • justjim1220J
          justjim1220 Module Developer @eniac
          @amanzimdwini @eniac
          rename or delete them and try again
          rename to save the changes you made
          You can also rename the folder by adding _bak
          or you can move those files out of their directories, like create a separate directory that has a different name than any other folder in MagicMirror.
          “Life’s Too Short To Dance With Ugly People”
          Jim Hallock - 1995
          • Y
            yep_DD
            git stash //stash your changes and save them
            git pull //update to current version
            git stash pop //merge your stash back
            justjim1220J 1 Reply Last reply Reply Quote 4
            • justjim1220J
              justjim1220 Module Developer @yep_DD
              @yep_dd
              Thanks! Wish I knew this before. Seems a lot easier than what I’ve been doing!!! :smirking_face:
              Jim Hallock - 1995
              • eniacE
                eniac
                Thanks … Work for me :-)
