    New Install From Raspbian Stretch
    raspberry pi 3raspbian stretch
    14 Posts 4 Posters 6.6k Views 4 Watching
      sebien0077
      II wanted to take everything back to 0. But the installation does not work anymore.
      I would have to do it again, I think.
      I know it’s a problem of addiction, but I still can not do it:
      At the first install :
      pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/MichMic        h/MagicMirror/master/installers/raspberry.sh)"
      $$$\    $$$ |                    \__|          $$$\    $$$ |\__|        $$  __$$\
      $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$        $\   $$$$$$\   $$$$$$\  \__/  $$ |
      $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __        $$\ $$  __$$\ $$  __$$\  $$$$$$  |
      $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |        \__|$$ /  $$ |$$ |  \__|$$  ____/
      $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |        $$ |  $$ |$$ |      $$ |
      $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |        \$$$$$$  |$$ |      $$$$$$$$\
      \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|        \______/ \__|      \________|
                              \______/
      Updating packages ...
      Réception de:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15,0        kB]
      Atteint:2 http://archive.raspberrypi.org/debian stretch InRelease
      15,0 ko réceptionnés en 0s (15,4 ko/s)
      Lecture des listes de paquets... Fait
      Installing helper tools ...
      Construction de l'arbre des dépendances
      Lecture des informations d'état... Fait
      build-essential is already the newest version (12.3).
      curl is already the newest version (7.52.1-5+deb9u8).
      git is already the newest version (1:2.11.0-3+deb9u4).
      unzip is already the newest version (6.0-21).
      wget is already the newest version (1.18-5+deb9u2).
      0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
      Check current Node installation ...
      Node currently installed. Checking version number.
      Minimum Node version: v5.1.0
      Installed Node version: v8.11.1
      No Node.js upgrade necessary.
      Cloning MagicMirror ...
      Clonage dans 'MagicMirror'...
      remote: Enumerating objects: 302, done.
      remote: Counting objects: 100% (302/302), done.
      remote: Compressing objects: 100% (270/270), done.
      remote: Total 302 (delta 37), reused 170 (delta 22), pack-reused 0
      Réception d'objets: 100% (302/302), 614.30 KiB | 0 bytes/s, fait.
      Résolution des deltas: 100% (37/37), fait.
      Cloning MagicMirror Done!
      Installing dependencies ...
      bash: ligne 112: npm : commande introuvable
      After, i have instaled npm:
      pi@raspberrypi:~ $ sudo apt-get install npm
      but when i try again :
      pi@raspberrypi:~ $ cd MagicMirror/
      pi@raspberrypi:~/MagicMirror $ npm install
      (node:8666) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpd        ir() instead.
      npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically un        maintained. Move on to something better. This package will continue to work with        Grunt v1, but it will not receive any updates.
      npm WARN deprecated express-ipfilter@0.3.1: This package is no longer being main        tained and contains security vulnerabilities
      npm ERR! Error: Method Not Allowed
      npm ERR!     at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
      npm ERR!     at /usr/share/npm/lib/cache/add-named.js:203:12
      npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
      npm ERR!     at FSReqWrap.oncomplete (fs.js:135:15)
      npm ERR! If you need help, you may report this *entire* log,
      npm ERR! including the npm and node versions, at:
      npm ERR!     <http://github.com/npm/npm/issues>
      npm ERR! System Linux 4.14.79-v7+
      npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install"
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v8.11.1
      npm ERR! npm -v 1.4.21
      npm ERR! code E405
      npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
      > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      successfully dowloaded and extracted!
      npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
      npm WARN deprecated browserslist@2.11.3: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
      npm ERR!
      npm ERR! not ok code 0
        sdetweil
        Node is downlevel.
        See
        node -v
          sebien0077
          OK, i have forced upgrade node with this command:
          curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
          I install Node:
          sudo apt install -y nodejs
          now node version :
          pi@raspberrypi:~/MagicMirror $ node -v
          v10.15.0
          I have remove MagicMirror folder, and reinstall from the beginning:
          pi@raspberrypi:~ $ rm -rf MagicMirror/
          pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
          All seem OK, but they are vulnerabillity…
          > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
          > electron@2.0.16 postinstall /home/pi/MagicMirror/node_modules/electron
          > node install.js
          Downloading SHASUMS256.txt
          [============================================>] 100.0% of 5.39 kB (5.39 kB/s)
          > magicmirror@2.6.0 install /home/pi/MagicMirror
          > cd vendor && npm install
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          added 82 packages from 57 contributors and audited 220 packages in 15.326s
          found 3 low severity vulnerabilities
            run `npm audit fix` to fix them, or `npm audit` for details
          > magicmirror@2.6.0 postinstall /home/pi/MagicMirror
          > sh installers/postinstall/postinstall.sh && npm run install-fonts
          MagicMirror installation successful!
