    HELP to use a cam with MM PLEASE
    19 Posts 6 Posters 10.0k Views 4 Watching
    • A
      axel
      I want to use my cam with magic mirror.
      I’ve bought 2 cams : an ip cam (SCS sentinel SVI0039 and an usb cam (Playstation eye 3)
      Can anyone help me? which modules should I use?
      Axel
      B Mykle1M 3 Replies Last reply Reply Quote 0
      • B
        bhepler Module Developer @axel
        @axel - Well, if you really want to use the camera, the basic module to use is MMM-Motion-Detection. This will turn the MagicMirror display off & on when it detects movement in front of the camera.
        I’m pretty sure there is a selfie module around here that will let you take pictures of yourself. If you really want to get advanced, there’s a facial recognition app that has been used with varying degrees of success.
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @axel
          @axel
          https://github.com/alexyak/camera will take selfies and send them to a host of email accounts and it’s written by the same author as the motiondetector module mentioned by @bhepler
            sdetweil
            and my MMM-SleepWake works with webcam for motion detection and Lucy for remembering which modules are hidden when waking by voice or movement
            and supports three different screen off approaches, tvservice (pi only) dpms (some monitors) and screen blanking(for auto power off devices, like TVs, EnergyStar)
            • Mykle1M
              @axel
              I would go with MMM-SleepWake because it’s a newer module and it’s fully supported by our friend, @sdetweil
              • A
                axel
                thank toi guys for your answers but what i want is to see my usb cam in live on the mirror! is there a module for that please?
                ? S 2 Replies Last reply Reply Quote 0
                  A Former User @axel
                  @axel
                  If your webcam has IP or URL address to stream video output, MMM-RTSP… or some iFrame modules could work.
                    shbatm Module Developer @axel
                    @axel said in HELP to use a cam with MM PLEASE:
                    If you can get an RTSP stream URL from your IP camera you can use my module: MMM-RTSPStream. Use the develop branch right now–and search this forum if you’re having issues getting it to work.
                    If you want to stream your USB camera by hooking it up to the Pi, you can look at something like mjpg-streamer (Google ‘OctoPrint mjpg-streamer setup’ for some good guides) and then use MMM-iframe to show the image.
                    • A
                      axel @shbatm
                      @shbatm
                      i try to use mjpg_streamer :
                      $ mjpg_streamer -o “output_http.so -w ./www” -i “input_uvc.so -f 1 -q 75 -y”
                      but i have this error : bind:Address already in use.
                      also : Innappropriate ioctl for device (25)
                      help!
                        The default port is the same as the Mirror, 8080. Try adding -p 8081 to your command to change the port.
                        A 2 Replies Last reply Reply Quote 0
                        • A
                          axel @shbatm
                          This post is deleted!
                          • A
                            axel @shbatm
                            @shbatm
                            it works well but now i tried To start mjpg on boot in vain. I used the crontab but how To write it with the options??
                            • B
                              @axel - Create a script with your command, name it something obvious like startcam.sh. Make it executable with chmod +x startcam.sh and then use pm2 to autostart and maintain the script: pm2 start startcam.sh When you’re satisfied with pm2’s handling, save the state: pm2 save
                              In the future, please use the markdown features of the board when posting code & logs.
                              • A
                                axel @bhepler
                                @bhepler
                                i did it but the status is not online but stopped. After a moment, the status changed To errored!! Help please…
                                • B
                                  @axel - Okay. Let’s skip PM2 for now and just concentrate on getting your script running.
                                  Edit the startcam.sh script and paste in the mjpg_streamer command:
                                  mjpg_streamer -o “output_http.so -w ./www” -i “input_uvc.so -f 1 -q 75 -y” -p 8081
                                  Once you have the script file to where it’s only that command, you can try to run that script manually by typing ./startcam.sh. That should be the equivalent of typing the command in yourself.
                                  Try that and let us know how it goes.
                                  • A
                                    axel @bhepler
                                    @bhepler
                                    Ok i can run manually the script.
                                    and now?
                                    S B 2 Replies Last reply Reply Quote 0
                                      sdetweil @axel
                                      he left off that you need to mark the script as executable
                                      chmod +x ./startcam.sh
                                      • A
                                        axel @sdetweil
                                        i did it before 😉
                                        • B
                                          @axel - Now that you can run your script and have it execute the command (I’m assuming that when you run the script, it does what you want) you just have to tell pm2 to manage that script.
                                          Tell pm2 to manage the script: pm2 start startcam.sh
                                          Tell pm2 to remember & autostart the script: pm2 save
                                          Let us know how it goes.
