    MMM-Hue-Lights - new module for your Philips Hue lights!
    87 Posts 20 Posters 68.4k Views 19 Watching
    • michael5rM Offline
      michael5r Module Developer @dhoggan
      @dhoggan said in MMM-Hue-Lights - new module for your Philips Hue lights!:
      The first issue is that, despite setting the position to be middle_center it adamantly displays justified to the left. If I set it as bottom_center, bottom_right or a variety of other positions it displays as expected; but always to the left if middle_center selected.
      The position has nothing to do with the internal alignment of the module - you need to add:
      alignment: 'center',
      to your config for the content to be centered.
      The third is more of a question as I can’t find out how to do this. One of the display examples has the left column with room groups and the right with individual lights. Can anyone point in the direction as to how to do this?
      Ahh … I guess I should have been more specific in the description of the examples. There’s no way to do what you describe above - in the screenshots I just wanted to show what both the lights and groups settings looked like, so I took 2 screenshots and placed them next to each other.
        michael5r Module Developer @Smotx
        @Smotx said in MMM-Hue-Lights - new module for your Philips Hue lights!:
        very great module. Thanks for job.
        It’s not possible to just see ‘your Rooms’, same as android Hue official app ?
        Sure - in the config, set this:
        displayMode: 'groups',
        and then it will only show your Rooms.
          I don’t understand why settings 'displaymode: “groups” does not work :(
          Setting ‘groups’ work only in mmm-hue-lights?js file, on config file does not work.
          What do you mean it doesn’t work? That’s what I do on my mirror:
            Smotx @michael5r
            @michael5r
            If i set
            displayMode: ‘groups’,
            in config file, MM show ‘lights’,
            to view Groups, I have to parameter on mmm-hue-lights.js.
            I don’t know why.
            michael5rM 1 Reply Last reply Reply Quote 0
              @michael5r
              If i set
              I don’t know why.
              Please paste in your entire config for this module - you can XXX out the sensitive info. Thanks!
              • tidus5T Offline
                tidus5
                Amazing job !!
                did you plan to make your module tactile ready :-p
                  Smotx @michael5r
                  @michael5r
                  module: “mmm-hue-lights”,
                  position: “lower_third”, // pick whichever position you want
                  bridgeIp: “192.168.1.156”,
                  user: “xxxxxxxxx”,
                  displayType: “grid”,
                  displaymode: “groups”,
                  hideFilter: [“Bloom”, “V3”, “SDB”],
                  // … and whatever else configuration options you want to use
                    Smotx
                    Why if i set
                    var config = {
                    	address: "0.0.0.0",
                    (To open my MM from another computer)
                    I have error on this module :
                    Hue api erroe:error ; read ECONNREST
                    hue api error: null
                    Thx
                    • N Offline
                      numb3rs
                      I just reinstalled magic mirror on the pi. I installed the mmm-hue-lights module. I tried the default config, and my old config and neither seem to work. The module just sits there with ‘Loading…’
                      Anybody have ideas?
                      I did open debug logs and see the module load.
                      ‘Starting module: mmm-hue-lights, version 1.3.2’ with no errors.
                      Inserting GET and POST with the user id works fine in the api nginx webpage.
                      I just noticed: Someone on GitHub put a bug report in this as well with the same issue.
                        JohnBachini
                        have you tried restarting the hue hub ?
                        • 6
                        • 7
                        • 8
                        • 9
                        • 4 / 9
