    Magic Mirror with touchscreen Display/Monitor
    21 Posts 6 Posters 22.1k Views 7 Watching
      core @sdetweil
      Ok, but a PCAP Touchfoil under the glass, mounted between a LED display and the Mirroview, will work for sure (asked Pilkington and the company selling the foil).
      Best regards
        sdetweil @core
        @core but this is effectively the same as the ir frame… the special touchfoil does the work… NOT the monitor…
        • cowboysdudeC Offline
          cowboysdude Module Developer @core
          I have a 24" one that after I bought it found out that it will not work in Linux so my only option is to install MM on Windows … ugh. So when I can come across a NUC or something small I will until then …
            BJK @Snille
            @Snille Hi Snille
            I have had greate use of xin.sh file to run at start. It contained the:
            “DISPLAY=:0.0 xinput --set-prop “Multi touch Multi touch overlay device” “Coordinate Transformation Matrix” 0 1 0 -1 0 1 0 0 1”
            However, now using the pm2 start xin.sh for automatic start, I get an error in the pm2 log
            What do you use to correct the ir-frame ?
            Best
            Bo
            S B SnilleS 4 Replies Last reply Reply Quote 0
              sdetweil @BJK
              @BJK what is the error?
                BJK @BJK
                Well, I start the xin.sh with PM2 and it works with calibrating the IR-frame:
                xin.sh:
                #!/bin/bash
                DISPLAY=:0.0 xinput --set-prop “Multi touch Multi touch overlay device” “Coordinate Transformation Matrix” 0 -1 1 1 0 0 0 0 1
                However, after the mm.sh (the MagicMirror) has started, then when I go back to Raspberry disktop the the Calibration is off again. If I then run the xin.sh with “pm2 start xin.sh” in a terminal window then the calibration is okay again.
                This is the error that I get from pm2 log file:
                Bo@MMpi:~ $ pm2 list
                │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                │ 0 │ xin │ fork │ 15 │ errored │ 0% │ 0b │
                [PM2][WARN] Current process list is not synchronized with saved list. App led mm differs. Type ‘pm2 save’ to synchronize.
                Bo@MMpi:~ $ pm2 log
                /home/Bo/.pm2/pm2.log last 15 lines:
                PM2 | 2022-03-31T20:11:38: PM2 log: App [xin:0] online
                PM2 | 2022-03-31T20:11:38: PM2 log: App [xin:0] exited with code [0] via signal [SIGINT]
                PM2 | 2022-03-31T20:11:38: PM2 log: App [xin:0] starting in -fork mode-
                PM2 | 2022-03-31T20:11:38: PM2 log: Script /home/Bo/xin.sh had too many unstable restarts (16). Stopped. “errored”
                /home/Bo/.pm2/logs/xin-out.log last 15 lines:
                /home/Bo/.pm2/logs/xin-error.log last 15 lines:
                0|xin | Invalid MIT-MAGIC-COOKIE-1 keyUnable to connect to X server
                0|xin | Unable to connect to X server
                0|xin | Invalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyUnable to connect to X server
                Should I do something else with pm2 or run the xin.sh in an other way?
                It would be so nice to have i done automatically :beaming_face_with_smiling_eyes:
                Best Bo
                  BJK @BJK
                  xin.sh:
                  #!/bin/bash
                  Bo@MMpi:~ $ pm2 log
                  It would be so nice to have i done automatically 😁
                  the mm.sh file:
                  DISPLAY=:0 npm start
                  Best Bo
                  S B 2 Replies Last reply Reply Quote 0
                    sdetweil @BJK
                    @BJK first
                    do
                    pm2 save
                    to sync the disk list with the memory list of things pm2 manages
                    then do
                    pm2 info 0
                    to get the startup info from the task definition
                    we’re you running as root ( or using sudo ) when u did the pm2 start xin.sh?
                      BJK @BJK
                      @BJK
                      Regarding: “we’re you running as root ( or using sudo ) when u did the pm2 start xin.sh?”
                      I just wrote “pm2 start xin.sh”,and then “pm2 start mm.sh” and then at last “pm2 save”
                      Should I have used “sudo pm2 start xin.sh” ?
                        sdetweil @BJK
                        @BJK no… NEVER use sudo for anything unless you know WHY you are doing it…
                        and you were logged on as user pi, right?
