    Amazon Echo/Alexa
    interaction
    22 Posts 14 Posters 29.3k Views 14 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      I feel this bit is mandatory. It comes courtesy of a friend who happens to have their house wired up and then this exchange happened one night:
      Her: "XBox, turn off all lights"
      Lights stay on
      Her (louder): "XBox, turn off all lights!"
      Lights stay on
      Kid4: "Mum, lights are Alexa, not XBox. Alexa, turn off all lights"
      Lights turn off
      Alexa: "okay"
      MichMichM 1 Reply Last reply Reply Quote 0
      • MichMichM Offline
        MichMich @KirAsh4
        @KirAsh4 lol. :)
          joerod
          Voice control will be great, I’d be super interested in this. I know there is a fork of this MagicMirror that does user voice control with googles API. The problem with this is that google only allows 50 API calls a day and there is no option to even buy more calls. As you can imagine the 50 calls get used up pretty quickly.
          I’ve seen another Mirror that uses Jasper which is open source and does not have the API limitation, but I found this application difficult to install.
          • nhubbardN Offline
            nhubbard
            I was thinking more like Wit.ai, but that would be a little complicated to add. It requires you to make your own system, but you could automate anything you want using your mirror as the audio input source!
            Just because something doesn’t do what you planned it to do doesn’t mean it’s useless.
            – Thomas Edison
            • N Offline
              Nichollsg
              Hey, I am actually interested in adding Amazon Alexa at some point, and I found a tutorial for adding this. Once I finish some other stuff going on, I will be back to start working on combining the magic mirror with amazon Alexa. I think the most difficult thing is going to be getting Alexa to feed stuff directly into the magic mirror. I am looking to have her used to search and play podcast videos from NPR/YouTube, but I think this might be a bit too much for the mirror- at least for right now.
                patm189
                I thought I heard somewhere that the Alexa’s open source software doesn’t actually allow for voice activation, but rather a button must be used to activate voice commands… perhaps that’s incorrect. I’d love to add voice command to my mirror.
                paviroP N 2 Replies Last reply Reply Quote 0
                • paviroP Offline
                  paviro @patm189
                  @patm189 maybe CMU Sphinx could be used as the always listening part and as a button for Amazon Echo.
                  – The Doctor
                  • N Offline
                    Nichollsg @patm189
                    @patm189 I see why that might be an inconvenience, and I feel the same. I would much rather use something similar to just saying “OK Google” or “Alexa, turn on…” to activate the service. However, if this is true then I will find a way to use the MMM-Button to activate it and have the omxplayer either activate default the first time the screen comes on after a certain time or change the number of times the button has to be pressed for each. Either way, I think any voice recognition software would be a cool addition to the mirror!
                      PtrBld Module Developer
                      I have just rewritten the MMM-Button module so it can support more than one Button at a time. Thereby we can theoretically take one Button to start omxplayer and one to listen for speech.
                      • T Offline
                        TerryW
                        I have a pi set up with the Alexa Voice services and indeed you must use a push button to activate listening mode. It does work pretty well. What I have started on is using the Rasberry Pi/Magic Mirror as a MQTT client. If you have an echo, you could call up and interact with Magic Mirror and your home automation and maybe have some fun “conversations” with your Magic Mirror. I think the mirror would make a great feedback device for some simple sensors around the home. You kind of end up with a home-brewed JIbo without the 500 dollar cost!
