    MMM-Hue-Lights - new module for your Philips Hue lights!
    87 Posts 20 Posters 84.1k Views 19 Watching
      dhoggan
      Just to add that I have managed to work out why the multi-column grid wasn’t working - it was down to me adding the suggested lines between the default { } entries. Adding the lines at the very end of the file and I have columns at last! Just in case anyone else ever has the same issue the custom.css file looks like:
      body {
      .mmm-hue-lights .grid {
      width: auto;
      display: flex;
      flex-flow: row wrap;
      margin: -10px;
      max-width: none;
      justify-content: center;
      .mmm-hue-lights .grid .hue {
      width: calc(25% - 20px);
      margin: 10px;
      display: block;
      Still puzzling over how the example had rooms in one column and lights in another - if anyone knows I’d be grateful of the help.
      Thanks,
      Dave
        Smotx
        very great module. Thanks for job.
        It’s not possible to just see ‘your Rooms’, same as android Hue official app ?
        Official app :
        alt text
        MagicMirror module :
        alt text
        michael5rM 1 Reply Last reply
          Smotx
          I don’t understand why settings 'displaymode: “groups” does not work :(
          Setting ‘groups’ work only in mmm-hue-lights?js file, on config file does not work.
          • michael5rM
            michael5r Module Developer @dhoggan
            @dhoggan said in MMM-Hue-Lights - new module for your Philips Hue lights!:
            The first issue is that, despite setting the position to be middle_center it adamantly displays justified to the left. If I set it as bottom_center, bottom_right or a variety of other positions it displays as expected; but always to the left if middle_center selected.
            The position has nothing to do with the internal alignment of the module - you need to add:
            alignment: 'center',
            to your config for the content to be centered.
            The third is more of a question as I can’t find out how to do this. One of the display examples has the left column with room groups and the right with individual lights. Can anyone point in the direction as to how to do this?
            Ahh … I guess I should have been more specific in the description of the examples. There’s no way to do what you describe above - in the screenshots I just wanted to show what both the lights and groups settings looked like, so I took 2 screenshots and placed them next to each other.
            • michael5rM
              michael5r Module Developer @Smotx
              @Smotx said in MMM-Hue-Lights - new module for your Philips Hue lights!:
              Sure - in the config, set this:
              displayMode: 'groups',
              and then it will only show your Rooms.
              • michael5rM
                What do you mean it doesn’t work? That’s what I do on my mirror:
                  Smotx @michael5r
                  @michael5r
                  If i set
                  displayMode: ‘groups’,
                  in config file, MM show ‘lights’,
                  to view Groups, I have to parameter on mmm-hue-lights.js.
                  I don’t know why.
                  • michael5rM
                    @michael5r
                    If i set
                    I don’t know why.
                    Please paste in your entire config for this module - you can XXX out the sensitive info. Thanks!
                    • tidus5T
                      tidus5
                      Amazing job !!
                      did you plan to make your module tactile ready :-p
                        Smotx @michael5r
                        @michael5r
                        module: “mmm-hue-lights”,
                        position: “lower_third”, // pick whichever position you want
                        bridgeIp: “192.168.1.156”,
                        user: “xxxxxxxxx”,
                        displayType: “grid”,
                        displaymode: “groups”,
                        hideFilter: [“Bloom”, “V3”, “SDB”],
                        // … and whatever else configuration options you want to use
                          Smotx
                          Why if i set
                          var config = {
                          	address: "0.0.0.0",
                          (To open my MM from another computer)
                          I have error on this module :
                          Hue api erroe:error ; read ECONNREST
                          hue api error: null
                          Thx
                          • N
                            numb3rs
                            I just reinstalled magic mirror on the pi. I installed the mmm-hue-lights module. I tried the default config, and my old config and neither seem to work. The module just sits there with ‘Loading…’
                            Anybody have ideas?
                            I did open debug logs and see the module load.
                            ‘Starting module: mmm-hue-lights, version 1.3.2’ with no errors.
                            Inserting GET and POST with the user id works fine in the api nginx webpage.
                            I just noticed: Someone on GitHub put a bug report in this as well with the same issue.
                              JohnBachini
                              have you tried restarting the hue hub ?
                                jasim
                                I installed mmm-hue-lights by default and get the following error message after 5 minutes. Hue API ERROR: Error: Read ECONNRESET. I ask for help with this problem. I’ve already reinstalled everything and it doesn’t help.
                                J michael5rM 2 Replies Last reply
                                  craig859
                                  Even after using Hue Developer to access the API debug/clip.html and generate a user string the Magic Mirror displays “please add your hue bridge IP and user to MagicMirror config.js file.”
                                  Has anyone seen anything new on this? Is there a change in the authentication for Hue, maybe something that broke this module?
                                    jasim @jasim
                                    @jasim can nobody help me?
                                    StoffbeuteluweS 1 Reply Last reply
                                    • StoffbeuteluweS
                                      Stoffbeuteluwe Project Sponsor @jasim
                                      @jasim can you post module config?
                                        jasim
                                        position: “top_right”, // pick whichever position you want
                                        bridgeIp: “192.168.178.21”,
                                        user: “ueRkyc6AclD2RnpgaUjnTYZb-1Z30eRsjYeF5bt”,
                                        J 1 Reply Last reply
                                          jasim @jasim
                                          @jasim
                                          defaults: {
                                          bridgeIp: ‘192.168.178.21’,
                                          user: ‘ueRkyc6AclD2RnpgaUjnTYZb-1Z30eRsjYeF5bt’,
                                          displayType: ‘grid’,
                                          displayMode: ‘lights’,
                                          displayFilter: [‘all’],
                                          hideFilter: [],
                                          hideOff: false,
                                          alignment: ‘left’,
                                          coloredList: true,
                                          minimalList: false,
                                          minimalGrid: false,
                                          minimalGridUltra: false,
                                          motionSleep: false,
                                          motionSleepSeconds: 300, // this is in seconds (not ms)
                                          updateInterval: 2 * 60 * 1000,
                                          animationSpeed: 2 * 1000,
                                          initialLoadDelay: 0,
                                          version: ‘1.3.2’
                                          J StoffbeuteluweS 2 Replies Last reply
                                            jasim @jasim
                                            @jasim die Benutzer ID habe ich etwas gekürzt.
                                            • 2 / 5
