    [MMM-MusicOnDemand] - Play music from deezer with a browser in the background
    16 Posts 5 Posters 14.5k Views 5 Watching
    • P
      ptrk95 Module Developer
      Description:
      This module allows you to play music from Deezer with puppeteer. That means you need at least a free account from Deezer. It is meant to be used with a speech recognition module like MMM-AssistantMk2, but it should work with other modules as long as you send the correct notifications as described in de README of the project.
      It acutally plays the music on the machine this module is running on. So you don't have to use a other device to play music with a music on demand service e.g. on Raspberry Pi.
      Enjoy :)
      Screenshots:
      alt text
      Download:
      GitHub
      Version 1.01
      • Force installs puppeteer v1.11.0
      Version 1.0
      • Initial Release, confirmed working on Raspberry Pi 3b+
      Cr4z33C 2 Replies Last reply
      • Cr4z33C
        Cr4z33 @ptrk95
        @ptrk95 yes finally a Deezer module and what is great is that it’s standalone THANKS! :smiling_face_with_heart-eyes:
        • Cr4z33C
          Cr4z33 @ptrk95
          @ptrk95 getting a black screen when I launch MagicMirror no matter if I use default Chromium or puppeteer.
          Actually I was going now to delete the puppeteer package, but it wasn’t installed at all. :thinking_face:
          Running everything on a Raspberry Pi 3 B+.
          • P
            Thanks for pointing that out! The dependencies in the package.json weren’t set. I uploaded a changed version but unfortunatley this build won’t work for me right now, so I have to do a deeper look into it.
            Edit: It`s again working on the new build, was a problem with the puppeteer version and the chromium version installed on raspbian.
            Cr4z33C 1 Reply Last reply
            • Cr4z33C
              Cr4z33 @ptrk95
              @ptrk95 it keeps displaying a black screen.
              This is my config section for this module:
              			module: "MMM-MusicOnDemand",
              			disabled: false,
              				chromiumPath : "/usr/bin/chromium-browser",
              				// chromiumPath : null,
              				showCover : true,
              				email : "****",
              				password : "****",
              and this is the MM dev log:
              pi@raspberrypi:~/MagicMirror $ npm start dev
              > magicmirror@2.6.0 start /home/pi/MagicMirror
              > sh run-start.sh "dev"
              Starting MagicMirror: v2.6.0
              Loading config ...
              Loading module helpers ...
              Module helper loaded: MMM-Remote-Control
              Module helper loaded: MMM-AssistantMk2
              Module helper loaded: MMM-PushBulletNotifications
              WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'puppeteer'
              App threw an error during load
                  at Module._resolveFilename (module.js:543:15)
                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                  at Function.Module._load (module.js:473:25)
                  at Module.require (module.js:586:17)
                  at require (internal/module.js:11:18)
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_helper.js:4:19)
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_helper.js:310:3)
                  at Module._compile (module.js:642:30)
                  at Object.Module._extensions..js (module.js:653:10)
                  at Module.load (module.js:561:32)
              { Error: Cannot find module 'puppeteer'
                  at Module.load (module.js:561:32) code: 'MODULE_NOT_FOUND' }
              Launching application.
              • P
                That’s strange.
                Try cd in the MusicOnDemand folder and then:
                npm install puppeteer@1.11.0
                • Cr4z33C
                  Cr4z33 @ptrk95
                  @ptrk95 but then why should I need puppeteer if we have already Chromium installed in the Pi? :confused_face:
                  P 1 Reply Last reply
                  • P
                    ptrk95 Module Developer @Cr4z33
                    @cr4z33 with puppeteer you can control the browser with Javascript. But it will install a version of chromium inside the puppeteer folder which you can delete to save space if you use the preinstalled chromium of raspbian :)
                    • Cr4z33C
                      Cr4z33 @ptrk95
                      @ptrk95 OK thanks now MM is loading properly, but yout module keeps saying ‘Initializing…’ and nothing happens. :grimacing_face:
                      This is the error in log:
                      Error: Failed to launch chrome!
                      TROUBLESHOOTING: https://github.com/GoogleChrome/puppeteer/blob/master/docs/troubleshooting.md
                          at onClose (/home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/lib/Launcher.js:342:14)
                          at ChildProcess.helper.addEventListener (/home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/lib/Launcher.js:332:60)
                          at emitTwo (events.js:131:20)
                          at ChildProcess.emit (events.js:214:7)
                          at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                      • P
                        @cr4z33 that’s most likely a versioning problem with puppeteer and chromium.
                        I assume you already did:
                        cd ~/MagicMirror/modules/MMM-MusicOnDemand
                        Please check your chromium version. My version is the latest one: version 65.0.3325.181.
                        If it’s not, try:
                        sudo apt-get install chromium-browser
                        And check that your chromium path in the config file is “/usr/bin/chromium-browser”, which I guess it is. Because on Raspberry Pi the browser of puppeteer isn’t working.
                        If that’s also not launching your browser I honestly don’t know why :/
                        In the latest build I added the option “showBrowser” in the config-file. If you set it to true, you are able to see the browser and what it is doing in the browser.
                        • Cr4z33C
                          Cr4z33 @ptrk95
                          @ptrk95 did everything you said, browser version is the same, added that config line, but the module keeps sitting at the ‘Initializing…’ word.
                          If I can’t do anything else maybe someone here is willing to contribute? :man_shrugging_medium_skin_tone:
                          • Cr4z33C
                            Cr4z33 @ptrk95
                            @ptrk95 tried to give your module another try, but if I try using the (latest) default Chromium browser it keeps sitting at the ‘Logging into deezer’ text and if I try using Puppeteer I get this:
                            /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: 18: /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: ?Udmv~�����������: not found
                            /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: 1: /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: �
                            @8
                              @,*@@@hh���,+r,+r0r0r0r: not found
                            /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: 1: /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: ELF: not found
                            /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: 19: /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: Syntax error: ")" unexpected
                                at Interface.helper.addEventListener (/home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/lib/Launcher.js:331:50)
                                at emitNone (events.js:111:20)
                                at Interface.emit (events.js:208:7)
                                at Interface.close (readline.js:370:8)
                                at Socket.onend (readline.js:149:10)
                                at Socket.emit (events.js:208:7)
                                at endReadableNT (_stream_readable.js:1056:12)
                                at _combinedTickCallback (internal/process/next_tick.js:138:11)
                            • ejay-ibmE
                              ejay-ibm Project Sponsor Module Developer
                              Fantastic !
                              I’m preparing as well a stand alone module to control spotify with the mk2 assistant as well . I should be able to release and share in a couple of days . I just need to fix one big bug and it will be OK .
                              Thanks for your module We will have all we need to control music with our mirror !
                              so cool
                              Ejay
                              F 1 Reply Last reply
                              • F
                                F17MC @ejay-ibm
                                @ejay-ibm said in [MMM-MusicOnDemand] - Play music from deezer with a browser in the background:
                                Fantastic !
                                so cool
                                Ejay
                                Wow! That is fantastic!
                                I have a question. I’m living in Spain, and I’m using a Spotify account from other country.
                                All works fine, and I don’t need VPN to play my music.
                                Do you think that I could be able to use my Spotify account with your module?
                                Thanks!
                                • Cr4z33C
                                  Cr4z33 @F17MC
                                  @F17MC mate imho you should contact him in private chat.
                                  This is a topic about a Deezer module and from another developer after all. :winking_face:
                                  • D
                                    dodol45
                                    can’t stop music with MMM-assistantMk2, can’t input any command after music playing, anyone know how to solve it ?
