PM2 error
13 Posts 6 Posters 5.7k Views 5 Watching
    dawookie1979
    I get this error when trying to run pm2 startup
    pi@MagicMirror:~ $ pm2 startup
    /usr/lib/node_modules/pm2/bin/pm2:6
    if (semver.satisfies(process.versions.node, ‘>= 6.0.0’))
    TypeError: semver.satisfies is not a function
    at Object. (/usr/lib/node_modules/pm2/bin/pm2:6:12)
    at Module._compile (internal/modules/cjs/loader.js:654:30)
    at Object.Module._extensions…js (internal/modules/cjs/loader.js:665:10)
    at Module.load (internal/modules/cjs/loader.js:566:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
    at Function.Module._load (internal/modules/cjs/loader.js:498:3)
    at Function.Module.runMain (internal/modules/cjs/loader.js:695:10)
    at startup (internal/bootstrap/node.js:201:19)
    at bootstrapNodeJSCore (internal/bootstrap/node.js:516:3)
    Please help a novice
    B 1 Reply Last reply Nov 28, 2018, 4:19 AM Reply Quote 0
      Status Board
      I have the exact same issue. Have you found a fix for this?
      • L Offline
        lavolp3 Module Developer
        Have you tried reinstalling pm2 or installing the latest version?
        sudo npm install pm2@latest -g
        I can’t find the line mentioned in the file /usr/lib/node_modules/pm2.
        So better reinstall I guess…
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        S 1 Reply Last reply Oct 31, 2018, 4:05 PM Reply Quote 0
          Status Board @lavolp3
          @lavolp3 I have not, right now my workaround is not using pm2 at all and just starting Magic Mirror with DISPLAY=:0 npm start
          D 1 Reply Last reply Nov 18, 2018, 9:21 PM Reply Quote 0
            dawookie1979
            tried re-installing, same issue
              dawookie1979 @Status Board
              @status-board how do I do this
              L 1 Reply Last reply Nov 19, 2018, 9:22 AM Reply Quote 0
              • L Offline
                lavolp3 Module Developer @dawookie1979
                @dawookie1979 @Status-Board
                can you please explain again how (the command) and from which folder you have installed pm2?
                And what is your system running?
                  dawookie1979
                  i have tried installing pm2 using sudo npm install pm2@latest -g command, either to the root directory or within magic mirror directory.
                  i am running raspberry pi3 Magic Mirror 2.5
                    bhepler Module Developer @dawookie1979
                    @dawookie1979 - At a guess, it looks like pm2 is not compatible with the version of node that you have on your pi. I would try upgrading node then re-running the pm2 startup command.
                      dawookie1979
                      thanks, i will try that. Can you give me the command / commands to run this node update.
                      M 1 Reply Last reply Nov 29, 2018, 1:51 AM Reply Quote 0
