    Home Assistant Module
    22 Posts 12 Posters 26.5k Views 18 Watching
      Sillec123
      it would be very cool if someone could build a Module for Home Assistant.
      • tidus5T Offline
        tidus5
        ohhhh yes!!!
        • O Offline
          onetwankyfive
          this could be really amazing
            robmarkcole
            Has anyone tried displaying the home-assistant front end in a browser window on the mirror?
              robmarkcole
              OK using the iFrame module (https://github.com/desertblade/iFrame) I got mirror to show the home-assistant demo page, so a little more work required to get something usable but a start.
              Cheers
              0_1483010955909_upload-65ef9cee-6e82-4886-b9ae-6fdf368131b0
              0_1483010883541_upload-ced3de75-80dd-48d9-9353-c590e3347bca
              • cowboysdudeC Offline
                cowboysdude Module Developer @robmarkcole
                @robmarkcole said in Home Assistant Module:
                Cheers
                I am not a programmer either but am very interested in this…
                  robmarkcole
                  Hi Cowboy, this post suggests a way forward https://home-assistant.io/blog/2016/04/07/static-website/ I think rather than display the whole HA panel on the mirror, I would display just some key info, such as who is home, house temperature etc. The novel part of the project is then to use Alexa to display information in the centre panel of the mirror, and have that panel dynamically update. It would show the alexa feed (in my case at http://alexa.amazon.co.uk/spa/index.html#cards) but I would add extra functionality to Alexa by integrating with Home-assistant. E.g. if the door-bell rang, I could ask Alexa ‘whos at the door’, and a feed to the front door camera would show in the panel. Any thoughts on this approach?
                    Well this is where most of these are heading… I like the idea!! NOT to mention that I’m waiting on parts to build a 32" mirror as a control center for my house…
                    Temps
                    Thermostat
                    door locks
                    etc…
                    • T Offline
                      tkoeberl
                      take a look @:
                      https://github.com/tkoeberl/MMM-homeassistant-sensors
                        danielgr
                        @tkoeberl Hi, looks awesome. Cant get mine to work though.
                        Did git clone https://github.com/tkoeberl/MMM-homeassistant-sensors.git in the modules folder. I can see a folder called MMM-homeassistant-sensors in the modules folder.
                        The config looks like this
                          module: 'MMM-homeassistant-feed',
                          position: 'top_left',
                            url: 'http://URL:8123/api/states?api_password=mypassword',
                            title: 'HA',
                            prettyName: 'true',
                            stripName: 'true',
                            values: ["sensor.olkyl_temperature"]
                        And it’s nothing there. Like the module is not there at all.
                        If i change
                        to
                            module: 'MMM-homeassistant-sensors',
                        I loads and i just get “Error fetching stats”.
                        Any idea what i might have done wrong?
                        • T Offline
                          tkoeberl @danielgr
                          @danielgr sorry, the first one was a mistake by me. Updated the readme accordingly.
                          About the “Error fetching stats”:
                          Just set a password for my API an it works like a charm. You have some special chars in your password?
                          If you point your browser to the url you can find the string?
                           "entity_id": "sensor.olkyl_temperature"
                            danielgr @tkoeberl
                            @tkoeberl
                            Wierd. Nope, just small letters and numbers. Yeah if i use the URL and go to http://URL:8123/api/states?api_password=mypassword i can see everything.
                            EDIT. Also, http://URL:8123/api/states/sensor.olkyl_temperature?api_password=password is working fine from my browser.
                            • T Offline
                              tkoeberl @danielgr
                              @danielgr https instead of http? Are you able to wget the page from your Mirror?
                                danielgr @tkoeberl
                                @tkoeberl Doh. DNS issues on the MM. Solved.
                                Thanks!
                                  MrEdOne @danielgr
                                  @danielgr
                                  Hi. I have same problem with “Error fetching stats”.
                                  Can you show your DNS config on MM?
                                  F D 2 Replies Last reply Reply Quote 0
                                  • G Offline
                                    goprojojo
                                    Is it possible to run Hassio on the same Magicmirror image? I just want to be able to run Hassio in the background.
                                    • F Offline
                                      FreddanB @MrEdOne
                                      @MrEdOne said in Home Assistant Module:
                                      @danielgr
                                      Me too.
                                        danielgr @MrEdOne
                                        @danielgr
                                        @FreddanB said in Home Assistant Module:
                                        @danielgr
                                        Me too.
                                        I had no DNS-server at all. Changed to my domain controllers IP who’s the DNS-server in my network and it worked. Can your MM resolve the address to your Home Assistant?
                                        • F Offline
                                          FreddanB
                                          I change from https to http and the problem solved for me. Thanks for a great module
                                            skippy_oz
                                            Hi, I have it working below is the code and a screenshot. It’s taking to an AM2302 Temp/Humidity Sensor connected to a NodeMCU running Tasmota and using MQTT to talk to HomeAssistant. See Dr Zzs video for the NodeMCU/D1mini setup.
                                            Dr Zzs Tasmota + D1mini (or Sonoff) - Temp & Humidity, ws2812 LEDs, and Motion Detection
                                              position: 'bottom_right',
                                                  		url: 'http://hassio:8123/api/states',
                                                  		prettyName : 'true',
                                                  		stripName: 'true',
                                                  		values: ["sensor.humidity", "sensor.temperature"]
                                            Regards
                                            skippy_oz
