    NOAA v3 using too many requests?
    28 Posts 4 Posters 14.7k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @motdog
      @motdog
      Yeah, that’s a good idea. Let us know the result with the new key.
        motdog @Mykle1
        So the weather with weather underground hasn’t updated since yesterday. I looked at my stats and they were super high for yesterday. Seems the same as what happened before. Weird that random days trigger high requests.0_1552586737919_weather.PNG
        Any thoughts? I’m going to switch back to darksky api to see what happens.
        S Mykle1M 2 Replies Last reply Reply Quote 0
          sdetweil @motdog
          @motdog weather underground has been shutting down keys for over a year now. No new free keys are available. Time to switch to another weather solution.
            motdog @sdetweil
            @sdetweil Thanks for the heads up. Still curious about the spike in requests. Had that with darksky too which is why I switched to weather underground.
              dazza120 @motdog
              @motdog I had the same! Have you got a raspberry Pi? And is it locking up? I had this on mine it just kept dailing every second it was mad! Took off my Overclock that I had on the Pi and it’s working V well at the mo.
                @motdog
                I’m just curious (and I may have missed this) but have you changed the updateInterval: 30 * 60 * 1000, This is designed to constrain the module to 48 calls per day. Also, as a long shot, are you running more than one weather module using the same API key? I do.
                  motdog @Mykle1
                  @Mykle1 I have not changed the update interval Is that in the css? I only have the one module running. What seems weird is that it runs fine then all of the sudden spikes.
                    motdog @dazza120
                    @dazza120 I am running a Pi 3B the Pi doesn’t lock up. Occasionally if I try to do something a bit funky with a gif in the eye candy module it has but as soon as I use a different gif I am ok.
                      dazza120 @motdog
                      @motdog not overclocked? My Pi would still work just ment that it was working overtime doing the weather connection every second.
                        @motdog said in NOAA v3 using too many requests?:
                        It is in the MMM-NOAA3.js file. Please verify the value. It can also be placed in the config entry which would override the module.js value.
                        Have you gotten a new API key?
                        Have your deleted you NOAA install and re-installed?
                        Have you tried NOAA by itself? No other modules running, or at most just the defaults of MM?
                          motdog @dazza120
                          @dazza120 no clue.
                            motdog @Mykle1
                            @Mykle1 I haven’t modified the js file. I did get a new key. One thing I changed at darksky was to limit the number of requests. The default had me at 1000. I lowered it to 750 so I shouldn’t hit the maximum. I’ll give it a few days to monitor. The number of requests stays low most of the time but occasionally spikes up
                              Well, something is causing the module to fetch the data. I do not believe it’s the module itself based on your answers
                                motdog @Mykle1
                                @Mykle1 what should I look for? I had 475 requests today.
                                  @motdog
                                  Are you absolutely sure that this is your setting in the config entry?
                                  Mykle1M M 2 Replies Last reply Reply Quote 0
                                    Mykle1 Project Sponsor Module Developer @Mykle1
                                    @motdog
                                    Post your NOAA config entry in a code block please. It should look like this.
                                              disabled: false,
                                              module: 'MMM-NOAA3',
                                              position: 'top_right',
                                                  provider: "darksky",
                                                  apiKey: "YOUR API KEY",
                                                  airKey: "YOUR AIR KEY", // IF you want Air Quality Index
                                                  css: "NOAA4",
                                                  userlat: "40.123456",
                                                  userlon: "-74.123456",
                                                  updateInterval: 30 * 60 * 1000,  // VERY IMPORTANT!
                                      motdog @Mykle1
                                      @Mykle1 from the NOAA3.js
                                      Module.register("MMM-NOAA3", {
                                          defaults: {
                                              animationSpeed: 0,
                                              initialLoadDelay: 8000,
                                              rotateInterval: 60 * 1000,
                                              apiKey: "",
                                              airKey: "",
                                              pws: "",
                                              css: "",
                                              frow: true,
                                      		nupdate: false,
                                      		userlat: "",
                                      		userlon: "",
                                        motdog @Mykle1
                                        @Mykle1 from my main config
                                        		position: 'bottom_left',
                                        			    apiKey: "xxxx",
                                        			    airKey: "xxxx",
                                        		        css: "NOAA4",
                                        			userlat: "38.751389",
                                        		        userlon: "-90.565948"
                                          motdog @dazza120
                                          @dazza120 interesting, Im now up to 600 requests and it locked up.
                                            @motdog
                                            Yikes! I’m out of ideas other than to see if this behavior exists when NOAA3 is the only module running. I’m not suggesting that you re-install MM but that is what I would do. Good luck.
