    PM2 error
    13 Posts 6 Posters 7.5k Views 5 Watching
      Status Board
      I have the exact same issue. Have you found a fix for this?
      • lavolp3L
        lavolp3 Module Developer
        Have you tried reinstalling pm2 or installing the latest version?
        sudo npm install pm2@latest -g
        I can’t find the line mentioned in the file /usr/lib/node_modules/pm2.
        So better reinstall I guess…
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          Status Board @lavolp3
          @lavolp3 I have not, right now my workaround is not using pm2 at all and just starting Magic Mirror with DISPLAY=:0 npm start
          D 1 Reply Last reply
            dawookie1979
            tried re-installing, same issue
              dawookie1979 @Status Board
              @status-board how do I do this
              lavolp3L 1 Reply Last reply
              • lavolp3L
                lavolp3 Module Developer @dawookie1979
                @dawookie1979 @Status-Board
                can you please explain again how (the command) and from which folder you have installed pm2?
                And what is your system running?
                  dawookie1979
                  i have tried installing pm2 using sudo npm install pm2@latest -g command, either to the root directory or within magic mirror directory.
                  i am running raspberry pi3 Magic Mirror 2.5
                    bhepler Module Developer @dawookie1979
                    @dawookie1979 - At a guess, it looks like pm2 is not compatible with the version of node that you have on your pi. I would try upgrading node then re-running the pm2 startup command.
                      dawookie1979
                      thanks, i will try that. Can you give me the command / commands to run this node update.
                      Mykle1M 1 Reply Last reply
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @dawookie1979
                        @dawookie1979
                        sudo apt update
                        then
                        sudo apt install nodejs
                        That should do it.
                          dawookie1979
                          ok, so the way i fixed this was to totally reinstall magic mirror 2.5. Thank you for your help
                            dazza120
                            I Had Similar i have just moved the pi to boot from sd to SSD that i had and for the life of me a fresh mirror 2.50 version wouldn’t run auto boot for love nor money i used this link in the end and its working well without having to kill everything and start again https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror Hope this helps someone else
                            Install PM2 using NPM:
                            sudo npm install -g pm2
                            Starting PM2 on Boot
                            To make sure PM2 can do it’s job when (re)booting your operating system, it needs to be started on boot. Luckily, PM2 has a handy helper for this.
                            pm2 startup
                            PM2 will now show you a command you need to execute.
                            Make a MagicMirror start script.
                            To use PM2 in combination with MagicMirror, we need to make a simple shell script. Preferable, we put this script outside the MagicMirror folder to make sure it won’t give us any issues if we want to upgrade the mirror.
                            cd ~
                            nano mm.sh
                            Add the following lines:
                            Save and close, using the commands CTRL-O and CTRL-X. Now make sure the shell script is executable bij performing the following command:
                            chmod +x mm.sh
                            You are now ready to the MagicMirror using this script using PM2.
                            Starting your MagicMirror with PM2
                            Simply start your mirror with the following command:
                            pm2 start mm.sh
                            You mirror should now boot up and appear on your screen after a few seconds.
                            Enable restarting of the MagicMirror script.
                            To make sure the MagicMirror restarts after rebooting, you need to save the current state of all scripts running via PM2. To do this, execute the following command:
                            pm2 save
                            And that’s all there is! You MagicMirror should now reboot after start, and restart after any failure.
                            Controlling you MagicMirror via PM2.
                            With your MagicMirror running via PM2, you have some handy tools at hand:
                            Restarting your MagicMirror:
                            pm2 restart mm
                            Stopping your MagicMirror:
                            pm2 stop mm
                            Show the MagicMirror logs:
                            pm2 logs mm
                            Show the MagicMirror process information:
                            pm2 show mm
