    Magic Mirror with touchscreen Display/Monitor
    21 Posts 6 Posters 25.1k Views 7 Watching
      core
      Hello all,
      I am planning to build a new Magic Mirror, this time with touch function.
      As mirror glass I use a Pilkington Mirrorview, which according to the manufacturer is suitable for touch functions (capacitive).
      Now I have the question how to realize the touch function of the display behind it. I had already thought about using a PCAP touch foil, which is mounted between the Mirrorview and the LCD display. According to the manufacturer, this would work, but it is very expensive.
      A cheaper alternative would be a touch screen display that is as flat as possible.
      Important would be the size:
      My mirror measures 44 cm x 50 cm (width x height). I.e. the display must not be too large, 17.3" maximum 18.4".
      Can you recommend a suitable display that is as flat as possible and not too heavy? Would such a display be suitable, for example?
      https://www.amazon.de/-/en/Viewsonic-TD1655-Multitouch-Replacement-Silver-Black/dp/B08778F756
      Many greetings
      S SnilleS cowboysdudeC 3 Replies Last reply Reply Quote 0
        sdetweil @core
        @core use an ir touch frame over the glass.
        • SnilleS
          Snille Module Developer @core
          @core I also used a IR-Frame in my build. Works very well if you just want “simple” point and click and/or point and drag (even with two fingers)… I have not tested it with more advanced stuff. :) But for the MM it’s great. You can read about my build here and underneath the picture, you can find a link to a full photo album with pictures and text to all pictures about what you see. :)
            core
            thank you very much for your replies.
            An IR touch overlay is unfortunately not possible in my case. The mirror is frameless and clamped in 4 holders (2 above and 2 at the bottom). That’s why i am looking for a touch display which can be mounted under the glass.
            Best regards
              sdetweil @core
              @core said in Magic Mirror with touchscreen Display/Monitor:
              that doesn’t exist. the monitor is dependent on human skin resistance (try it with a glove on)
              the mirror glass would block that
                core @sdetweil
                Ok, but a PCAP Touchfoil under the glass, mounted between a LED display and the Mirroview, will work for sure (asked Pilkington and the company selling the foil).
                Best regards
                  sdetweil @core
                  @core but this is effectively the same as the ir frame… the special touchfoil does the work… NOT the monitor…
                  • cowboysdudeC
                    cowboysdude Module Developer @core
                    I have a 24" one that after I bought it found out that it will not work in Linux so my only option is to install MM on Windows … ugh. So when I can come across a NUC or something small I will until then …
                      BJK @Snille
                      @Snille Hi Snille
                      I have had greate use of xin.sh file to run at start. It contained the:
                      “DISPLAY=:0.0 xinput --set-prop “Multi touch Multi touch overlay device” “Coordinate Transformation Matrix” 0 1 0 -1 0 1 0 0 1”
                      However, now using the pm2 start xin.sh for automatic start, I get an error in the pm2 log
                      What do you use to correct the ir-frame ?
                      Best
                      Bo
                      S B SnilleS 4 Replies Last reply Reply Quote 0
                        sdetweil @BJK
                        @BJK what is the error?
                          BJK @BJK
                          Well, I start the xin.sh with PM2 and it works with calibrating the IR-frame:
                          xin.sh:
                          #!/bin/bash
                          DISPLAY=:0.0 xinput --set-prop “Multi touch Multi touch overlay device” “Coordinate Transformation Matrix” 0 -1 1 1 0 0 0 0 1
                          However, after the mm.sh (the MagicMirror) has started, then when I go back to Raspberry disktop the the Calibration is off again. If I then run the xin.sh with “pm2 start xin.sh” in a terminal window then the calibration is okay again.
                          This is the error that I get from pm2 log file:
                          Bo@MMpi:~ $ pm2 list
                          │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                          │ 0 │ xin │ fork │ 15 │ errored │ 0% │ 0b │
                          [PM2][WARN] Current process list is not synchronized with saved list. App led mm differs. Type ‘pm2 save’ to synchronize.
                          Bo@MMpi:~ $ pm2 log
                          /home/Bo/.pm2/pm2.log last 15 lines:
                          PM2 | 2022-03-31T20:11:38: PM2 log: App [xin:0] online
                          PM2 | 2022-03-31T20:11:38: PM2 log: App [xin:0] exited with code [0] via signal [SIGINT]
                          PM2 | 2022-03-31T20:11:38: PM2 log: App [xin:0] starting in -fork mode-
                          PM2 | 2022-03-31T20:11:38: PM2 log: Script /home/Bo/xin.sh had too many unstable restarts (16). Stopped. “errored”
                          /home/Bo/.pm2/logs/xin-out.log last 15 lines:
                          /home/Bo/.pm2/logs/xin-error.log last 15 lines:
                          0|xin | Invalid MIT-MAGIC-COOKIE-1 keyUnable to connect to X server
                          0|xin | Unable to connect to X server
                          0|xin | Invalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyUnable to connect to X server
                          Should I do something else with pm2 or run the xin.sh in an other way?
