    MMM-CalendarExt2
    486 Posts 83 Posters 949.3k Views 83 Watching
      SARCux @debaetstony
      @debaetstony
      hi,
      these are my lines in the config.js
      views: [
      				mode: "daily",
      				title: "Termine nächsten Tage",
      				position: "top_center",
      				locale: "de-DE",
      				calendars: ["eigene Kalender eintragen"],
      				slotCount: 3,
      				slotTitleFormat: {
      						sameDay: "[Heute]",
      						nextDay: "[Morgen]",
      						nextWeek: "[am] dddd",
      						lastDay: "[Gestern]",
      						lastWeek: "[letzte] ddd",
      						sameElse: "DD.MM."
        sdetweil @SARCux
        @sarcux the doc seems to suggest where you have
        sameDay: "[Heute]",
        you could have the date format too
        sameDay: "[Heute]  D, MMM",
        you do that on lastWeek
        formatting options
        https://devhints.io/moment
          debaetstony @sdetweil
          @sdetweil @SARCux
          changed to
          slotTitleFormat: {
          	sameDay: "[Vandaag]",
          	nextWeek: "[Overmorgen]",
          slotSubTitleFormat: " ", // (default value is "ddd")
          and give me this
          (slotSubTitleFormat empty because changing date format does not work)
            debaetstony
            How can you make the empty spaces smaller?
            I have an overlap between ‘today’ view and ‘month’ view.
            Make both narrower in ‘today’ and ‘month’ view
            • BKeyportB Offline
              BKeyport Module Developer @debaetstony
              @debaetstony
              Use daily view. Eliminates the space almost completely. Also, if I remember right, if you change the order of views in the config.js, you may be able to get month view on top of daily view, but I’m not sure about that. Sean wasn’t too clear in order of building the modules.
              something else you might be interested in. If you’d like empty days to disappear in daily view:
              In your config.js, under views, add the following className: "remove_empty_slot",
              For example:
              views: [
              		mode: "daily",
              		slotCount: 14,
              		timeFormat:"LT",
              		hideOverflow: false,
              		filterPassedEvent: true,
              Then in custom.css add:
              .CX2 .remove_empty_slot .eventCount_0 {
                display:none;
              • P Offline
                pkup10
                Re: MMM-CalendarExt2
                I am new here and am trying to get the calendar extension to work. I set it up with the basic configuation but I am getting a blank screen in Magic Mirror. Any help would be appreciated.
                module: ‘MMM-CalendarExt2’,
                calendars : [
                url: “https://www.google.com/calendar/ical/ovb564thnod82u5c4njut98728%40group.calendar.google.com/public/basic.ics”,
                views: [
                mode: “daily”,
                scenes: [
                • BKeyportB Offline
                  BKeyport Module Developer @pkup10
                  @pkup10 way underconfigured. Compare to mine, stripped down to it’s bare minimum.
                  			module: "MMM-CalendarExt2", // https://github.com/MMM-CalendarExt2/MMM-CalendarExt2
                  				calendars : [
                  						url: "<URL>",
                  						name: "Main Calendar",
                  				views: [
                  						mode: "daily",
                  						calendars: ["Main Calendar"],
                  				scenes: [
                  • W Offline
                    Wenike @BKeyport
                    @bkeyport actually, that might be @pkup10 's problem: he didn’t put a position item in his config. MM won’t display it without knowing where to display it.
                    S BKeyportB 2 Replies Last reply Reply Quote 0
                      sdetweil @Wenike
                      @wenike that module doesn’t use the typical display approach. position is not used
                      • BKeyportB Offline
                        BKeyport Module Developer @Wenike
                        @wenike Take a look at my barebones config above. You’ll notice the position is part of the view config not the main part. This module creates virtual positions after the main stuff is done.
                          Askedal
                          is there a way to setup a sliding week (sliding 7 days) in the calendar, means always show the actual day as the first day and then e.g. 7 days into the future ?
                          Currently I’m showing two weeks, but on Sundays the first week shows only gone events and is not very helpful. I rather would like to save the space for the first week by just showing only 7 days in the future. Unfortunately I was not able to figure this out by myself :crying_face: .
                          Many thanks for the great addon
                          Clas
                            MMRIZE @Askedal
                            @askedal
                            Weeks views purpose is that. Use Daily view with horizontal layout.
                              MMRIZE @Askedal
                              @askedal
                              And the start day of week respects your locale. So in your country, if the week starts from Monday, adjust your locale to it.
                                Askedal @MMRIZE
                                @mmrize said in MMM-CalendarExt2:
                                @askedal
                                I tried the daily view, but then saturday and sunday were missing, it showed only the working days (maybe there were no events ?)
                                  MMRIZE @Askedal
                                  @askedal
                                  I think you are missing some options;
                                  They might be slotCount and fromNow.
                                  slotCount in daily view points How many days will appear
                                  fromNow in daily view points From which day the view begins.
                                  So if you set daily view like this;
                                  fromNow: -1,
                                  slotCount: 5
                                  It will show 5 days schedules from yesterday.
                                  I think you probably want 7 days schedule from today. In that case, this will work; (You may need more options and CSS modifying to beautify the look of view)
                                    mode: "daily",
                                    title: "My Schedule",
                                    position: "bottom_bar",
                                    type: "row",
                                    slotCount: 7,
                                    fromNow: 0,
                                    useEventTimeRelative: true,
                                  • General View options: https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/master/docs/Configuration/View.md
                                  • Daily View options : https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/master/docs/Configuration/Views/daily.md
                                    MMRIZE @Askedal
                                    @askedal
                                    Anyway, I need to point this; The MMM-CalendarExt2 is going to die because of its unusual complexity to use and heavy dependencies of obsoleted legacy node modules. I already have archived it. I wish I can release Ext3 in near future to solve those problems.
                                    A BKeyportB F 3 Replies Last reply Reply Quote 1
                                      Askedal @MMRIZE
                                      Many thanks, it is mostly working. I have now set it like this and it is showing the next 7 days correctly.
                                                  mode: "daily",
                                                  useEventTimeRelative: false,
                                                  fromNow: 0,
                                                  slotCount: 7,
                                                  type: "row",
                                                  calendars: [],
                                                  dateFormat: "dd",
                                                  slotTitleFormat: {
                                                      sameDay: "dd",
                                                      nextDay: "dd",
                                                      nextWeek: "dd",
                                                      sameElse: "",
                                      But there is a lot of free space between the days, can I somehow move the days closer together so that they look more like a table and not like 7 single days ?
                                      Many thanks for your help
                                      • BKeyportB Offline
                                        BKeyport Module Developer @MMRIZE
                                        @mmrize I do believe that there are some working within the code to try and figure out Sean’s work. It’s a shame he stepped back though, but I get it. even with my minor modules I’m suffering a bit of burnout and frustration for a free product.
                                          sdetweil @BKeyport
                                          @bkeyport @MMRIZE IS Sean!!
                                          • G Offline
                                            ge
                                            Will a touch screen work with MMM-CalendarExt2? For example have the current month displayed, and then be able to scroll to the next month, or months ahead like a phone calendar.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 21 / 25
