    MMM-Globe
    119 Posts 39 Posters 221.5k Views 40 Watching
    • P Offline
      Peter @iMAGiC
      @iMAGiC , I used your link: MM starts, I see half of the globe and MM stops, starts again with half of the globe and stops again; like a loop.
      Maybe because I use a RPI 2?
      Peter
      iMAGiCI 1 Reply Last reply Reply Quote 0
      • P Offline
        Peter @dasbooter
        @dasbooter , what link do you use?
        peter
        • PimagicalP Offline
          Pimagical @Peter
          @Peter I fixed this problem with improving my wifi signal/range!
          Check your wifi signal quality if around 37/70 this will cause problems for sure, it should be at least above 45/70 or higher check your signal with:
          sudo iwconfig wlan0
          My bad wifi signal caused problems like not loading the globe images and freezing agenda items and not loading the newsfeed items.
          Solutions are
          1. Change the accespoint location or
          2. Buy a WIFI USB adapter to improve the wifi range because the Pi 3 default wifi/bluetooth is very bad: Pi 3 Wifi problems or
          3. DIY Modification option External antenna modifications for the Raspberry :Pi 3
          Good Luck!
          • iMAGiCI Offline
            iMAGiC @Peter
            @Peter do you set updateInterval correctly?
            btw, I use Pi 3 with LAN.
            only thing is loading time is longer, but OK.
            Choice * Judgment * Values
            • P Offline
              Peter
              Wifi signal is 49/70.
              I use the original update interval.
              Peter
              • iMAGiCI Offline
                iMAGiC @Peter
                @Peter I think there is a problem, but not link I provided. may you check others, it shouldn’t cause MM stop or restart.
                • P Offline
                  Peter
                  I rest my case.
                  I can’t get it working the way I want.
                  Thanks everybody for your help.
                  Peter
                  • FlatPepsiF Offline
                    FlatPepsi
                    For those seeking North American globe views, I have great news - GEOS-16 (aka GEOS-East) is now publishing live color (yes, COLOR) images!
                    See web site here:
                    https://www.star.nesdis.noaa.gov/GOES/GOES16_FullDisk.php
                    There are a few links for the latest image, depending on the resolution you want. (Watch out -many of the web site’s URLs are date and time specific) I’m using: https://cdn.star.nesdis.noaa.gov/GOES16/ABI/FD/GEOCOLOR/678x678.jpg
                    Until a proper GIT update is done on this module, you can edit your setup to get this new image. In the folder:
                    /home/pi/MagicMirror/modules/MMM-Globe
                    Edit the file: MMM-Globe.js
                    Find the lines with ‘centralAmericaDiscNat’: , and put the new URL in there. In my case, I used:
                    		'centralAmericaDiscNat': 'https://cdn.star.nesdis.noaa.gov/GOES16/ABI/FD/GEOCOLOR/678x678.jpg'
                    Do note that the code has 2 sections for different resolutions- you may need to update both.
                    Enjoy!
                    pugslyP 1 Reply Last reply Reply Quote 1
                    • pugslyP Offline
                      pugsly @FlatPepsi
                      @flatpepsi said in MMM-Globe:
                      centralAmericaDiscNat’: 'https://cdn.star.nesdis.noaa.gov/GOES16/ABI/FD/GEOCOLOR/678x678.jpg
                      I put the URL above for high res but since I only use 200px use this url for low res
                      https://cdn.star.nesdis.noaa.gov/GOES16/ABI/FD/GEOCOLOR/thumbnail.jpg
                      • C Offline
                        chris1971
                        MMM Globe - The Image Gallery has moved!
                        Hi has anybody solved the issues with the MMM Globe.
                        I am using MMM Globe, but the pictures/ jpgs are not longer available on the EUMETSAT server. Does anybody have a solution?
                        Thx, Chris
                        • StoffbeuteluweS Offline
                          Stoffbeuteluwe Project Sponsor @chris1971
                          @chris1971 try the link of the new path in…
                          ownpath: “link of new path“
                          in MMM-Globe config…
                          • C Offline
                            chris1971
                            … could you please explain more in detail…
                            Thanks, Chris
                              I’ll contact you later when I’m at home
                              • C Offline
                                chris1971
                                would be great!!!
                                  @chris1971
                                              module: 'MMM-Globe',
                                              position: 'middle_center',
                                              style: 'europeDiscNat',
                                              imageSize: 600,
                                              ownImagePath:'https://eumetview.eumetsat.int/static-images/MSG/RGB/NATURALCOLOR/FULLRESOLUTION/IMAGESDisplay/VazIBqHF9k665',
                                              updateInterval: 10*60*1000
                                  I hope this ok for you…
                                    Stoffbeuteluwe Project Sponsor @Stoffbeuteluwe
                                    @Stoffbeuteluwe ist that ok?
                                    • C Offline
                                      chris1971
                                      Great!!!
                                      It’s working with the link… where did you find it?
                                      Regards, Christoph
                                        @chris1971 this is the link from the picture of the Earth on the eumesat webpage…
                                        • C Offline
                                          chris1971
                                          yes - and now I still have the question if the picture will be updated automatically. With the old configuration (on the EUMETSAT server) I got a new picture every 15 minutes…
                                            @chris1971 i hope so
                                            • 6
                                            • 5 / 6
