    Magic Mirror with touchscreen Display/Monitor
    21 Posts 6 Posters 25.1k Views 7 Watching
      sdetweil @core
      @core said in Magic Mirror with touchscreen Display/Monitor:
      That’s why i am looking for a touch display which can be mounted under the glass.
      that doesn’t exist. the monitor is dependent on human skin resistance (try it with a glove on)
      the mirror glass would block that
        core @sdetweil
        Ok, but a PCAP Touchfoil under the glass, mounted between a LED display and the Mirroview, will work for sure (asked Pilkington and the company selling the foil).
        Best regards
          sdetweil @core
          @core but this is effectively the same as the ir frame… the special touchfoil does the work… NOT the monitor…
          • cowboysdudeC
            cowboysdude Module Developer @core
            I have a 24" one that after I bought it found out that it will not work in Linux so my only option is to install MM on Windows … ugh. So when I can come across a NUC or something small I will until then …
              BJK @Snille
              @Snille Hi Snille
              I have had greate use of xin.sh file to run at start. It contained the:
              “DISPLAY=:0.0 xinput --set-prop “Multi touch Multi touch overlay device” “Coordinate Transformation Matrix” 0 1 0 -1 0 1 0 0 1”
              However, now using the pm2 start xin.sh for automatic start, I get an error in the pm2 log
              What do you use to correct the ir-frame ?
              Best
              Bo
              S B SnilleS 4 Replies Last reply Reply Quote 0
                sdetweil @BJK
                @BJK what is the error?
                  BJK @BJK
                  Well, I start the xin.sh with PM2 and it works with calibrating the IR-frame:
                  xin.sh:
                  #!/bin/bash
                  DISPLAY=:0.0 xinput --set-prop “Multi touch Multi touch overlay device” “Coordinate Transformation Matrix” 0 -1 1 1 0 0 0 0 1
                  However, after the mm.sh (the MagicMirror) has started, then when I go back to Raspberry disktop the the Calibration is off again. If I then run the xin.sh with “pm2 start xin.sh” in a terminal window then the calibration is okay again.
                  This is the error that I get from pm2 log file:
                  Bo@MMpi:~ $ pm2 list
                  │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                  │ 0 │ xin │ fork │ 15 │ errored │ 0% │ 0b │
                  [PM2][WARN] Current process list is not synchronized with saved list. App led mm differs. Type ‘pm2 save’ to synchronize.
                  Bo@MMpi:~ $ pm2 log
                  /home/Bo/.pm2/pm2.log last 15 lines:
                  PM2 | 2022-03-31T20:11:38: PM2 log: App [xin:0] online
                  PM2 | 2022-03-31T20:11:38: PM2 log: App [xin:0] exited with code [0] via signal [SIGINT]
                  PM2 | 2022-03-31T20:11:38: PM2 log: App [xin:0] starting in -fork mode-
                  PM2 | 2022-03-31T20:11:38: PM2 log: Script /home/Bo/xin.sh had too many unstable restarts (16). Stopped. “errored”
                  /home/Bo/.pm2/logs/xin-out.log last 15 lines:
                  /home/Bo/.pm2/logs/xin-error.log last 15 lines:
                  0|xin | Invalid MIT-MAGIC-COOKIE-1 keyUnable to connect to X server
                  0|xin | Unable to connect to X server
                  0|xin | Invalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyUnable to connect to X server
                  Should I do something else with pm2 or run the xin.sh in an other way?
                  It would be so nice to have i done automatically :beaming_face_with_smiling_eyes:
                  Best Bo
                    BJK @BJK
                    xin.sh:
                    #!/bin/bash
                    Bo@MMpi:~ $ pm2 log
                    It would be so nice to have i done automatically 😁
                    the mm.sh file:
                    DISPLAY=:0 npm start
                    Best Bo
                    S B 2 Replies Last reply Reply Quote 0
                      sdetweil @BJK
                      @BJK first
                      do
                      pm2 save
                      to sync the disk list with the memory list of things pm2 manages
                      then do
                      pm2 info 0
                      to get the startup info from the task definition
                      we’re you running as root ( or using sudo ) when u did the pm2 start xin.sh?
