    Raspbian Stretch: Screen is always blanked
    displayingblankblack screenraspbian
    2 Posts 2 Posters 1.9k Views 2 Watching
    • A
      a-i-ks
      Hello folks,
      I can’t get my RaspberryPi 2b with Raspbian Stretch to leave the display on permanently. I followed this instructions from GitHub and added the lines mentioned in the instruction to the files
      (I had to create the file and the path to the file “~/.config/lxsession/LXDE-pi/autostart”)
      I just found out that the location of the autostart file has changed: “/etc/xdg/lxsession/LXDE-pi/autostart”
      Raspbian still seems to turn off the display. MagicMirror still runs without problems. The logfile shows no errors and the website is accessible via (IP of the Raspberry):8080 and shows all modules there.
      Do you have any idea how I could proceed to troubleshoot?
      Greetings, André
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @a-i-ks
        @a-i-ks
        Personally, I would install xscreensaver and use that to disable the screensaver.
        In your terminal
        sudo apt-get install xscreensaver
        THEN
        sudo reboot
        Run xscreensaver. Choose Disable Screensaver. Done.
