    MMM-CalendarExt2
    486 Posts 83 Posters 949.3k Views 83 Watching
      Mariba
      Hello,
      I’m really satisfied with this module. Thank you.
      Although, I’m facing an issue. I want to display two calendars in the same view and same scene. The calendars just won’t show. It works individually but not together.
      Replace My URL with the original url. Sorry for the indentations.
      My config:
      module: 'MMM-CalendarExt2',
      url: "My URL",
      url: "my URL",
      views: [
      title: "Calendar",
      mode: "daily", fromNow:2, slotCount:2,
      type: "row",
      position: "upper_third",
      calendars: ["Regular", "University"],
      scenes: [
      My CSS:
      body {
      /* .CX2 .slot .event {
      background: inherit;
       .CX2 .slot .slotHeader {
      background-color: inherit;
      text-transform: uppercase;
      font-size: 12px;
      font-family: "Roboto Condensed", Arial, helvetica, sans-serif;
      font-weight: 400;
      color: #999;
      .CX2 .event[data-calendar-name="Regular"] {
      border-left: #0098e9 solid;
      .CX2 .event[data-calendar-name="University"] {
      border-left: #60bb41 solid;
        mrmagoo_83
        Don’t you need to call out the view name the scene?
        • ? Offline
          A Former User @Mariba
          @Mariba
          Well, I haven’t inspected your code yet, but most of the cases, it would be maxItems issue of view. For the performance, default maxItems of view is set to 100. If your calendars might have many events, set that option to a bigger value. You can estimate the number needed with your serverside log.
          • BKeyportB Offline
            BKeyport Module Developer @Guest
            @Sean Neither of those are what I would want. No matter how many items I have, there is a space there. I want to rid myself of the excess blank space, so that I can fit more real items into the display. When the day is empty there is very little space between days.
              Mariba @Guest
              @Sean Hello,
              I tried with maxItems set to 10. I’m definitely sure that I dont have more than 8 items with the calendars combined. It still doesn’t solve the problem.
                mrmagoo_83
                How does one replace a parentheses in the title of an event?
                • BKeyportB Offline
                  BKeyport Module Developer @mrmagoo_83
                  @mrmagoo_83 Regex would be “\(” and “\)” to find both.
                  • ? Offline
                    A Former User @BKeyport
                    @BKeyport
                    • ? Offline
                      @Mariba
                      In that case, I should have real data to inspect.
                        mmmmh Project Sponsor
                        I have two views in one scene and need some layout/styling help. One row view shows the next 7 days and a column should show as many events as possible from 8 days onwards (a preview). For more precise placement, I created my own regions and added them to the index.html template.
                        The next-7-days daily view is at the bottom of the screen and behaves nicely. The preview column is in the center of the screen and regrettably runs over the next-7-days view.
                        In a daily column view, how can I skip days without events?
                        Which style element do I need to modify in custom.css to have the column content to stop at precise coordinates and not spill over other modules?
                        I tried limiting the region either with a bottom-margin or height value, both do not apply.
                        Here’s the style that doesn’t work
                        .region .preview {
                            border: 1px #831e4d solid;
                            position: absolute;
                            left: 480px;
                            width: 400px;
                            top: 390px;
                            height: 550px;
                        • ? Offline
                          A Former User @mmmmh
                          @mmmmh
                          1. Give your view className to control more precisely.
                            For example,
                            title: "Remove Empty Slot",
                            mode: "daily",
                            calendars: [],
                            position:"top_left",
                            hideOverflow: false,
                            slotCount: 7,
                            className: "remove_empty_slot"
                          Then modify your css/custom.css
                          .CX2 .remove_empty_slot .eventCount_0 {
                            display:none;
                            @Sean That works nicely for skipping days without events, thanks.
                            What can I do about the overlap of the content. I can’t limit the view height in the config file or in the class style.
                            • ? Offline
                              @mmmmh
                              can u tell me more details? even picture would be a help to understand your expect.
                              • BKeyportB Offline
                                @Sean You know, I was just wondering how to get rid of empty days. Thanks!
                                  mmmmh Project Sponsor @Guest
                                  @Sean said in MMM-CalendarExt2:
                                  @mmmmh
                                  Here’s an example (I disabled other modules).
                                  • ? Offline
                                    @mmmmh
                                    You can set hideOverflow:true and slotMaxHeight:100px. If your view has 5 slots(with column type), The height of the view will be (100 + @) * 5. @ would be some additional elements like some margins or title area. Anyway, with this calculation, you can adjust and estimate the height of the view somehow.
                                    Or you can put this 2 view in same position(bottom_bar?), in that case, the views will be stacked not overlapped. The order will be what you ordered in configuration.
                                    Or, just use another position like bottom_bar and top_right.
                                      @Sean
                                      Thanks for the constructive help. I was already using different positions. Stacking within the same position doesn’t really work:
                                      Slot limiting (and two different positions) seems to be (closer to) what I want to accomplish:
                                      Another workaround would probably be to work with separate instances of the module.
                                      • ? Offline
                                        @mmmmh
                                        In your picture (trial for stacking),
                                        You probably have trouble with styling a daily view. I think it is about the view’s location and width. In that case, you can assign className to control specific view details with CSS.
                                          @Sean
                                          Thanks for the remark. Stacking in the same position but with a different (additional) class for the column kinda works but there is still overlap (in this instance I am not limiting the slot height and count in the column, I would like to have as many entries as possible in the column):
                                            mmmmh Project Sponsor @mmmmh
                                            I found a workaround. I made the background of the lower part black. : )
                                            In the last screenshot Thu. 28 takes up so much space, even when I enable hideOverflow. I think have to remove some hardcoded 150px in .slotContent but I can’t get to it.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 24
                                            • 25
                                            • 7 / 25