                          It would be so nice to have i done automatically :beaming_face_with_smiling_eyes:
                          Best Bo
                            BJK @BJK
                            xin.sh:
                            #!/bin/bash
                            Bo@MMpi:~ $ pm2 log
                            It would be so nice to have i done automatically 😁
                            the mm.sh file:
                            DISPLAY=:0 npm start
                            Best Bo
                            S B 2 Replies Last reply Reply Quote 0
                              sdetweil @BJK
                              @BJK first
                              do
                              pm2 save
                              to sync the disk list with the memory list of things pm2 manages
                              then do
                              pm2 info 0
                              to get the startup info from the task definition
                              we’re you running as root ( or using sudo ) when u did the pm2 start xin.sh?
                                BJK @BJK
                                @BJK
                                Regarding: “we’re you running as root ( or using sudo ) when u did the pm2 start xin.sh?”
                                I just wrote “pm2 start xin.sh”,and then “pm2 start mm.sh” and then at last “pm2 save”
                                Should I have used “sudo pm2 start xin.sh” ?
                                  sdetweil @BJK
                                  @BJK no… NEVER use sudo for anything unless you know WHY you are doing it…
                                  and you were logged on as user pi, right?
                                    BJK @BJK
                                    @BJK
                                    Well, instead of user pi, I am user Bo. So my home directory is like home/Bo/MagicMirror/modules…
                                    But any idea about the xin.sh error? Would it help to let pm2 just run the xin.sh once?
                                    Best
                                      sdetweil @BJK
                                      @BJK pm2’s JOB is to start and run stuff AND KEEP it running…
                                      so, if it ends. pm2 will start it back up…
                                      and if it errors too many times too fast it will stop restarting…
                                      • SnilleS
                                        Snille Module Developer @BJK
                                        @BJK I don’t start the xin.sh (with pm2). if you read in the xin.sh file you will find instructions how I did it… :) Here you can download the xin.sh.
                                        The script (if you don’t want to download it):
                                        #!/bin/bash
                                        # Before I just tested with the xinput command directly in the autostart file, but that did not work. So now instead I just created a script called xin.sh.
                                        # nano ~/xin.sh
                                        # Then added
                                        # DISPLAY=:0.0 xinput --set-prop "Multi touch Multi touch overlay device" "Coordinate Transformation Matrix" 0 1 0 -1 0 1 0 0 1
                                        # There should actually be 3 spaces between “Multi touch” and “Multi touch overlay device”. For some reason the board removes the extra spaces here.
                                        # You can actually find the “name” of the device with this commandDISPLAY=:0.0 xinput list
                                        # Shows something like this:
                                        # Virtual core pointer id=2 [master pointer (3)]
                                        #   Virtual core XTEST pointer id=4 [slave pointer (2)]
                                        #   Multi touch Multi touch overlay device id=6 [slave pointer (2)]
                                        # Virtual core keyboard id=3 [master keyboard (2)]
                                        # Virtual core XTEST keyboard id=5 [slave keyboard (3)]
                                        # Depending on what you have connected to your RPi. 🙂
                                        # So, after creating the xin.sh I added that to the autostart file for LXDE:
                                        # Like this:
                                        # nano ~/.config/lxsession/LXDE-pi/autostart
                                        # Added at the end of the file.
                                        # @/home/pi/xin.sh
                                        # Restarted and it works.
                                        You have to figure out your own “matrix” of course… :) Not sure if mine is the same…
                                          BJK @Snille
                                          @Snille
                                          Thank you! :beaming_face_with_smiling_eyes:
                                          Now, after your precise suggestions, I did read up on the autostart for Raspberry:
                                          https://forums.raspberrypi.com/viewtopic.php?t=313191
                                          https://forums.raspberrypi.com/viewtopic.php?f=66&t=294014
                                          and using:
                                          “sudo nano /etc/xdg/lxsession/LXDE-pi/autostart”
                                          I pasted my line at the end of the the autostart:
                                          @/home/pi/xin.sh
                                          and then saved the file
                                          In the xin.sh file, I have:
                                          line1: #!/bin/bash
                                          line 2: DISPLAY=:0.0 xinput --set-prop “Multi touch Multi touch overlay device” “Coordinate Transformation Matrix” 0 -1 1 1 0 0 0 0 1
                                          So, just two lines and "line1or2: " is not part of the file :smirking_face: (and - as you said - I do have a bit different coordinate compared to you)
                                          AND now it WORKS! Thank you !
                                          SnilleS S 2 Replies Last reply Reply Quote 0
                                          • SnilleS
                                            @BJK Great to hear!! :)
