    Troubleshooting MagicMirror
    19 Posts 5 Posters 6.1k Views 4 Watching
    • O Offline
      OthTheGentel
      @Mykle1 Thank you for your answer.
        Mykle1 Project Sponsor Module Developer @OthTheGentel
        @oththegentel
        You’re welcome, mate.
        You might want to read this simple guide if you are unsure about adding modules to your config.js file.
        https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
        • O Offline
          OthTheGentel
          Is there any way to get an overview when I’m editing the config.js file
          I tried a web access to pi’s ip address and port from another computer on the same network but it’s not working even if i specified the ip address of pi in address section and allowed all ip addresses in ipwhitelist section!!
            @oththegentel
            This is not working for you?
            var config = {
            	address: "localhost",
            	port: 8080,
            	ipWhitelist: [],
            • O Offline
              OthTheGentel @Mykle1
              @mykle1 unfortunately not.
              I put the wlan0 ip address of my pi instead of localhost and it’s not working neither.
                @oththegentel
                Long shot:
                Try address: "0.0.0.0",
                • O Offline
                  @mykle1 Nope even locally
                  I’ll scan all my ports and check if 8080 is already used
                  D idoodlerI 2 Replies Last reply Reply Quote 0
                    dazza120 @OthTheGentel
                    @oththegentel enable VNC and patch in using that, I’m doing changes on my phone using that method it’s not the best given the screen size normally I do adjustments on the Mac when I can be bothered to boot it up, last minute changes are done on the phone.
                    • idoodlerI Offline
                      idoodler Module Developer @OthTheGentel
                      @oththegentel It sounds like your MagicMirror instance is not running.
                      How did you start MagicMirror, do you have pm2 installed?
