    Home Assistant Module
    22 Posts 12 Posters 28.5k Views 18 Watching
    • T
      tkoeberl
      take a look @:
      https://github.com/tkoeberl/MMM-homeassistant-sensors
        danielgr
        @tkoeberl Hi, looks awesome. Cant get mine to work though.
        Did git clone https://github.com/tkoeberl/MMM-homeassistant-sensors.git in the modules folder. I can see a folder called MMM-homeassistant-sensors in the modules folder.
        The config looks like this
          module: 'MMM-homeassistant-feed',
          position: 'top_left',
            url: 'http://URL:8123/api/states?api_password=mypassword',
            title: 'HA',
            prettyName: 'true',
            stripName: 'true',
            values: ["sensor.olkyl_temperature"]
        And it’s nothing there. Like the module is not there at all.
        If i change
        to
            module: 'MMM-homeassistant-sensors',
        I loads and i just get “Error fetching stats”.
        Any idea what i might have done wrong?
        T 1 Reply Last reply
        • T
          tkoeberl @danielgr
          @danielgr sorry, the first one was a mistake by me. Updated the readme accordingly.
          About the “Error fetching stats”:
          Just set a password for my API an it works like a charm. You have some special chars in your password?
          If you point your browser to the url you can find the string?
           "entity_id": "sensor.olkyl_temperature"
          D 1 Reply Last reply
            danielgr @tkoeberl
            @tkoeberl
            Wierd. Nope, just small letters and numbers. Yeah if i use the URL and go to http://URL:8123/api/states?api_password=mypassword i can see everything.
            EDIT. Also, http://URL:8123/api/states/sensor.olkyl_temperature?api_password=password is working fine from my browser.
            • T
              tkoeberl @danielgr
              @danielgr https instead of http? Are you able to wget the page from your Mirror?
                danielgr @tkoeberl
                @tkoeberl Doh. DNS issues on the MM. Solved.
                Thanks!
                M 1 Reply Last reply
                  MrEdOne @danielgr
                  @danielgr
                  Hi. I have same problem with “Error fetching stats”.
                  Can you show your DNS config on MM?
                  F D 2 Replies Last reply
                  • G
                    goprojojo
                    Is it possible to run Hassio on the same Magicmirror image? I just want to be able to run Hassio in the background.
                    • F
                      FreddanB @MrEdOne
                      @MrEdOne said in Home Assistant Module:
                      @danielgr
                      Me too.
                        danielgr @MrEdOne
                        @danielgr
                        @FreddanB said in Home Assistant Module:
                        @danielgr
                        Me too.
                        I had no DNS-server at all. Changed to my domain controllers IP who’s the DNS-server in my network and it worked. Can your MM resolve the address to your Home Assistant?
                        • F
                          FreddanB
                          I change from https to http and the problem solved for me. Thanks for a great module
                            skippy_oz
                            Hi, I have it working below is the code and a screenshot. It’s taking to an AM2302 Temp/Humidity Sensor connected to a NodeMCU running Tasmota and using MQTT to talk to HomeAssistant. See Dr Zzs video for the NodeMCU/D1mini setup.
                            Dr Zzs Tasmota + D1mini (or Sonoff) - Temp & Humidity, ws2812 LEDs, and Motion Detection
                              position: 'bottom_right',
                                  		url: 'http://hassio:8123/api/states',
                                  		prettyName : 'true',
                                  		stripName: 'true',
                                  		values: ["sensor.humidity", "sensor.temperature"]
                            Regards
                            skippy_oz
                            A 1 Reply Last reply
                            • A
                              Aaron19953 @skippy_oz
                              Any chance this will work with https ?
                              I’m receive the same error “Error fetching stats”
                              I can see the attributes if I browse to
                              https://IP:8123/api/states/sensor.name?api_password=PASSWORD
                                skippy_oz
                                I have it working with HTTPS :grinning_face:
                                Change the url to match what you have for HA
                                          url: 'https://username.duckdns.org:8123/api/states',
                                          stripName: 'true',
                                You will need to modify the node_help.js file for this module change the below line of code /MagicMirror/modules/MMM-homeassistant-sensors/node_helper.js
                                request({ url: url, method: 'GET' }, function (error, response, body) {
                                To the following and change the api-password to what you have set in HA it’s about line 12.
                                  request({ url: url, headers: {'x-ha-access': 'api-password'}, method: 'GET' }, function (error, response, body) {
                                It’s working it looks like it takes a bit longer to get the data as I think the atentication takes some time.
                                Regards
                                skippy_oz
