    MM Update - GIT error
    17 Posts 4 Posters 8.7k Views 3 Watching
    • P Offline
      Pakmann
      Hey guys,
      i want to update my MM system from version 2.1.3 -> 2.4.x.
      It looks like i am to stupid for it -.-
      I am in the MagicMirror folder an try to make an GIT pull. I received an error immediatly.
      May you have an idea for this issue ?
      sudo git pull && npm install
      error: object file .git/objects/5d/fba0b834306cc81693307ab0d1bf24e798a46a is empty
      fatal: loose object 5dfba0b834306cc81693307ab0d1bf24e798a46a (stored in .git/objects/5d/fba0b834306cc81693307ab0d1bf24e798a46a) is co                    rrupt
      fatal: The remote end hung up unexpectedly
        AxLed Module Developer
        @Pakmann
        2 ideas:
        • in which folder are you trying to run the pull? It should be /MagicMirror/
        • do it without sudo rights
        AxLED
        • P Offline
          Pakmann
          @AxLed
          strange behaviour… i am in my root folder for MagicMirror: /home/pi/MagicMirror/
          without sudo command same result
          justjim1220J 1 Reply Last reply Reply Quote 0
          • justjim1220J Offline
            justjim1220 Module Developer @Pakmann
            @pakmann
            delete the file giving he error…
            “Life’s Too Short To Dance With Ugly People”
            Jim Hallock - 1995
            • P Offline
              Pakmann
              @justjim1220
              thanks a lot! This works, but now the next issue -.-
              error: refs/remotes/origin/develop does not point to a valid object!
              remote: Enumerating objects: 507, done.
              remote: Counting objects: 100% (507/507), done.
              error: object file .git/objects/36/766f9a0089766d4a0e164f3f0b198dadcf60c4 is empty
              fatal: SHA1 KOLLISION MIT 36766f9a0089766d4a0e164f3f0b198dadcf60c4 GEFUNDEN !
              fatal: index-pack fehlgeschlagen
                @pakmann
                try…
                npm rebuild
                from the MagicMirror directory
                then reboot your system
                Jim Hallock - 1995
                • P Offline
                  Pakmann @justjim1220
                  @justjim1220 said in MM Update - GIT error:
                  @pakmann
                  try…
                  npm rebuild
                  rebuild was sucessfull, but not working. Problem still alive
                    @pakmann
                    delete the file causing new error…
                    Then rebuild again…
                    npm rebuild
                    then reboot again
                    if this doesn’t work, you may need to do the git pull && npm install again
                    Jim Hallock - 1995
                    • P Offline
                      • detele file: check
                      • npm rebuild: check
                      • reboot: check
                      • new request for git pull && npm install: same behaviour…
                      remote: Total 1591 (delta 507), reused 507 (delta 507), pack-reused 1084
                      Empfange Objekte: 100% (1591/1591), 691.80 KiB | 463.00 KiB/s, Fertig.
                      error: object file .git/objects/df/fc042df5d96cc8f7a956c12a2e002004d4cf7d is empty
                      fatal: SHA1 KOLLISION MIT dffc042df5d96cc8f7a956c12a2e002004d4cf7d GEFUNDEN !
                      justjim1220J 2 Replies Last reply Reply Quote 0
                        @pakmann
                        Well, I am not sure what is happening…
                        My best guess is to delete the .git folder then redo the git pull && npm install
                        Jim Hallock - 1995
                          @pakmann
                          OR…
                          Rename your MagicMirror folder to MM-BAK
                          then git clone MagicMirror for a fresh install
                          Then move your modules folder, config.js, and custom.css files over to the fresh install
                          might also need to move the package.json and package-lock.json files from the bak to the fresh install
                          And, anytime I have dealt with anything like this, I always have to rebuild, or reboot, or both
                          Jim Hallock - 1995
                            mochman Module Developer
                            Maybe this was the issue.
                            https://www.geekwire.com/2018/github-recovering-widespread-outage-caused-networking-database-issues/
                            justjim1220J 1 Reply Last reply Reply Quote 1
                              justjim1220 Module Developer @mochman
                              @mochman
                              Yeah, it’s possible if the update was retrieved during that time.
                              Jim Hallock - 1995
                              • P Offline
                                Pakmann
                                @justjim1220
                                so i did it. After that i try to make the npm install. Suprise… the next issues. What a hard MM update! Maybe you have any idea ?
                                Bereits aktuell.
                                (node:1893) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                                npm ERR! Error: Method Not Allowed
                                npm ERR!     at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
                                npm ERR!     at /usr/share/npm/lib/cache/add-named.js:203:12
                                npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
                                npm ERR!     at FSReqWrap.oncomplete (fs.js:135:15)
                                npm ERR! If you need help, you may report this *entire* log,
                                npm ERR! including the npm and node versions, at:
                                npm ERR!     <http://github.com/npm/npm/issues>
                                npm ERR! System Linux 4.14.71-v7+
                                npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install"
                                npm ERR! cwd /home/pi/MagicMirror
                                npm ERR! node -v v8.11.1
                                npm ERR! npm -v 1.4.21
                                npm ERR! code E405
                                npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
                                > phantomjs-prebuilt@2.1.16 install /home/pi/MagicMirror/node_modules/jshint/node_modules/phantomjs-prebuilt
                                > node install.js
                                PhantomJS not found on PATH
                                Unexpected platform or architecture: linux/arm
                                It seems there is no binary available for your platform/architecture
                                Try to install PhantomJS globally
                                npm WARN This failure might be due to the use of legacy binary "node"
                                npm WARN For further explanations, please read
                                /usr/share/doc/nodejs/README.Debian
                                > electron-chromedriver@1.6.0 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
                                > node ./download-chromedriver.js
                                npm WARN optional dep failed, continuing phantomjs-prebuilt@2.1.16
                                npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                                npm WARN deprecated browserslist@2.11.3: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
                                npm ERR!
                                npm ERR! not ok code 0
                                  @pakmann
                                  GEEZ!!!
                                  I literally just installed a fresh MagicMirror to an Ubuntu OS, and had zero issues.
                                  I did a manual install of Browserlist…
                                  npm install Browserlist@3.0 -g
                                  then I also did a manual install of PhantomJS…
                                  sudo npm insall PhantomJS@latest -g
                                  Then I made sure I had updated versions of npm, node, and electron
                                  npm install npm@latest -g
                                  npm install node@ latest -g
                                  sudo npm electron@latest -g
                                  Jim Hallock - 1995
                                    @pakmann
                                    I’m not using pi, so I don’t really know if this will help or not… could be different
                                    Jim Hallock - 1995
                                    • P Offline
                                      Pakmann
                                      hmm… it looks like my system is broken. npm makes a lot of problems too.
                                      I decide to reset the systems completely. Fresh OS and a new MM installation. It was easier as to find the root cause. Now everythink is running up again.
                                      Thanks a lot for your ideas and your help
