    MMM-Hue-Lights - new module for your Philips Hue lights!
    87 Posts 20 Posters 84.1k Views 19 Watching
      Smotx
      I don’t understand why settings 'displaymode: “groups” does not work :(
      Setting ‘groups’ work only in mmm-hue-lights?js file, on config file does not work.
      michael5rM 1 Reply Last reply
      • michael5rM
        michael5r Module Developer @dhoggan
        @dhoggan said in MMM-Hue-Lights - new module for your Philips Hue lights!:
        The first issue is that, despite setting the position to be middle_center it adamantly displays justified to the left. If I set it as bottom_center, bottom_right or a variety of other positions it displays as expected; but always to the left if middle_center selected.
        The position has nothing to do with the internal alignment of the module - you need to add:
        alignment: 'center',
        to your config for the content to be centered.
        The third is more of a question as I can’t find out how to do this. One of the display examples has the left column with room groups and the right with individual lights. Can anyone point in the direction as to how to do this?
        Ahh … I guess I should have been more specific in the description of the examples. There’s no way to do what you describe above - in the screenshots I just wanted to show what both the lights and groups settings looked like, so I took 2 screenshots and placed them next to each other.
        • michael5rM
          michael5r Module Developer @Smotx
          @Smotx said in MMM-Hue-Lights - new module for your Philips Hue lights!:
          very great module. Thanks for job.
          It’s not possible to just see ‘your Rooms’, same as android Hue official app ?
          Sure - in the config, set this:
          displayMode: 'groups',
          and then it will only show your Rooms.
          • michael5rM
            What do you mean it doesn’t work? That’s what I do on my mirror:
              Smotx @michael5r
              @michael5r
              If i set
              displayMode: ‘groups’,
              in config file, MM show ‘lights’,
              to view Groups, I have to parameter on mmm-hue-lights.js.
              I don’t know why.
              • michael5rM
                @michael5r
                If i set
                I don’t know why.
                Please paste in your entire config for this module - you can XXX out the sensitive info. Thanks!
                • tidus5T
                  tidus5
                  Amazing job !!
                  did you plan to make your module tactile ready :-p
                    Smotx @michael5r
                    @michael5r
                    module: “mmm-hue-lights”,
                    position: “lower_third”, // pick whichever position you want
                    bridgeIp: “192.168.1.156”,
                    user: “xxxxxxxxx”,
                    displayType: “grid”,
                    displaymode: “groups”,
                    hideFilter: [“Bloom”, “V3”, “SDB”],
                    // … and whatever else configuration options you want to use
                      Smotx
                      Why if i set
                      var config = {
                      	address: "0.0.0.0",
                      (To open my MM from another computer)
                      I have error on this module :
                      Hue api erroe:error ; read ECONNREST
                      hue api error: null
                      Thx
                      • N
                        numb3rs
                        I just reinstalled magic mirror on the pi. I installed the mmm-hue-lights module. I tried the default config, and my old config and neither seem to work. The module just sits there with ‘Loading…’
                        Anybody have ideas?
                        I did open debug logs and see the module load.
                        ‘Starting module: mmm-hue-lights, version 1.3.2’ with no errors.
                        Inserting GET and POST with the user id works fine in the api nginx webpage.
                        I just noticed: Someone on GitHub put a bug report in this as well with the same issue.
                          JohnBachini
                          have you tried restarting the hue hub ?
                            jasim
                            I installed mmm-hue-lights by default and get the following error message after 5 minutes. Hue API ERROR: Error: Read ECONNRESET. I ask for help with this problem. I’ve already reinstalled everything and it doesn’t help.
                            J michael5rM 2 Replies Last reply
                              craig859
                              Even after using Hue Developer to access the API debug/clip.html and generate a user string the Magic Mirror displays “please add your hue bridge IP and user to MagicMirror config.js file.”
                              Has anyone seen anything new on this? Is there a change in the authentication for Hue, maybe something that broke this module?
                                jasim @jasim
                                @jasim can nobody help me?
                                StoffbeuteluweS 1 Reply Last reply
                                • StoffbeuteluweS
                                  Stoffbeuteluwe Project Sponsor @jasim
                                  @jasim can you post module config?
                                    jasim
                                    position: “top_right”, // pick whichever position you want
                                    bridgeIp: “192.168.178.21”,
                                    user: “ueRkyc6AclD2RnpgaUjnTYZb-1Z30eRsjYeF5bt”,
                                    J 1 Reply Last reply
                                      jasim @jasim
                                      @jasim
                                      defaults: {
                                      bridgeIp: ‘192.168.178.21’,
                                      user: ‘ueRkyc6AclD2RnpgaUjnTYZb-1Z30eRsjYeF5bt’,
                                      displayType: ‘grid’,
                                      displayMode: ‘lights’,
                                      displayFilter: [‘all’],
                                      hideFilter: [],
                                      hideOff: false,
                                      alignment: ‘left’,
                                      coloredList: true,
                                      minimalList: false,
                                      minimalGrid: false,
                                      minimalGridUltra: false,
                                      motionSleep: false,
                                      motionSleepSeconds: 300, // this is in seconds (not ms)
                                      updateInterval: 2 * 60 * 1000,
                                      animationSpeed: 2 * 1000,
                                      initialLoadDelay: 0,
                                      version: ‘1.3.2’
                                      J StoffbeuteluweS 2 Replies Last reply
                                        jasim @jasim
                                        @jasim die Benutzer ID habe ich etwas gekürzt.
                                        • StoffbeuteluweS
                                          @jasim Ich versuche heute Abend mal deine config. das wir wissen ob da irgendwo ein Fehler ist…
                                          • StoffbeuteluweS
                                            @jasim versuch mal meins, das funktioniert…
                                                        module: "mmm-hue-lights",
                                                        header: "Philips-Hue",
                                                        position: "bottom_right", // pick whichever position you want
                                                        bridgeIp: "xxxxxxxxxxxxxxxxxxx",
                                                        user: "xxxxxxxxxxxxxxxxxxx",
                                                        displayType: 'grid',
                                                        displayMode: 'lights',
                                                        displayFilter: ['all'],
                                                        hideFilter: [],
                                                        hideOff: false,
                                                        alignment: 'right',
                                                        coloredList: true,
                                                        minimalList: false,
                                                        minimalGrid: true,
                                                        motionSleep: false,
                                                        version: '1.3.2'
                                            • 2 / 5
