    Monitor size recommendations
    how tomonitor
    13 Posts 6 Posters 8.4k Views 5 Watching
      j.e.f.f Project Sponsor Module Developer @Guest
      @sean said in Monitor size recommendations:
      Anyway, I think higher resolution(1920*1080) would be better for some modules. Sometimes I feel lower resolution is a bit small.
      I second this. You’ll find that most of the modules won’t scale well to 720p. Can all be corrected of you have a good handle on CSS, but if you just start with a 1080p display, you’ll save yourself time and headache.
        dcarls91
        Would a tv work? Thinking of using a tv so the speakers are already built in so that i can add alexa.
        J cowboysdudeC 2 Replies Last reply Reply Quote 1
          j.e.f.f Project Sponsor Module Developer @dcarls91
          @dcarls91 Yep TV will work fine. I built two out of TVs.
          • cowboysdudeC Offline
            cowboysdude Module Developer @dcarls91
            @dcarls91 I’m using a Vizio 32" HD tv and it is awesome! OF course I’m also using a ITX motherboard and not a pi ;)
            • bheplerB Offline
              bhepler Module Developer
              I just started work on my 4th mirror and this one is 27" diagonal. I did one mirror that was 83" x 14" so it’s pretty much “whatever works for the space”.
              Caution - Wide Load
                j.e.f.f Project Sponsor Module Developer @cowboysdude
                @cowboysdude said in Monitor size recommendations:
                @dcarls91 Raspberry Pi will work fine with a TV as well. ITX board comes in handy for other processing tasks, but the Pi has no problems outputting 1080p over HDMI.
                  dcarls91
                  Awesome, thanks for all of your input. Ended up with a 22" monitor to start with.
                    Mykle1 Project Sponsor Module Developer @dcarls91
                    @dcarls91 said in Monitor size recommendations:
                    Have fun! My first MM was a 22".
                    https://forum.magicmirror.builders/topic/1678/1-old-noob-1-rpi-i-can-t-believe-i-did-it-revisited
                      cowboysdude Module Developer @j.e.f.f
                      @j-e-f-f That is true…In my case I need more than the pi could handle.
