    Hello Lucy: got Sleep
    8 Posts 3 Posters 2.5k Views 3 Watching
      mash55
      I am running mm on a pi with HDMI monitor. Hello Lucy is in charge. Config file includes:
      standByMethod: "PI"
      Telling Lucy to goto sleep gives me a black screen but monitor is not turned off. My goal is that monitor goes to power saving mode which I think can be achieved with a:
      tvservice -o
      command. This command should be used with the standByMethod=PI option in the config file (according to the github doc) but it seems it is not. Looking at the node_helper.js file in the ‘MMM-voice replacement files’ section it seems that this option is commented out.
      Is that an oversight? Or is this function defined somewhere else?
      Thanks for any pointers…
        sdetweil @mash55
        @mash55 Yes, Mykle changed it for his setup to use the dpms commands…
        you will have to uncomment the lines u need and comment out the exec('xset dpms…) commands just before each
        we have an update waiting on some MMM-Voice changes that makes this more configurable…
        M Mykle1M 2 Replies Last reply Reply Quote 1
          mash55 @sdetweil
          @sdetweil Thanks Sam… works now :)
            @sdetweil said in Hello Lucy: got Sleep:
            Dagnabit! Did I change it after I accepted your PR? Honestly, I thought it was a working config option. If I did inadvertently mess that up I will change it back. Please let me know Sam.
              sdetweil @Mykle1
              @mykle1 it was like that when I forked your repo…
                Facetious resposnse:
                Well, why didn’t you fix it? ;-)
                Immediate reaction:
                Doh! Well I feel stupid. :thumbsup:
                  sdetweil @Mykle1
                  @mykle1 said in Hello Lucy: got Sleep:
                  I did in my fork! which I submitted back as PR, but we haven’t promoted it yet, cause waiting for MMM-Voice
                    Ahhh, right. I knew that. :-)
