    MMM-Hue-Lights - new module for your Philips Hue lights!
    87 Posts 20 Posters 84.1k Views 19 Watching
    • michael5rM
      michael5r Module Developer @Smotx
      @Smotx said in MMM-Hue-Lights - new module for your Philips Hue lights!:
      I don’t understand why settings 'displaymode: “groups” does not work :(
      Setting ‘groups’ work only in mmm-hue-lights?js file, on config file does not work.
      What do you mean it doesn’t work? That’s what I do on my mirror:
        Smotx @michael5r
        @michael5r
        If i set
        displayMode: ‘groups’,
        in config file, MM show ‘lights’,
        to view Groups, I have to parameter on mmm-hue-lights.js.
        I don’t know why.
        michael5rM 1 Reply Last reply
        • michael5rM
          @michael5r
          If i set
          I don’t know why.
          Please paste in your entire config for this module - you can XXX out the sensitive info. Thanks!
          • tidus5T
            tidus5
            Amazing job !!
            did you plan to make your module tactile ready :-p
              Smotx @michael5r
              @michael5r
              module: “mmm-hue-lights”,
              position: “lower_third”, // pick whichever position you want
              bridgeIp: “192.168.1.156”,
              user: “xxxxxxxxx”,
              displayType: “grid”,
              displaymode: “groups”,
              hideFilter: [“Bloom”, “V3”, “SDB”],
              // … and whatever else configuration options you want to use
                Smotx
                Why if i set
                var config = {
                	address: "0.0.0.0",
                (To open my MM from another computer)
                I have error on this module :
                Hue api erroe:error ; read ECONNREST
                hue api error: null
                Thx
                • N
                  numb3rs
                  I just reinstalled magic mirror on the pi. I installed the mmm-hue-lights module. I tried the default config, and my old config and neither seem to work. The module just sits there with ‘Loading…’
                  Anybody have ideas?
                  I did open debug logs and see the module load.
                  ‘Starting module: mmm-hue-lights, version 1.3.2’ with no errors.
                  Inserting GET and POST with the user id works fine in the api nginx webpage.
                  I just noticed: Someone on GitHub put a bug report in this as well with the same issue.
                    JohnBachini
                    have you tried restarting the hue hub ?
                      jasim
                      I installed mmm-hue-lights by default and get the following error message after 5 minutes. Hue API ERROR: Error: Read ECONNRESET. I ask for help with this problem. I’ve already reinstalled everything and it doesn’t help.
                      J michael5rM 2 Replies Last reply
                        craig859
                        Even after using Hue Developer to access the API debug/clip.html and generate a user string the Magic Mirror displays “please add your hue bridge IP and user to MagicMirror config.js file.”
                        Has anyone seen anything new on this? Is there a change in the authentication for Hue, maybe something that broke this module?
                          jasim @jasim
                          @jasim can nobody help me?
                          StoffbeuteluweS 1 Reply Last reply
                          • StoffbeuteluweS
                            Stoffbeuteluwe Project Sponsor @jasim
                            @jasim can you post module config?
                              jasim
                              position: “top_right”, // pick whichever position you want
                              bridgeIp: “192.168.178.21”,
                              user: “ueRkyc6AclD2RnpgaUjnTYZb-1Z30eRsjYeF5bt”,
                              J 1 Reply Last reply
                                jasim @jasim
                                @jasim
                                defaults: {
                                bridgeIp: ‘192.168.178.21’,
                                user: ‘ueRkyc6AclD2RnpgaUjnTYZb-1Z30eRsjYeF5bt’,
                                displayType: ‘grid’,
                                displayMode: ‘lights’,
                                displayFilter: [‘all’],
                                hideFilter: [],
                                hideOff: false,
                                alignment: ‘left’,
                                coloredList: true,
                                minimalList: false,
                                minimalGrid: false,
                                minimalGridUltra: false,
                                motionSleep: false,
                                motionSleepSeconds: 300, // this is in seconds (not ms)
                                updateInterval: 2 * 60 * 1000,
                                animationSpeed: 2 * 1000,
                                initialLoadDelay: 0,
                                version: ‘1.3.2’
                                J StoffbeuteluweS 2 Replies Last reply
                                  jasim @jasim
                                  @jasim die Benutzer ID habe ich etwas gekürzt.
                                  • StoffbeuteluweS
                                    @jasim Ich versuche heute Abend mal deine config. das wir wissen ob da irgendwo ein Fehler ist…
                                    • StoffbeuteluweS
                                      @jasim versuch mal meins, das funktioniert…
                                                  module: "mmm-hue-lights",
                                                  header: "Philips-Hue",
                                                  position: "bottom_right", // pick whichever position you want
                                                  bridgeIp: "xxxxxxxxxxxxxxxxxxx",
                                                  user: "xxxxxxxxxxxxxxxxxxx",
                                                  displayType: 'grid',
                                                  displayMode: 'lights',
                                                  displayFilter: ['all'],
                                                  hideFilter: [],
                                                  hideOff: false,
                                                  alignment: 'right',
                                                  coloredList: true,
                                                  minimalList: false,
                                                  minimalGrid: true,
                                                  motionSleep: false,
                                                  version: '1.3.2'
                                        jasim
                                        Funktioniert leider auch nicht nach 10 min kommt besagte Fehlermeldung.
                                        • StoffbeuteluweS
                                          @jasim also kann es ja nur an der Installation liegen…
                                          • StoffbeuteluweS
                                            maybe somebody can help…we have checked the config …works but error message on the screen
                                            • 3 / 5
