Avoid "HDMI" splash screen on PIR control
Re: PIR Sensor - Sleep LCD monitor
Hello.
I found this interesting topic on the forum, but couldn’t find a solution to the “HDMI” screen popping up whnever I turn on my Screeen device.I’m using the standart board to use old Laptop screens.
Any advices?
@vongomben did you mean when u turn off?
this is the energystar compliance in the monitor that says “oh no!, input is turned off, I will power off soon”
no way to work around this. except to turn the monitor off
not many ways to do that -
@vongomben Mine does it too. It flashes a couple times then goes off.
@sdetweil is right… no way around that.
@sdetweil ok.
I still have the remote from the board, will check if there is a standby function there.
Will update you here.d
there is no solution, other than to find a monitor that doesn’t do it.
just about every display and tv shows some branding message during power on.
this why my sleep/wake module hides all the modules instead of turning the display off.
(and the fact that I can’t get it to turn off by software. but I can turn it on…)
