    MMM-Hue-Lights - new module for your Philips Hue lights!
    87 Posts 20 Posters 81.0k Views 19 Watching
      Smotx
      Why if i set
      var config = {
      	address: "0.0.0.0",
      (To open my MM from another computer)
      I have error on this module :
      Hue api erroe:error ; read ECONNREST
      hue api error: null
      Thx
      • N Offline
        numb3rs
        I just reinstalled magic mirror on the pi. I installed the mmm-hue-lights module. I tried the default config, and my old config and neither seem to work. The module just sits there with ‘Loading…’
        Anybody have ideas?
        I did open debug logs and see the module load.
        ‘Starting module: mmm-hue-lights, version 1.3.2’ with no errors.
        Inserting GET and POST with the user id works fine in the api nginx webpage.
        I just noticed: Someone on GitHub put a bug report in this as well with the same issue.
          JohnBachini
          have you tried restarting the hue hub ?
            jasim
            I installed mmm-hue-lights by default and get the following error message after 5 minutes. Hue API ERROR: Error: Read ECONNRESET. I ask for help with this problem. I’ve already reinstalled everything and it doesn’t help.
            J michael5rM 2 Replies Last reply Reply Quote 0
              craig859
              Even after using Hue Developer to access the API debug/clip.html and generate a user string the Magic Mirror displays “please add your hue bridge IP and user to MagicMirror config.js file.”
              Has anyone seen anything new on this? Is there a change in the authentication for Hue, maybe something that broke this module?
              michael5rM 1 Reply Last reply Reply Quote 0
                jasim @jasim
                @jasim can nobody help me?
                • StoffbeuteluweS Offline
                  Stoffbeuteluwe Project Sponsor @jasim
                  @jasim can you post module config?
                    jasim
                    module: “mmm-hue-lights”,
                    position: “top_right”, // pick whichever position you want
                    bridgeIp: “192.168.178.21”,
                    user: “ueRkyc6AclD2RnpgaUjnTYZb-1Z30eRsjYeF5bt”,
                    // … and whatever else configuration options you want to use
                      jasim @jasim
                      @jasim
                      defaults: {
                      bridgeIp: ‘192.168.178.21’,
                      user: ‘ueRkyc6AclD2RnpgaUjnTYZb-1Z30eRsjYeF5bt’,
                      displayType: ‘grid’,
                      displayMode: ‘lights’,
                      displayFilter: [‘all’],
                      hideFilter: [],
                      hideOff: false,
                      alignment: ‘left’,
                      coloredList: true,
                      minimalList: false,
                      minimalGrid: false,
                      minimalGridUltra: false,
                      motionSleep: false,
                      motionSleepSeconds: 300, // this is in seconds (not ms)
                      updateInterval: 2 * 60 * 1000,
                      animationSpeed: 2 * 1000,
                      initialLoadDelay: 0,
                      version: ‘1.3.2’
                      J StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                        jasim @jasim
                        @jasim die Benutzer ID habe ich etwas gekürzt.
                          @jasim Ich versuche heute Abend mal deine config. das wir wissen ob da irgendwo ein Fehler ist…
                            @jasim versuch mal meins, das funktioniert…
                                        module: "mmm-hue-lights",
                                        header: "Philips-Hue",
                                        position: "bottom_right", // pick whichever position you want
                                        bridgeIp: "xxxxxxxxxxxxxxxxxxx",
                                        user: "xxxxxxxxxxxxxxxxxxx",
                                        displayType: 'grid',
                                        displayMode: 'lights',
                                        displayFilter: ['all'],
                                        hideFilter: [],
                                        hideOff: false,
                                        alignment: 'right',
                                        coloredList: true,
                                        minimalList: false,
                                        minimalGrid: true,
                                        motionSleep: false,
                                        version: '1.3.2'
                              jasim
                              Funktioniert leider auch nicht nach 10 min kommt besagte Fehlermeldung.
                                @jasim also kann es ja nur an der Installation liegen…
                                  maybe somebody can help…we have checked the config …works but error message on the screen
                                    jasim @Stoffbeuteluwe
                                    @Stoffbeuteluwe said in MMM-Hue-Lights - new module for your Philips Hue lights!:
                                    Aber was kann ich da falsch gemacht haben, ich habe schon alles neu installiert und es kommt immer wieder die Fehlermeldung.
                                    Die Installation ist doch recht einfach: Run git clone https://github.com/michael5r/mmm-hue-lights.git from inside your MagicMirror/modules folder.
                                    Mehr steht da nicht.
                                    Oder muss ich noch etwas zusätzlichen installieren.
                                      @jasim ich weiß auch nicht so richtig, das kann es ja bloß noch der ip oder der User Nummer liegen…
                                      bei der Installation kannst du nicht viel falsch machen und die config geht ja auch.
                                      Ich bin leider auch kein Profi…das ich hier ins Detail gehen kann.
                                        @Stoffbeuteluwe Ich habe nochmal eine neue user nummer erzeugt und auch da nach 10 min keine verbindung mehr. Kann es sein das bei der erzeugung der user nummer da steht ( {“devicetype”:“my_hue_app#iphone peter”} )
                                        ich habe aber ein Android Smartphone , kann das der Fehler sein.?
                                          @jasim aber die ersten 10 min funktioniert es??
                                            @Stoffbeuteluwe Ja ohne probleme.
                                            • 3 / 5
