    MMM-CalendarExt2
    486 Posts 83 Posters 949.3k Views 83 Watching
    • G Offline
      gonzonia
      Thanks for the quick reply!
      I think it’s much closer to where I want it now. It takes some time for the data to load initially, but it seems to be working. Still some visual tweaks to make.
      I kinda miss the built in styles from CalendarExt. It made it easy to just make each calendar different.
      • F Offline
        Fr8Trayne
        Howdy @Sean something weird is happening. I have this module setup and it’s been working great for a while. It is a scene with two views. The first view is great, but the second view which has the exact same calendars only shows today. The rest of the month is blank. Have you seen this happen before?
        • ? Offline
          A Former User @Fr8Trayne
          @Fr8Trayne
          show me the configuration.
          • F Offline
            Fr8Trayne
            I’ve removed the actual links to calendars solely for this . Please note that it has been working up until 2 days ago. I love this module just not sure this stopped working. Also note I have a second version of this one a weekly view that still is working just fine.
            module: “MMM-CalendarExt2”,
            pages: {second: “fullscreen_above”},
            defaultset: {
            view: {
            slotCount: 5,
            				scenes: [
                				name: "Month Calendar",
            				views: ["family"],
            				className: "scene_1",
            				views: [
                				    mode: "week",
            				    fromNow:0,
            				    className: "view_1",
            				    calendars: [],
            				    slotTitleFormat:"MM/DD",
            				    slotSubTitleFormat: "dddd",
            				    beforeDays: "7",
            				    hideOverflow: false,
            				    type: "row",
            				    name: "Family Calendar",
            				    url: "https://calendar.google.com/calendar/ical",
            				    scanInterval: 2000,
            				    className: "family_calendar",
            				    maxIterations: 100,
            				    name: "Dad's Calendar",
            					    scanInterval: 2000,
            				    className: "dads_calendar",
            				    maxIterations: 100,
            				    name: "Mom's Calendar",
            				    scanInterval: 2000,
            				    className: "moms_calendar",
            				    maxIterations: 100,
            				    name: "Alana's Calender",
            				    scanInterval: 2000,
            				    className: "alanas_calendar",
            				    maxIterations: 100,
            				    name: "John's Calendar",
            				    scanInterval: 2000,
            				    className: "johns_calendar",
            				    maxIterations: 100,
            				    name: "Holiday Calendar",
            				    url: "https://calendar.google.com/calendar/ical,
            				    scanInterval: 2000,
            				    className: "holiday_calendar",
            				    maxIterations: 100,
            • ? Offline
              @Fr8Trayne
              I think this could be also maxItems issue of view.
              You have several calendars in a view, it means you might have tons of events in the memory of RPI.(You can check how much events are selected to load on your log.)
              Which events should be displayed would be decided by some rules with some condition - filter, sort, … In this case, you haven’t set your rule, so the view would contain 100 events(set as default, sorted by time) from whole calendars. And most(or all) of them would be too old events to display in this view.
              Just set the maxItems of view bigger, or set your rule of filter or sort events to display.
              • F Offline
                Fr8Trayne
                @Sean thanks. I have added those changes with no effect. Would you mind guiding me to find those stores events in the RPI? I’d like to see if that is the issue.
                • ? Offline
                  @Fr8Trayne
                  Could you share with me your real ical url or file to inspect? you can send it via email. (eouia0819@gmail.com)
                  • L Offline
                    lotusvball
                    Can someone show me what I am doing wrong. I have this configuration:
                    		module: 'MMM-CalendarExt2',
                    			//firstDrawingDelay: 1000*10,
                    			scenes:[
                    					views: ["VIEW1"],
                    			views:[
                    					mode: "daily",
                    					title: "Bard Family Schedule",
                    					position: "bottom_right",
                    					maxItems: 100,
                    					maxDays: 5,
                    					locale: "en",
                    					hideOverflow: true,
                    					filterPassedEvent: true,
                    					slotCount: 4,
                    					calendars: ["Steve","Tracie","Alex"],
                    					url: "https://calendar.google.com/calendar/ical/",
                    					beforeDays:0,
                    					afterDays: 5,
                    					beforeDays:0,
                    					afterDays: 5,
                    					beforeDays:0,
                    					afterDays: 5,
                    The actual calendars have the correct url in my setup. If I set one calendar to show in the view ie. [“Alex”] it works but if I try to do all of them I get nothing. Only the headings for the days.
