    MMM-AI
    Scheduled Pinned Locked Moved Fun & Games
    19 Posts 7 Posters 12.0k Views 10 Watching
    • justjim1220J Offline
      justjim1220 Module Developer @ejay-ibm
      @ejay-ibm
      Would it be possible for the user to change the avatar to their personal likeness?
      For example, be able to use a family member’s face, or an actor/actress, a cartoon character, etc. ?
      Or like the HAL2000, maybe the Alexa bar or circle animations?
      Jim Hallock - 1995
        @ejay-ibm
        I would be interested in Max Headroom, with his tourette-style glitches included!!!
        Jim Hallock - 1995
          @ejay-ibm
          You might be interested in the following links:
          https://avatarsdk.com/?_ga=2.125796682.1526809898.1553040863-987282811.1553040863
          https://api.avatarsdk.com/samples/web/#
          Jim Hallock - 1995
          ejay-ibmE T 2 Replies Last reply Reply Quote 0
          • ejay-ibmE Offline
            ejay-ibm Project Sponsor Module Developer @justjim1220
            @justjim1220
            Yes everything is possible .
            It’s just different gif ani .
            So you can make gif with your family members from a video and convert it to gif .
            I’m using crazy head to transform a static picture into a moving / talking avatar .
            Then some photoshop to finalize the gif.
            Ejay
            • T Offline
              teitlebot @ejay-ibm
              @ejay-ibm Thanks
              I would like to implement it a bit different.
              I would like no image unless the mirror is called.
              I found a trigger “ASSISTANT_RESPONSE_END : this notification will be bursted when Assistant’s voice responsing is ended.”
              I just dont know what code I need to put to make the image not appear other than putting a blank gif file. I assume there is a proper code.
              ejay-ibmE 1 Reply Last reply Reply Quote 0
              • T Offline
                teitlebot @justjim1220
                @justjim1220 This is amazing
                I was able to use the sample and also make an account but I cant figure how to get a gif from it to use in Magic Mirror. Any ideas?
                • ejay-ibmE Offline
                  ejay-ibm Project Sponsor Module Developer @teitlebot
                  @teitlebot You need to export as a movie, Then make an import as frame in photoshop
                  This will give you an idea
                  https://graphicdesign.stackexchange.com/questions/46656/how-to-convert-a-video-file-into-an-animated-gif-in-photoshop
                  Ejay
                  • ejay-ibmE Offline
                    @teitlebot I would use a black pixel image as no image
                    you can find all you need here
                    https://github.com/aureooms/pixels
                    Ejay
                    • T Offline
                      teitlebot @ejay-ibm
                      @ejay-ibm thanks. I figured there was a proper way to code a picture to be gone but this will work I guess. Thanks
                      • T Offline
                        teitlebot @teitlebot
                        @teitlebot @Sean Any idea how I can get it to fade the face on and off from the black pixel?
