    MMM Remote Controle - starting issus
    13 Posts 3 Posters 5.8k Views 3 Watching
    • E Offline
      Ernst-Jan
      Is there a way to see whats wrong with the config of your last module.
      My last module is remote controle.
      I have set address: 0.0.0.0, and ipWhitelist: [],
      module: ‘MMM-Remote-Control’
      // uncomment the following line to show the URL of the remote control on the mirror
      position: ‘bottom_left’
      // you can hide this module afterwards from the remote control itself
      When i start with pm2 start mm i see only this error. When i remove te module MM start normal.
      0|mm | Starting MagicMirror: v2.6.0
      0|mm | Loading config …
      0|mm | WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
      0|mm | Loading module helpers …
      0|mm | Initializing new module helper …
      0|mm | Module helper loaded: updatenotification
      0|mm | No helper found for module: helloworld.
      0|mm | All module helpers loaded.
      0|mm | Starting server on port 8080 …
      0|mm | Server started …
      0|mm | Connecting socket for: updatenotification
      0|mm | Sockets connected & modules started …
      0|mm | Launching application.
      S E 2 Replies Last reply Reply Quote 0
        sdetweil @Ernst-Jan
        @ernst-jan do
        npm start dev
        Then select the console tab of the developers environment, and look for any errors (red text)
        • E Offline
          Ernst-Jan @Ernst-Jan
          @ernst-jan
          npm ERR! missing script: start
          npm ERR! /home/pi/.npm/_logs/2019-01-31T17_06_55_736Z-debug.log
            sdetweil @Ernst-Jan
            @ernst-jan in the magic mirror folder
            • E Offline
              @ernst-jan said in MMM Remote Controle - starting issus:
              npm/logs
              1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’, ‘dev’ ]
              2 info using npm@5.6.0
              3 info using node@v9.11.2
              4 verbose stack Error: missing script: start
              4 verbose stack at run (/usr/lib/node_modules/npm/lib/run-script.js:151:19)
              4 verbose stack at /usr/lib/node_modules/npm/lib/run-script.js:61:5
              4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:115:5
              4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:402:5
              4 verbose stack at checkBinReferences
              (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:357:45)
              4 verbose stack at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:400:3)
              4 verbose stack at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:160:5)
              4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:348:12
              4 verbose stack at /usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:78:16
              4 verbose stack at FSReqWrap.readFileAfterClose [as oncomplete] (fs.js:525:3)
              5 verbose cwd /home/pi/.local/share/Trash/files/MMM-Remote-Control/MMM-Remote-Control
              6 verbose Linux 4.14.79-v7+
              7 verbose argv “/usr/bin/node” “/usr/bin/npm” “start” “dev”
              8 verbose node v9.11.2
              9 verbose npm v5.6.0
              10 error missing script: start
              11 verbose exit [ 1, true ]
              • E Offline
                Ernst-Jan
                @sdetweil said in MMM Remote Controle - starting issus:
                npm start dev
                /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js
                  sdetweil @Ernst-Jan
                  @ernst-jan don’t understand your reply.
                  From the MagicMirror folder do
                  npm start dev
                  Then as per my previous instructions
                  • E Offline
                    Ernst-Jan
                    Loading config …
                    Server started …
                    Whoops! There was an uncaught exception…
                    { Error: listen EADDRINUSE 127.0.0.1:8080
                    at Object._errnoException (util.js:1024:11)
                    at _exceptionWithHostPort (util.js:1046:20)
                    at Server.setupListenHandle [as _listen2] (net.js:1351:14)
                    at listenInCluster (net.js:1392:12)
                    at GetAddrInfoReqWrap.doListen [as callback] (net.js:1501:7)
                    at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:97:10)
                    code: ‘EADDRINUSE’,
                    errno: ‘EADDRINUSE’,
                    syscall: ‘listen’,
                    address: ‘127.0.0.1’,
                    port: 8080 }
                    main.js:343 Config file is missing! Please create a config file.
                    loadConfig @ main.js:343
                    19:03:05.148
                      sdetweil @Ernst-Jan
                      @ernst-jan it is already running. Need to stop it before starting again
                        sdetweil @Ernst-Jan
                        @ernst-jan and syntax errors
                        From mm folder do
                        node tests/configs/check_config.js
                        Start at the top and correct errors reported, rerun til no errors, then do the npm start again
                          robiv8
                          i am missing a semilicon
                          type this
                          , position: ‘bottom_left’
                            sdetweil @robiv8
                            @robiv8 two close brace, only one open
                            Comma Missing after the module line
                              robiv8
                              @robiv8 said in MMM Remote Controle - starting issus:
                              You are right! 1 close brace are to much
                              And comma missing:
                              This
                              or this
                                              module: ‘MMM-Remote-Control’,
                              is the same.