          > magicmirror@2.6.0 install-fonts /home/pi/MagicMirror
          > cd fonts && npm install
          added 1 package from 1 contributor and audited 1 package in 3.955s
          found 0 vulnerabilities
          npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
          added 921 packages from 1366 contributors and audited 2466 packages in 170.898s
          found 8 vulnerabilities (7 low, 1 high)
          Dependencies installation Done!
          Check plymouth installation ...
          Splashscreen: Checking themes directory.
          Splashscreen: Create theme directory if not exists.
          Splashscreen: Theme copied successfully.
          Splashscreen: Changed theme to MagicMirror successfully.
            sdetweil @sebien0077
            @sebien0077
            run
            npm audit fix
              sebien0077 @sdetweil
              yes i have made , only one resist :
              pi@raspberrypi:~/MagicMirror $ npm audit
                                     === npm audit security report ===
              │                                Manual Review                                 │
              │            Some vulnerabilities require your attention to resolve            │
              │         Visit https://go.npm.me/audit-guide for additional guidance          │
              │ Low           │ Prototype Pollution                                          │
              │ Package       │ lodash                                                       │
              │ Patched in    │ >=4.17.5                                                     │
              │ Dependency of │ express-ipfilter                                             │
              │ Path          │ express-ipfilter > lodash                                    │
              │ More info     │ https://nodesecurity.io/advisories/577                       │
              S lavolp3L 2 Replies Last reply Reply Quote 0
                @sebien0077
                npm i lodash@latest
                  dazza120
                  Hi guys instead of me starting a new thread for the same thing can I jump in as it seems the last thing may have fixed OP’s issue, I have two vulnerabilities that are not fixing ate all 😢 can you help please I’ve tried the npm I lodash@latest but that doesn’t work
                                         Manual Review                                 │
                  │ Moderate      │ Regular Expression Denial of Service                         │
                  │ Package       │ underscore.string                                            │
                  │ Patched in    │ >=3.3.5                                                      │
                  │ Dependency of │ fix                                                          │
                  │ Path          │ fix > underscore.string                                      │
                  │ More info     │ https://npmjs.com/advisories/745                             │
                  │ More info     │ https://npmjs.com/advisories/577
                  • lavolp3L Offline
                    lavolp3 Module Developer
                    Guys be careful with the npm vulnerabilities!
                    It’s not advisable to always fix all of them.
                    E.g. if a vulnerability wants to have a most recent version of an important dependency, fixing it might even break your working MM because MM can’t work with this new dependency.
                    If you’re not completely sure what you’re doing then leave them.
                    They are not errors after all, your modules should work with these vulnerabilities as well.
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                    D 1 Reply Last reply Reply Quote 2
                      dazza120 @lavolp3
                      @lavolp3 understood thanks ill leave well alone now then thanks
                      • lavolp3L Offline
                        lavolp3 Module Developer @sebien0077
                        @sebien0077 better leave lodash alone is my suggestion. YOur mirror should work with this vulnerability as well.
                        HOwever, you can of course try it out IF YOU DARE!!!
                        Go on the presented link and do as suggested.
                        npm install lodash@4.17.5
                        (that’s what I would try)
                          sebien0077 @lavolp3
                          @lavolp3 said in New Install From Raspbian Stretch:
                          Thx for your help. I just don’t like vulnerability :)
                          i have try 4.17.5 and 4.17.11 … nothing work :(
                          pi@raspberrypi:~/MagicMirror $ npm install lodash@4.17.5
                          + lodash@4.17.5
                          updated 1 package and audited 4407 packages in 42.128s
                          found 1 low severity vulnerability
                          pi@raspberrypi:~/MagicMirror $ npm audit fix
                          up to date in 31.654s
                          fixed 0 of 1 vulnerability in 4407 scanned packages
                            1 vulnerability required manual review and could not be updated
                          │                                Manual Review                                 │
                          found 1 low severity vulnerability in 4407 scanned packages
                            1 vulnerability requires manual review. See the full report for details.
                          pi@raspberrypi:~/MagicMirror $ npm install lodash@4.17.11
                          + lodash@4.17.11
                          updated 1 package and audited 4407 packages in 39.671s
                          up to date in 32.389s
                          │                                Manual Review                                 │
                            sdetweil
                            as you will be the only user of the app (in your house, no public consumers, not open to internet)…
                            the vulnerabilities really don’t matter…
                            • lavolp3L Offline
                              @sebien0077 Have you done a reboot? I hear they can do wonders!
                                sebien0077 @lavolp3
                                @lavolp3 yes, a lot of time ^^
