    NOAA v3 using too many requests?
    28 Posts 4 Posters 14.9k Views 4 Watching
    • Mykle1M
      I don’t know. That is certainly possible and it would definitely account for issue in this topic. I use my key in both modules and as you can see I don’t have such a problem.
        motdog
        I’m not sharing a key as far as I know. My usage just skyrocketed which was surprising. I switched from dark sky to another provider & all is well. Tomorrow I’ll get a new key from darksky and see what happens. Just seemed weird to me
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @motdog
          @motdog
          Yeah, that’s a good idea. Let us know the result with the new key.
            motdog @Mykle1
            So the weather with weather underground hasn’t updated since yesterday. I looked at my stats and they were super high for yesterday. Seems the same as what happened before. Weird that random days trigger high requests.0_1552586737919_weather.PNG
            Any thoughts? I’m going to switch back to darksky api to see what happens.
            S Mykle1M 2 Replies Last reply
              sdetweil @motdog
              @motdog weather underground has been shutting down keys for over a year now. No new free keys are available. Time to switch to another weather solution.
                motdog @sdetweil
                @sdetweil Thanks for the heads up. Still curious about the spike in requests. Had that with darksky too which is why I switched to weather underground.
                D 1 Reply Last reply
                  dazza120 @motdog
                  @motdog I had the same! Have you got a raspberry Pi? And is it locking up? I had this on mine it just kept dailing every second it was mad! Took off my Overclock that I had on the Pi and it’s working V well at the mo.
                  • Mykle1M
                    @motdog
                    I’m just curious (and I may have missed this) but have you changed the updateInterval: 30 * 60 * 1000, This is designed to constrain the module to 48 calls per day. Also, as a long shot, are you running more than one weather module using the same API key? I do.
                      motdog @Mykle1
                      @Mykle1 I have not changed the update interval Is that in the css? I only have the one module running. What seems weird is that it runs fine then all of the sudden spikes.
                        motdog @dazza120
                        @dazza120 I am running a Pi 3B the Pi doesn’t lock up. Occasionally if I try to do something a bit funky with a gif in the eye candy module it has but as soon as I use a different gif I am ok.
                          dazza120 @motdog
                          @motdog not overclocked? My Pi would still work just ment that it was working overtime doing the weather connection every second.
                          • Mykle1M
                            @motdog said in NOAA v3 using too many requests?:
                            It is in the MMM-NOAA3.js file. Please verify the value. It can also be placed in the config entry which would override the module.js value.
                            Have you gotten a new API key?
                            Have your deleted you NOAA install and re-installed?
                            Have you tried NOAA by itself? No other modules running, or at most just the defaults of MM?
                              motdog @dazza120
                              @dazza120 no clue.
                                motdog @Mykle1
                                @Mykle1 I haven’t modified the js file. I did get a new key. One thing I changed at darksky was to limit the number of requests. The default had me at 1000. I lowered it to 750 so I shouldn’t hit the maximum. I’ll give it a few days to monitor. The number of requests stays low most of the time but occasionally spikes up
                                • Mykle1M
                                  Well, something is causing the module to fetch the data. I do not believe it’s the module itself based on your answers
                                    motdog @Mykle1
                                    @Mykle1 what should I look for? I had 475 requests today.
                                    • Mykle1M
                                      @motdog
                                      Are you absolutely sure that this is your setting in the config entry?
                                      Mykle1M M 2 Replies Last reply
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @Mykle1
                                        @motdog
                                        Post your NOAA config entry in a code block please. It should look like this.
                                                  disabled: false,
                                                  module: 'MMM-NOAA3',
                                                  position: 'top_right',
                                                      provider: "darksky",
                                                      apiKey: "YOUR API KEY",
                                                      airKey: "YOUR AIR KEY", // IF you want Air Quality Index
                                                      css: "NOAA4",
                                                      userlat: "40.123456",
                                                      userlon: "-74.123456",
                                                      updateInterval: 30 * 60 * 1000,  // VERY IMPORTANT!
                                          motdog @Mykle1
                                          @Mykle1 from the NOAA3.js
                                          Module.register("MMM-NOAA3", {
                                              defaults: {
                                                  animationSpeed: 0,
                                                  initialLoadDelay: 8000,
                                                  rotateInterval: 60 * 1000,
                                                  apiKey: "",
                                                  airKey: "",
                                                  pws: "",
                                                  css: "",
                                                  frow: true,
                                          		nupdate: false,
                                          		userlat: "",
                                          		userlon: "",
                                            motdog @Mykle1
                                            @Mykle1 from my main config
                                            		position: 'bottom_left',
                                            			    apiKey: "xxxx",
                                            			    airKey: "xxxx",
                                            		        css: "NOAA4",
                                            			userlat: "38.751389",
                                            		        userlon: "-90.565948"
