    The installer script linked from the main page is broken.
    4 Posts 2 Posters 1.7k Views 2 Watching
    • R
      redink
      My mirror stopped working yet again, so I reformatted the SD card and went back to square 1.
      After fighting the wifi issue, i finally got to the part of actually installing the app. However, the script on the main page breaks right away. I had to manually install NPM in order to move forward.
      But, the script still fails because it fails to fetch a bunch of dependencies. Is there a different script that I can use? I see that it hasn’t been updated in 9 months.
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @redink
        @redink
        I don’t think there is another install script. However, you can run npm install in the MagicMirror directory. This often completes installing the dependencies. MM can also be installed manually but you likely already know that. Good luck, mate.
        • R
          redink
          Thanks! The manual install did the trick for me.
          • Mykle1M
            @redink
            Good news!
