    Avoid "HDMI" splash screen on PIR control
    6 Posts 6 Posters 1.3k Views 6 Watching
      sdetweil @vongomben
      @vongomben did you mean when u turn off?
      this is the energystar compliance in the monitor that says “oh no!, input is turned off, I will power off soon”
      no way to work around this. except to turn the monitor off
      not many ways to do that
      V 1 Reply Last reply Reply Quote 1
      • cowboysdudeC Offline
        cowboysdude Module Developer @vongomben
        @vongomben Mine does it too. It flashes a couple times then goes off.
        @sdetweil is right… no way around that.
        • V Offline
          vongomben @sdetweil
          @sdetweil ok.
          I still have the remote from the board, will check if there is a standby function there.
          Will update you here.
          d
            there is no solution, other than to find a monitor that doesn’t do it.
            just about every display and tv shows some branding message during power on.
              this why my sleep/wake module hides all the modules instead of turning the display off.
              (and the fact that I can’t get it to turn off by software. but I can turn it on…)