                    Here is the startup sequence:
                    Starting MagicMirror: v2.9.0
                    Loading config …
                    Loading module helpers …
                    Initializing new module helper …
                    Module helper loaded: MMM-GooglePhotos
                    Module helper loaded: MMM-MyScoreboard
                    No helper found for module: MMM-pages.
                    Module helper loaded: MMM-OnScreenMenu
                    No helper found for module: MMM-SmartWebDisplay.
                    Module helper loaded: MMM-CalendarExt2
                    All module helpers loaded.
                    Starting server on port 8080 …
                    Server started …
                    Connecting socket for: MMM-GooglePhotos
                    MMM-GooglePhotos started
                    Connecting socket for: MMM-MyScoreboard
                    Starting node_helper for module [MMM-MyScoreboard]
                    Connecting socket for: MMM-OnScreenMenu
                    Connecting socket for: MMM-CalendarExt2
                    Sockets connected & modules started …
                    Launching application.
                    MMM-GooglePhotos initialized after loading.
                    [CALEXT2] calendar:Steve >> Scanning start with interval:1800000
                    [CALEXT2] calendar:Tracie >> Scanning start with interval:1800000
                    [CALEXT2] calendar:Alex >> Scanning start with interval:1800000
                    [CALEXT2] calendar:Alex >> Scanned: 3, Selected: 3
                    [GPHOTO] Scan finished : 66
                    [CALEXT2] calendar:Steve >> Scanned: 0, Selected: 0
                    [CALEXT2] calendar:Tracie >> Scanned: 7, Selected: 7
                    Can you see anything I am doing wrong?
                    ? 1 Reply Last reply Reply Quote 1
                    • ? Offline
                      A Former User @lotusvball
                      @lotusvball
                      Could you share with me your real ical(.ics) file or URL? By only inspection of real ical, I can tell what’s wrong.
                      email : eouia0819@gmail.com
                      • L Offline
                        lotusvball @Guest
                        @Sean Just emailed it. from sabard@gmail.com
                        • C Offline
                          code999 @wegz15
                          @wegz15 Hey!! your layout is the exact one I have been trying to do for many hours over the last months. May you please paste the code you used to make it looks like that? thx ( the doc’s are confusing and do not show where the part of the codes go to make it work. i liked the first Ext docs better.)
                            rookiepilot
                            Did anybody else’s MMM-CalendarExt2 module break after daylight savings? (Sunday November 3rd). Both my “MMM-MyCalendar” AND “MMM-CalendarExt2” modules are showing events on the wrong days now. The problem seems to only occur with reoccurring events; they usually show up one day earlier. Rebooting does not correct the issue. I hope someone can figure this out soon 😞
                            • C Offline
                              code999
                              Hi All,
                              So I have been trying to figure out how to make the calendar smaller. It is over lapping other modules. I have read the docs but I am unclear on how it all comes together to work. Please help.
                              • C Offline
                                code999 @code999
                                @code999 I guess no one knows how to do this? Everything I try it does not change what I want.
                                • ? Offline
                                  A Former User @code999
                                  @code999
                                  Too ambiguous. What you tried and what you expected as a result? It would be nice to understand with an image about where is an issue and how to change it.
                                  You can customize CSS to adjust the size of almost every element, and you can adjust some height-related values on the configuration. And, there be some brief information about the HTML structure and CSS selectors on docs. e.g) https://github.com/eouia/MMM-CalendarExt2/wiki/4.-Styling
                                  So, what is your issue?
                                  • C Offline
                                    code999 @Guest
                                    @Sean sorry about me not able to explain what I am trying to do. this is how it looks now. 0_1573232750888_before edit.JPG I want to move it to the right and shrink it so it does not overlap the other modules. 0_1573232901007_trying to do.JPG
                                    Thanks for your help.
                                    M ? 2 Replies Last reply Reply Quote 0
                                      mrdenmark
                                      This post is deleted!
                                        mrdenmark @code999
                                        @code999
                                        try position top_right instead of full_screen and see how that looks, you can then have a dig around the files and see if you can alter the size by specifying the size % or pixels
                                          mrdenmark
                                          @Sean ,
                                          can this module work with mmm-keybindings?i’d like to use the spacebar or similar to cycle through scenes
                                          • ? Offline
                                            @code999
                                            Which position did you set for the view? put the view in a proper position, then, add this into your css/custom.css
                                            .CX2 {
                                              width: 800px;
                                            Or any size you want.
                                            • 6
                                            • 24
                                            • 25
                                            • 4 / 25
