    Amazon Echo/Alexa
    interaction
    22 Posts 14 Posters 30.5k Views 14 Watching
    • V Offline
      Vendittelli Module Developer
      I saw that someone managed to turn their raspberry pi into an Amazon Echo and was wondering whether anyone was interested?
      I can’t work on it until after exams (yay student life). So if somebody wanted to try it in the interim then I thought I’d throw the suggestion out there!
      • MichMichM Offline
        MichMich
        Well, I’m not specifically interested in a Amazon Echo plugin. But I do want to built a voice recognition plugin. Unfortunately, I’m still looking for a simple, stable and powerful recognition library that plays nice with Electron and doesn’t need any Python (or other external solutions …).
        • K Offline
          KirAsh4 Moderator
          I feel this bit is mandatory. It comes courtesy of a friend who happens to have their house wired up and then this exchange happened one night:
          Her: "XBox, turn off all lights"
          Lights stay on
          Her (louder): "XBox, turn off all lights!"
          Lights stay on
          Kid4: "Mum, lights are Alexa, not XBox. Alexa, turn off all lights"
          Lights turn off
          Alexa: "okay"
          MichMichM 1 Reply Last reply Reply Quote 0
          • MichMichM Offline
            MichMich @KirAsh4
            @KirAsh4 lol. :)
              joerod
              Voice control will be great, I’d be super interested in this. I know there is a fork of this MagicMirror that does user voice control with googles API. The problem with this is that google only allows 50 API calls a day and there is no option to even buy more calls. As you can imagine the 50 calls get used up pretty quickly.
              I’ve seen another Mirror that uses Jasper which is open source and does not have the API limitation, but I found this application difficult to install.
              • N Offline
                nhubbard
                I was thinking more like Wit.ai, but that would be a little complicated to add. It requires you to make your own system, but you could automate anything you want using your mirror as the audio input source!
                Just because something doesn’t do what you planned it to do doesn’t mean it’s useless.
                – Thomas Edison
                • N Offline
                  Nichollsg
                  Hey, I am actually interested in adding Amazon Alexa at some point, and I found a tutorial for adding this. Once I finish some other stuff going on, I will be back to start working on combining the magic mirror with amazon Alexa. I think the most difficult thing is going to be getting Alexa to feed stuff directly into the magic mirror. I am looking to have her used to search and play podcast videos from NPR/YouTube, but I think this might be a bit too much for the mirror- at least for right now.
                  • P Offline
                    patm189
                    I thought I heard somewhere that the Alexa’s open source software doesn’t actually allow for voice activation, but rather a button must be used to activate voice commands… perhaps that’s incorrect. I’d love to add voice command to my mirror.
                    P N 2 Replies Last reply Reply Quote 0
                    • P Offline
                      paviro @patm189
                      @patm189 maybe CMU Sphinx could be used as the always listening part and as a button for Amazon Echo.
                      We're all stories in the end. Just make it a good one, eh?
                      – The Doctor
                      • N Offline
                        Nichollsg @patm189
                        @patm189 I see why that might be an inconvenience, and I feel the same. I would much rather use something similar to just saying “OK Google” or “Alexa, turn on…” to activate the service. However, if this is true then I will find a way to use the MMM-Button to activate it and have the omxplayer either activate default the first time the screen comes on after a certain time or change the number of times the button has to be pressed for each. Either way, I think any voice recognition software would be a cool addition to the mirror!
                        • P Offline
                          PtrBld Module Developer
                          I have just rewritten the MMM-Button module so it can support more than one Button at a time. Thereby we can theoretically take one Button to start omxplayer and one to listen for speech.
                          • T Offline
                            TerryW
                            I have a pi set up with the Alexa Voice services and indeed you must use a push button to activate listening mode. It does work pretty well. What I have started on is using the Rasberry Pi/Magic Mirror as a MQTT client. If you have an echo, you could call up and interact with Magic Mirror and your home automation and maybe have some fun “conversations” with your Magic Mirror. I think the mirror would make a great feedback device for some simple sensors around the home. You kind of end up with a home-brewed JIbo without the 500 dollar cost!
                              d3r
                              I also have Amazon alexa running on my rpi alongside the MM2. I say mirror, mine is on a monitor on my desk and I use it as dashboard/calendar/newscenter. I also have amazon alexa running on it. I used the guide amazon uploaded.
                              So the way I currently have it set up is I have the MM running on full screen and have put the alexa module as always “show on top” so I can use a mouse button to click and control alexa, while at the same time still see the other modules. Ideally, I would like to embed the alexa voice control module in the MM2. Is that something that would be possible to do?
                                derMick
                                Yesterday I found an update on amazons developer blog: https://developer.amazon.com/public/community/post/Tx1WVAG8L2OOXF0/Alexa-Voice-Service-Introduces-API-Update-that-Makes-It-Easier-to-Build-Hands-Fr
                                Now the wake up word (or voice activation) is provided. I will test the AVS/Alexa sample code during the next weeks: https://github.com/alexa/alexa-avs-sample-app/wiki/Raspberry-Pi
                                Or do I missed a „ready to use“ Alexa module for magic mirror?
                                kin regards, mick
                                PS: about limitations (of request etc.) I do not know, and I did not read the AVS documentation now.
                                • G Offline
                                  gismo2006
                                  I habe post this yeasterday unser General Forum. :-)
                                  • G Offline
                                    gismo2006
                                    You didn´t need to push a Button now but there was a time limit of 120 days befor you have to renew the libarys…
                                    greets gismo
                                    • C Offline
                                      carteblanche
                                      I’m not a programmer so I have yet to figure out how to make a module, but I was able to follow the instructions from Amazon to get AVS/Alexa running on my rpi3 while MM2 is also running. It’s kinda cool cause Alexa just runs in the background and takes commands with the wake word “Alexa”.
                                      The only feature I wish it had is visual feedback on the mirror. I also wish the Alexa sample app could autorun anytime I have the mirror loaded.
                                        darrene
                                        I’ve started looking at this too. I tried the AVS link as above - functionally great and easy to setup but I’m unsure how practical it is to implement.
                                        I’m just starting to look at @whyjustin 's module here which looks to address the MM integration aspect but I think as has been mentioned, you only get 120 days of usage before you need to revisit it.
                                          d3r
                                          I think there is a confusion about the time limit. Alexa pi comes with 2 wake word engines, Sensory and kitt.ai. Sensory will expire in at least 120 days and will need to be re setup but but the kitt.ai engine doesn’t seem to have a time limit. Kitt.ai is free for personal use but needs to be licensed when used commercial.
                                          C 1 Reply Last reply Reply Quote 2
                                          • C Offline
                                            carteblanche @d3r
                                            @d3r Yes you are correct.
                                            I have tried out both wake word engines with the Alexa pi sample app and for me the sensory engine performed much better in picking up the wake word. For some reason with snowboy (kitt.ai) I always seem to have to be very close to the mic for it to be picked up.
