    Can't connect to MMM-Admin-Interface
    2 Posts 2 Posters 1.0k Views 2 Watching
    • H Offline
      HCoyle
      Yes, I am a NOOB. But I do have some programming background. I recently installed MM 2.6.0 on a pi 3B+. Additionally, I installed the MMM-Admin-Interface module. While logged in via VNC to the pi, the program works fine. However, if I try to access the mirror on another computer (http://192.168.1.19:8080/MMM-Admin-Interface) I get the above mentioned error. My config file is pretty straightforward. I have tried every option that I have found, but still no luck. My .PM2 log has no errors. Any suggestions would be appreciated.
      The following is from my config.js file.
      var config = {
      address: "",
      // address: “127.0.0.1”, // Address to listen on, can be:
      // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
      // - “”, “0.0.0.0”, “::” to listen on any interface
      // Default, when address config is left out, is “localhost”
      port: 8080,
      address: [“0.0.0.0”],
      // ipwhitelist: [“192.168.1.9”,“::1”],
      ipwhitelist: [],
      // ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
        Mykle1 Project Sponsor Module Developer @HCoyle
        @HCoyle said in Can't connect to MMM-Admin-Interface:
        Try
        address: "0.0.0.0",
        Note: Only one entry for address. It appears you have two.
