    MMM-CalendarExt2
    486 Posts 83 Posters 949.3k Views 83 Watching
    • W Offline
      wegz15
      So, I tried a public google calendar as well as 2 of my private shared google calendars. The shared public one does not work, 1 of my shared one works, and 1 does not within the module. However, all of these calendars work in the default upcoming events module. Any suggestions on why this is? Also, I tried changing the “calendarfetcher.js” in the default calendar folder and with that change the default calendar stopped working, but the mmm-calendarext2 worked.
      W ? 2 Replies Last reply Reply Quote 0
      • W Offline
        wegz15 @wegz15
        I think I figured out the problem. I can see other recent events added to these calendars. I think since they are older calendars they fall outside of the maxItems: 100, beforeDays: 60, afterDays: 365, maxIterations: 100 ranges. I tried adjusting those to go back to the start of the calendars and when I do it doesn’t pull in any events from any of my calendars. I’m not sure how to fix this.
        • ? Offline
          A Former User @wegz15
          @wegz15
          maybe some repeated events couldn’t be parsed. this is using different parser with default module. it is faster and has more features. but occasionally it fails some repeated events.
          i’m researching how to improve but not yet success. i may return but need more time to consider.
          • ? Offline
            @wegz15
            anyway, can you send me your ics url and configuration? my mail is eouia0819@gmail.com
            • ? Offline
              @wegz15
              Now I think found something. set your maxIteration to 1000.
              The reason is, your “Red Shift” events is started from too past, so even after 100(default value) occurrences it couldn’t reach to present age.
              • W Offline
                wegz15
                Yep, that worked. Thank you. I tried that, but I had it in the wrong spot. Its been trial and error trying to learn which values effect what on the main screen. If any one knows, is there a way to make the calendar not try to take up the full screen with the normal size text? Maybe use the % somewhere? I also have not been able to figure out how to get rid of the week number, I’m somehow missing a day, and I can’t figure out a way to get rid of the “last tuesday, Yesterday, today”. I’d also like to make that bottom weather “shorter”.
                Im just not sure how or where to edit these values. Is there maybe a tutorial or video to learn how to “edit” magicmirror and modules?
                ? C 2 Replies Last reply Reply Quote 0
                • ? Offline
                  @wegz15
                  month or week view might be too huge even for 1920*1080 size.
                  • To get rid of week number, open your css/custom.css then add this.
                  .CX2 .weeksmark {
                    display:none;
                  • To adjust day format, add this in your view configuration
                  slotTitleFormat: "D",
                  slotSubTitleFormat: "ddd",
                  I think you’ve set above fields in defaultSet, but each view can have it’s own setting. Especially, week and month could have different behaviors with other views for settings. Read the wiki carefully. https://github.com/eouia/MMM-CalendarExt2/wiki/2d.-Configuration:defaultSet
                  • W Offline
                    wegz15
                    I guess what is confusing me the most is where to actually put each piece. I have that in currently and I am still seeing the “last, next today…”
                    module: 'MMM-CalendarExt2',
                    		scenes:[
                    				views: ["Monthly"],
                    		views:[
                    				mode: "Month",
                    				locale: "en",
                    				slotMaxHeight: "70px",
                    				dateFormat: "M/D",
                    				weeksFormat: " ",
                    				slotSubTitle:"ddd",
                    				slotSubTitle:"",
                    				dateTimeFormat: "ddd mm/dd",
                    				timeFormat:"h:mm A",
                    				slotCount: 5,
                    				showWeekends: true,
                    				hideOverflow: true,
                    				filterPassedEvent: false,
                    				calendars: ["Work"],
                    And I guess I’m asking if in general there is a way to scale the whole module so I can have a whole calendar fit into the open space. Thank you for all the help so far. This is my 3rd “day” working with magicmirror.
                    • ? Offline
                      Very weird. I use your configuration (even with your ics)
                      And this is what my screen shows.
                      There might be more configuration values than you posted. Give me whole configuration.
                      • W Offline
                        wegz15
                        I emailed you my whole set up earlier. I think there is something, somewhere in another folder I must have messed with. I deleted everything but my clock and pasted just the calendar and it is showing up as pictured. Maybe a fresh install of MM or MMM-calendarext2. 0_1558118108866_Screenshot (1).png
                          Jerrylein
                          @Sean thanks for the great module.
                          I would like to change the design of calendar as in calendarext (Weekdays and monthTitleFormat)
                          alt text
                          is this possible or should I use calendarext v1?
                          ? D 2 Replies Last reply Reply Quote 0
                          • ? Offline
                            A Former User @Jerrylein
                            @Jerrylein
                            weekdays name could be cutomizable, but calext2 doesn’t have monthtitle on monthview
                              Jerrylein @Guest
                              @Sean
                              ok. but how I can change this? I mean the weekdays (sun, mon, tue,wed) are not in the same row with days.
                              alt text
                              • ? Offline
                                @Jerrylein
                                That is slotSubTitleFormat.
                                in Mon 26, Mon will be slotSubTitle and 26 will be slotTitle. (and additionally 11/25 will be slotAltTitle)
                                So, if you set like;
                                  mode: "month",
                                  position: "fullscreen_below",
                                  slotSubTitleFormat: "dddd", // (default value is "ddd")
                                It will show Monday instead of Mon
                                https://github.com/eouia/MMM-CalendarExt2/wiki/2c4.-View:week,-month
                                  Jerrylein @Guest
                                  @Sean
                                  thx.
                                  But I do not want to change the format.
                                  I would like to change the design of slotSubTitle as in Calext V1
                                  Here is Calext V1
                                  that’s calext2
                                  I think i should change custom.css file? but how?
                                  • ? Offline
                                    @Jerrylein
                                    If so, why aren’t you using CalendarExt2?
                                    Unfortunately, that part of CalendarExt is table header so it can’t move.
                                    But with CalendarExt2, you can mimic CalendarExt style. like this; (Even though that’s not you want.)
                                    I misread your first question. so you can make it like this;
                                    .CX2 .weekSlot.seq_0 .cellSlot .slotSubTitle {
                                      position:relative;
                                      top:-30px;
                                      left:40%;
                                    • F Offline
                                      flopp
                                      I tried to add an URL that starts withwebcal://, but it doesn’t show up.
                                      If I try other URL from an example here, it works, so the problem must be the URL with webcal.
                                      • ? Offline
                                        A Former User @flopp
                                        @flopp Just replace webcalto http
                                        F 1 Reply Last reply Reply Quote 1
                                        • F Offline
                                          flopp @Guest
                                          @Sean said in MMM-CalendarExt2:
                                          Thanks, worked :)
                                          • F Offline
                                            flopp
                                            I am trying to get the view like the picture here
                                            https://github.com/eouia/MMM-CalendarExt2/blob/master/screenshot.png
                                            How is that possible?
                                            Or can I show 7 days, today to the left? Like 7 days rolling.
                                            • 24
                                            • 25
                                            • 2 / 25
