    trouble Accessing JSON structure using variables, help
    4 Posts 2 Posters 1.3k Views 2 Watching
      sdetweil
      I am trying to access a json structure using variables containing the parts of the structure.
      according to the javascript and json docs, when u want to use variables, u must use the bracket notation
      so
      object[key1][key2].value
      when object looks like this
        "fred":{"mary":"value1","sue":value2"}
      so
      var a='fred'
      var b='sue'
      and
      object[a][b].value should return 'value2'
      but in my module, I am getting cannot access 'sue' of undefined
      if I make a variable then it works, but still throws an error
      var bob=object[a][b] returns error cannot access 'sue' of undefined
      but if I do
      var bob= object[a.toString()][b.toString()]
      then it works, and bob= the sue data item and
      bob.value works… BUT still throws an error cannot access value of undefined… but it worked (I debug step thru the code)…
      if I use literals instead of variables as the key names, then it works… but I need to use variables to reduce the code by using a loop to walk thru the big json object…
      do we have some downlevel javascript? or??
      this should be SO easy, but something is weird…
        @sdetweil well, its a side effect of the way the code works…
        if (object[key][key] !==‘undefined’)
        will throw an access error if either of the two keys are not in the object… BEFORE you can check the results with the if…
        SO, wrap with try/catch and all is well…
          You genius types are awesome! :thumbsup:
          Create the topic. Reply to yourself. Mark topic solved (by self).
            sdetweil @Mykle1
            @mykle1 there is no better thought motivator than posting on a live forum…!!
