    PM2 error
    13 Posts 6 Posters 6.4k Views 5 Watching
      Status Board
      I have the exact same issue. Have you found a fix for this?
      • lavolp3L Offline
        lavolp3 Module Developer
        Have you tried reinstalling pm2 or installing the latest version?
        sudo npm install pm2@latest -g
        I can’t find the line mentioned in the file /usr/lib/node_modules/pm2.
        So better reinstall I guess…
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          Status Board @lavolp3
          @lavolp3 I have not, right now my workaround is not using pm2 at all and just starting Magic Mirror with DISPLAY=:0 npm start
            dawookie1979
            tried re-installing, same issue
              dawookie1979 @Status Board
              @status-board how do I do this
              • lavolp3L Offline
                lavolp3 Module Developer @dawookie1979
                @dawookie1979 @Status-Board
                can you please explain again how (the command) and from which folder you have installed pm2?
                And what is your system running?
                  dawookie1979
                  i have tried installing pm2 using sudo npm install pm2@latest -g command, either to the root directory or within magic mirror directory.
                  i am running raspberry pi3 Magic Mirror 2.5
                  • bheplerB Offline
                    bhepler Module Developer @dawookie1979
                    @dawookie1979 - At a guess, it looks like pm2 is not compatible with the version of node that you have on your pi. I would try upgrading node then re-running the pm2 startup command.
                      dawookie1979
                      thanks, i will try that. Can you give me the command / commands to run this node update.
                        Mykle1 Project Sponsor Module Developer @dawookie1979
                        @dawookie1979
                        sudo apt update
                        then
                        sudo apt install nodejs
                        That should do it.
