    PM2 error
    13 Posts 6 Posters 6.5k Views 5 Watching
    • lavolp3L Offline
      lavolp3 Module Developer
      Have you tried reinstalling pm2 or installing the latest version?
      sudo npm install pm2@latest -g
      I can’t find the line mentioned in the file /usr/lib/node_modules/pm2.
      So better reinstall I guess…
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        Status Board @lavolp3
        @lavolp3 I have not, right now my workaround is not using pm2 at all and just starting Magic Mirror with DISPLAY=:0 npm start
          dawookie1979
          tried re-installing, same issue
            dawookie1979 @Status Board
            @status-board how do I do this
            • lavolp3L Offline
              lavolp3 Module Developer @dawookie1979
              @dawookie1979 @Status-Board
              can you please explain again how (the command) and from which folder you have installed pm2?
              And what is your system running?
                dawookie1979
                i have tried installing pm2 using sudo npm install pm2@latest -g command, either to the root directory or within magic mirror directory.
                i am running raspberry pi3 Magic Mirror 2.5
                • bheplerB Offline
                  bhepler Module Developer @dawookie1979
                  @dawookie1979 - At a guess, it looks like pm2 is not compatible with the version of node that you have on your pi. I would try upgrading node then re-running the pm2 startup command.
                    dawookie1979
                    thanks, i will try that. Can you give me the command / commands to run this node update.
                      Mykle1 Project Sponsor Module Developer @dawookie1979
                      @dawookie1979
                      sudo apt update
                      then
                      sudo apt install nodejs
                      That should do it.
                        dawookie1979
                        ok, so the way i fixed this was to totally reinstall magic mirror 2.5. Thank you for your help