                        BJK @BJK
                        @BJK
                        Regarding: “we’re you running as root ( or using sudo ) when u did the pm2 start xin.sh?”
                        I just wrote “pm2 start xin.sh”,and then “pm2 start mm.sh” and then at last “pm2 save”
                        Should I have used “sudo pm2 start xin.sh” ?
                          sdetweil @BJK
                          @BJK no… NEVER use sudo for anything unless you know WHY you are doing it…
                          and you were logged on as user pi, right?
                            BJK @BJK
                            @BJK
                            Well, instead of user pi, I am user Bo. So my home directory is like home/Bo/MagicMirror/modules…
                            But any idea about the xin.sh error? Would it help to let pm2 just run the xin.sh once?
                            Best
                              sdetweil @BJK
                              @BJK pm2’s JOB is to start and run stuff AND KEEP it running…
                              so, if it ends. pm2 will start it back up…
                              and if it errors too many times too fast it will stop restarting…
                              • SnilleS
                                Snille Module Developer @BJK
                                @BJK I don’t start the xin.sh (with pm2). if you read in the xin.sh file you will find instructions how I did it… :) Here you can download the xin.sh.
                                The script (if you don’t want to download it):
                                #!/bin/bash
                                # Before I just tested with the xinput command directly in the autostart file, but that did not work. So now instead I just created a script called xin.sh.
                                # nano ~/xin.sh
                                # Then added
                                # DISPLAY=:0.0 xinput --set-prop "Multi touch Multi touch overlay device" "Coordinate Transformation Matrix" 0 1 0 -1 0 1 0 0 1
                                # There should actually be 3 spaces between “Multi touch” and “Multi touch overlay device”. For some reason the board removes the extra spaces here.
                                # You can actually find the “name” of the device with this commandDISPLAY=:0.0 xinput list
                                # Shows something like this:
                                # Virtual core pointer id=2 [master pointer (3)]
                                #   Virtual core XTEST pointer id=4 [slave pointer (2)]
                                #   Multi touch Multi touch overlay device id=6 [slave pointer (2)]
                                # Virtual core keyboard id=3 [master keyboard (2)]
                                # Virtual core XTEST keyboard id=5 [slave keyboard (3)]
                                # Depending on what you have connected to your RPi. 🙂
                                # So, after creating the xin.sh I added that to the autostart file for LXDE:
                                # Like this:
                                # nano ~/.config/lxsession/LXDE-pi/autostart
                                # Added at the end of the file.
                                # @/home/pi/xin.sh
                                # Restarted and it works.
                                You have to figure out your own “matrix” of course… :) Not sure if mine is the same…
                                  BJK @Snille
                                  @Snille
                                  Thank you! :beaming_face_with_smiling_eyes:
                                  Now, after your precise suggestions, I did read up on the autostart for Raspberry:
                                  https://forums.raspberrypi.com/viewtopic.php?t=313191
                                  https://forums.raspberrypi.com/viewtopic.php?f=66&t=294014
                                  and using:
                                  “sudo nano /etc/xdg/lxsession/LXDE-pi/autostart”
                                  I pasted my line at the end of the the autostart:
                                  @/home/pi/xin.sh
                                  and then saved the file
                                  In the xin.sh file, I have:
                                  line1: #!/bin/bash
                                  line 2: DISPLAY=:0.0 xinput --set-prop “Multi touch Multi touch overlay device” “Coordinate Transformation Matrix” 0 -1 1 1 0 0 0 0 1
                                  So, just two lines and "line1or2: " is not part of the file :smirking_face: (and - as you said - I do have a bit different coordinate compared to you)
                                  AND now it WORKS! Thank you !
                                  SnilleS S 2 Replies Last reply Reply Quote 0
                                  • SnilleS
                                    @BJK Great to hear!! :)
                                      sdetweil @BJK
                                      @BJK LXDE/autostart is running as root I think…
                                      pm2 autostart is NOT running as root, so u have to use sudo
