    MMM-NetworkScanner
    10 Posts 3 Posters 1.9k Views 4 Watching
    • plainbrokeP Offline
      plainbroke
      Is there a way to have two columns side by side of output to the screen?
      I have more in the module being checked than will fit on the screen in one column.
      I have even made the font smaller so I could get the important ones to show.NetworkScanner.jpg
        plainbroke @sdetweil
        Thanks for looking I was afraid of that. I will put a request in for a hopeful change by the maker…
          sdetweil @plainbroke
          @plainbroke looking at the code, it creates a table w only 1 column.
          so someone would have to change the code
              @plainbroke last updated in 2019, so don’t hold your breath.
              learn js and html…
              make it configurable
              use list,
              divide by configured columns
              • xadamxkX Offline
                xadamxk
                Is anyone working on this? I can fork the project with the changes you requested - just let me know.
                plainbrokeP 2 Replies Last reply Reply Quote 0
                  plainbroke @xadamxk
                  @xadamxk
                  Please do fork and fix it for me
                    plainbroke @xadamxk
                    @xadamxk
                    You gonna fix this problem for me.? I have done a little research on it and it is way above my pay grade…
                    xadamxkX 1 Reply Last reply Reply Quote 0
                    • xadamxkX Offline
                      xadamxk @plainbroke
                      @plainbroke I was going to do it, but the module doesn’t use a template for the design. They do it all in javascript, so it wouldn’t be as easy as I was hoping.
                      The developer of this module hasn’t made updates for over 2 years, so you’d be better off trying this fork that has been updated to allow column layouts: https://github.com/spitzlbergerj/MMM-NetworkScanner
                        plainbroke @xadamxk
                        @xadamxk
                        Thank you for the information, I am still having issues with the list going off the screen. I am trying different areas on the screen to see if that makes a differance.
                          plainbroke
                          I finally figured out that I can use 2 instances of this module. Like so and they show up side by side on the screen allowing me to run 20 or so in this module.
                          module: “MMM-NetworkScanner”,
                          position: “top_left”,
                          header: “”,
                          devices: [
                          { ipAddress:
                          position: “top_right”,
                          header: “”,
                          devices: [
                          { ipAddress:
