    MMM-Hue-Lights - new module for your Philips Hue lights!
    87 Posts 20 Posters 77.9k Views 19 Watching
      jasim
      I installed mmm-hue-lights by default and get the following error message after 5 minutes. Hue API ERROR: Error: Read ECONNRESET. I ask for help with this problem. I’ve already reinstalled everything and it doesn’t help.
      J michael5rM 2 Replies Last reply Reply Quote 0
        craig859
        Even after using Hue Developer to access the API debug/clip.html and generate a user string the Magic Mirror displays “please add your hue bridge IP and user to MagicMirror config.js file.”
        Has anyone seen anything new on this? Is there a change in the authentication for Hue, maybe something that broke this module?
        michael5rM 1 Reply Last reply Reply Quote 0
          jasim @jasim
          @jasim can nobody help me?
          • StoffbeuteluweS Offline
            Stoffbeuteluwe Project Sponsor @jasim
            @jasim can you post module config?
              jasim
              module: “mmm-hue-lights”,
              position: “top_right”, // pick whichever position you want
              bridgeIp: “192.168.178.21”,
              user: “ueRkyc6AclD2RnpgaUjnTYZb-1Z30eRsjYeF5bt”,
              // … and whatever else configuration options you want to use
                jasim @jasim
                @jasim
                defaults: {
                bridgeIp: ‘192.168.178.21’,
                user: ‘ueRkyc6AclD2RnpgaUjnTYZb-1Z30eRsjYeF5bt’,
                displayType: ‘grid’,
                displayMode: ‘lights’,
                displayFilter: [‘all’],
                hideFilter: [],
                hideOff: false,
                alignment: ‘left’,
                coloredList: true,
                minimalList: false,
                minimalGrid: false,
                minimalGridUltra: false,
                motionSleep: false,
                motionSleepSeconds: 300, // this is in seconds (not ms)
                updateInterval: 2 * 60 * 1000,
                animationSpeed: 2 * 1000,
                initialLoadDelay: 0,
                version: ‘1.3.2’
                J StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                  jasim @jasim
                  @jasim die Benutzer ID habe ich etwas gekürzt.
                    @jasim Ich versuche heute Abend mal deine config. das wir wissen ob da irgendwo ein Fehler ist…
                      @jasim versuch mal meins, das funktioniert…
                                  module: "mmm-hue-lights",
                                  header: "Philips-Hue",
                                  position: "bottom_right", // pick whichever position you want
                                  bridgeIp: "xxxxxxxxxxxxxxxxxxx",
                                  user: "xxxxxxxxxxxxxxxxxxx",
                                  displayType: 'grid',
                                  displayMode: 'lights',
                                  displayFilter: ['all'],
                                  hideFilter: [],
                                  hideOff: false,
                                  alignment: 'right',
                                  coloredList: true,
                                  minimalList: false,
                                  minimalGrid: true,
                                  motionSleep: false,
                                  version: '1.3.2'
                        jasim
                        Funktioniert leider auch nicht nach 10 min kommt besagte Fehlermeldung.
                          @jasim also kann es ja nur an der Installation liegen…
                            maybe somebody can help…we have checked the config …works but error message on the screen
                              jasim @Stoffbeuteluwe
                              @Stoffbeuteluwe said in MMM-Hue-Lights - new module for your Philips Hue lights!:
                              Aber was kann ich da falsch gemacht haben, ich habe schon alles neu installiert und es kommt immer wieder die Fehlermeldung.
                              Die Installation ist doch recht einfach: Run git clone https://github.com/michael5r/mmm-hue-lights.git from inside your MagicMirror/modules folder.
                              Mehr steht da nicht.
                              Oder muss ich noch etwas zusätzlichen installieren.
                                @jasim ich weiß auch nicht so richtig, das kann es ja bloß noch der ip oder der User Nummer liegen…
                                bei der Installation kannst du nicht viel falsch machen und die config geht ja auch.
                                Ich bin leider auch kein Profi…das ich hier ins Detail gehen kann.
                                  @Stoffbeuteluwe Ich habe nochmal eine neue user nummer erzeugt und auch da nach 10 min keine verbindung mehr. Kann es sein das bei der erzeugung der user nummer da steht ( {“devicetype”:“my_hue_app#iphone peter”} )
                                  ich habe aber ein Android Smartphone , kann das der Fehler sein.?
                                    @jasim aber die ersten 10 min funktioniert es??
                                      @Stoffbeuteluwe Ja ohne probleme.
                                        @jasim bei mir passiert das auch wenn das die ganze Nacht in Standby geht…dann ist früh auch die Fehlermeldung da weil es keine Daten bekommt.
                                        Ich mach dann MM Neustart dann geht es wieder.
                                          @Stoffbeuteluwe ich habe den Entwickler des Moduls schon angeschrieben, aber er meldet sich nicht.
                                          Eigentlich ein schönes Modul aber nicht zu gebrauchen .
                                            Cain
                                            @jasim said in MMM-Hue-Lights - new module for your Philips Hue lights!:
                                            can you use the api on the hub itself when it stops working on the magic mirror
                                            https:// /debug/clip.html ?
                                            as maybe there are too many request
                                            also what version of the hub are you using?
                                            and what updateinterval?
                                            • 3 / 5
