    NOAA v3 using too many requests?
    28 Posts 4 Posters 12.7k Views 4 Watching
      motdog
      I’m not sharing a key as far as I know. My usage just skyrocketed which was surprising. I switched from dark sky to another provider & all is well. Tomorrow I’ll get a new key from darksky and see what happens. Just seemed weird to me
        Mykle1 Project Sponsor Module Developer @motdog
        @motdog
        Yeah, that’s a good idea. Let us know the result with the new key.
          motdog @Mykle1
          So the weather with weather underground hasn’t updated since yesterday. I looked at my stats and they were super high for yesterday. Seems the same as what happened before. Weird that random days trigger high requests.0_1552586737919_weather.PNG
          Any thoughts? I’m going to switch back to darksky api to see what happens.
          S Mykle1M 2 Replies Last reply Reply Quote 0
            sdetweil @motdog
            @motdog weather underground has been shutting down keys for over a year now. No new free keys are available. Time to switch to another weather solution.
              motdog @sdetweil
              @sdetweil Thanks for the heads up. Still curious about the spike in requests. Had that with darksky too which is why I switched to weather underground.
                dazza120 @motdog
                @motdog I had the same! Have you got a raspberry Pi? And is it locking up? I had this on mine it just kept dailing every second it was mad! Took off my Overclock that I had on the Pi and it’s working V well at the mo.
                  @motdog
                  I’m just curious (and I may have missed this) but have you changed the updateInterval: 30 * 60 * 1000, This is designed to constrain the module to 48 calls per day. Also, as a long shot, are you running more than one weather module using the same API key? I do.
                    motdog @Mykle1
                    @Mykle1 I have not changed the update interval Is that in the css? I only have the one module running. What seems weird is that it runs fine then all of the sudden spikes.
                      motdog @dazza120
                      @dazza120 I am running a Pi 3B the Pi doesn’t lock up. Occasionally if I try to do something a bit funky with a gif in the eye candy module it has but as soon as I use a different gif I am ok.
                        dazza120 @motdog
                        @motdog not overclocked? My Pi would still work just ment that it was working overtime doing the weather connection every second.
                        • 3 / 3
