    NOAA v3 using too many requests?
    28 Posts 4 Posters 14.9k Views 4 Watching
      motdog @Mykle1
      So the weather with weather underground hasn’t updated since yesterday. I looked at my stats and they were super high for yesterday. Seems the same as what happened before. Weird that random days trigger high requests.0_1552586737919_weather.PNG
      Any thoughts? I’m going to switch back to darksky api to see what happens.
      S Mykle1M 2 Replies Last reply
        sdetweil @motdog
        @motdog weather underground has been shutting down keys for over a year now. No new free keys are available. Time to switch to another weather solution.
        M 1 Reply Last reply
          motdog @sdetweil
          @sdetweil Thanks for the heads up. Still curious about the spike in requests. Had that with darksky too which is why I switched to weather underground.
          D 1 Reply Last reply
            dazza120 @motdog
            @motdog I had the same! Have you got a raspberry Pi? And is it locking up? I had this on mine it just kept dailing every second it was mad! Took off my Overclock that I had on the Pi and it’s working V well at the mo.
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @motdog
              @motdog
              I’m just curious (and I may have missed this) but have you changed the updateInterval: 30 * 60 * 1000, This is designed to constrain the module to 48 calls per day. Also, as a long shot, are you running more than one weather module using the same API key? I do.
                motdog @Mykle1
                @Mykle1 I have not changed the update interval Is that in the css? I only have the one module running. What seems weird is that it runs fine then all of the sudden spikes.
                Mykle1M 1 Reply Last reply
                  motdog @dazza120
                  @dazza120 I am running a Pi 3B the Pi doesn’t lock up. Occasionally if I try to do something a bit funky with a gif in the eye candy module it has but as soon as I use a different gif I am ok.
                    dazza120 @motdog
                    @motdog not overclocked? My Pi would still work just ment that it was working overtime doing the weather connection every second.
                    • Mykle1M
                      @motdog said in NOAA v3 using too many requests?:
                      It is in the MMM-NOAA3.js file. Please verify the value. It can also be placed in the config entry which would override the module.js value.
                      Have you gotten a new API key?
                      Have your deleted you NOAA install and re-installed?
                      Have you tried NOAA by itself? No other modules running, or at most just the defaults of MM?
                        motdog @dazza120
                        @dazza120 no clue.
                          motdog @Mykle1
                          @Mykle1 I haven’t modified the js file. I did get a new key. One thing I changed at darksky was to limit the number of requests. The default had me at 1000. I lowered it to 750 so I shouldn’t hit the maximum. I’ll give it a few days to monitor. The number of requests stays low most of the time but occasionally spikes up
                          • Mykle1M
                            Well, something is causing the module to fetch the data. I do not believe it’s the module itself based on your answers
                              motdog @Mykle1
                              @Mykle1 what should I look for? I had 475 requests today.
                              • Mykle1M
                                @motdog
                                Are you absolutely sure that this is your setting in the config entry?
                                Mykle1M M 2 Replies Last reply
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @Mykle1
                                  @motdog
                                  Post your NOAA config entry in a code block please. It should look like this.
                                            disabled: false,
                                            module: 'MMM-NOAA3',
                                            position: 'top_right',
                                                provider: "darksky",
                                                apiKey: "YOUR API KEY",
                                                airKey: "YOUR AIR KEY", // IF you want Air Quality Index
                                                css: "NOAA4",
                                                userlat: "40.123456",
                                                userlon: "-74.123456",
                                                updateInterval: 30 * 60 * 1000,  // VERY IMPORTANT!
                                    motdog @Mykle1
                                    @Mykle1 from the NOAA3.js
                                    Module.register("MMM-NOAA3", {
                                        defaults: {
                                            animationSpeed: 0,
                                            initialLoadDelay: 8000,
                                            rotateInterval: 60 * 1000,
                                            apiKey: "",
                                            airKey: "",
                                            pws: "",
                                            css: "",
                                            frow: true,
                                    		nupdate: false,
                                    		userlat: "",
                                    		userlon: "",
                                      motdog @Mykle1
                                      @Mykle1 from my main config
                                      		position: 'bottom_left',
                                      			    apiKey: "xxxx",
                                      			    airKey: "xxxx",
                                      		        css: "NOAA4",
                                      			userlat: "38.751389",
                                      		        userlon: "-90.565948"
                                        motdog @dazza120
                                        @dazza120 interesting, Im now up to 600 requests and it locked up.
                                        • Mykle1M
                                          @motdog
                                          Yikes! I’m out of ideas other than to see if this behavior exists when NOAA3 is the only module running. I’m not suggesting that you re-install MM but that is what I would do. Good luck.
                                            motdog @Mykle1
                                            @Mykle1 yeah its crazy. I don’t lock up often and I don’t know if it is a correlation. I may just try a different weather module to see if thats the solution
