    Application not starting when OpenGL is enabled
    33 Posts 7 Posters 18.0k Views 6 Watching
    • K Offline
      Klinge
      Re: [RasPi2] Application not starting when OpenGL is enabled
      I have the same problem as described above. The MM does not start.
      > sh run-start.sh
      libGL error: MESA-LOADER: failed to retrieve device information
      Starting MagicMirror: v2.5.0
      Loading config ...
      Loading module helpers ...
      All module helpers loaded.
      Server started ...
      Starting module: newsfeed
      Launching application.
      And I have not a PIR Module installed too. The MM is absolute new installed and still nothing configured.
      Does anyone have an idea why it does not start?
      Thank you in advance
      richland007R 1 Reply Last reply Reply Quote 0
      • richland007R Offline
        richland007 @Klinge
        @klinge I think the appilcationstarts but on server mode only at least thats what it was doing on my case…go on a different computers webbrowser and type your mirrors RaspberryPi IP address and :8080 as the port number http://raspberrypiIP:8080 and see what you get.
        I did not find a solution to it i just took OpenGL out of the equation and it works fine
        Denis
        • ? Offline
          A Former User
          Try this
          npm start — —disable-gpu
          — is - -(dash twice.) I’m not sure disable or disabled. Try both.
          • K Offline
            Klinge
            Thank you for your advice. I will try it on Monday
            • K Offline
              Klinge
              I tried both. …disable-gpu unfortunately does not not bring any improvement. So I took OpenGL out of the equation and it works.
                Anthony Project Sponsor
                I have the same problem. When OpenGL is enabled the application freezes at launching and I must unplug my pi from power and plug it back. I even tried to update electron to a newer version but I got another error there so I end up disabling OpenGL again.
                • ? Offline
                  A Former User
                  Just use serveronly (node serveronly) instead npm start.
                    Anthony Project Sponsor @Guest
                    @sean Thank you for your fast reply. I’ll give it a try as soon as I get home and see how it goes.
                      rts58
                      Are you using pm2? I was having same issue, and was able to resolve by following pm2 setup process.
                        dazza120
                        OpenGL causes nothing but problems on the Pi I had to go back to legacy, full GL caused locked up the Pi causing black screen from the start of the MM, Fake GL caused MMM-voice not to work, so had to go back to legacy and all problems above gone
                        • 1 / 4
