    Completely lost
    15 Posts 6 Posters 4.9k Views 6 Watching
      sdetweil @notacomputerguy
      @notacomputerguy read the two topics in my signature below. I didn’t write them but they will help get you started…
      some modules have trouble cause things change so much
      see
      there is a lot to learn
        @notacomputerguy the latest release also removes the old current and forecast modules and replaced them w one that takes a new parameter to choose how u want to see the data
        so no video of stuff that came out April 1st…
          you could copy the sample config again to get back to install time config
            best experience says work on one module at a time.
            when stuck ask for help, resolve and move on to next.
            • N Offline
              notacomputerguy @sdetweil
              @sdetweil I was kind of hoping this would be a one and done thing. It seems like things become obsolete really quick. I don’t plan on making this a full on hobby, I just wanted a magic mirror that would work for the next few years maintenance free… Maybe this isnt for me.
              S cowboysdudeC 2 Replies Last reply Reply Quote 0
                @notacomputerguy you might get lucky, but I wouldn’t count on it.
                we all loved weather modules, but now every provider demands registration and money for things we used to get for free…
                and they kill the old apis, sometimes w no notice.
                apple bought darsky
                ibm bought weather underground
                none of those work free anymore
                keeping things going for customers is no longer the thing.
                modules here were created by someone with a need, and willingness to share their stuff…many authors have moved on since then, and their stuff becomes brittle with all the changes around them…
                maintenance was one thing, constant rev rewrites are a killer.
                • cowboysdudeC Offline
                  cowboysdude Module Developer @notacomputerguy
                  @notacomputerguy I would look for the lastest weather module that still uses an api key and try that. :) Even the one I wrote is obsolete… as many providers as there were they are no more so that, as Sams says, breaks things.
                  The ONLY reason I have free weather api is because I have a weather station so 2 services provide me with keys as long as I provide them with data…
                  The state of how things are… ugh… it’s weather for God’s sake … but data is $$ to companies… the little guy be damned.
                  If that’s what’s holding you up skip the weather for now and start with stock modules and build up :) We’re here to help… it doesn’t have to be a full time job!
                    sdetweil @cowboysdude
                    @cowboysdude i picked on weather as an example of changing times, not specifically what the OP was struggling with
                    • ankonaskiff17A Offline
                      ankonaskiff17 @notacomputerguy
                      @notacomputerguy I use weather.gov for both current and forecast per module @sdetweil mentions.
                      I wrote a marginal explainer over a year ago about how to use weather.gov as provider.
                      You have to do some pre-work on some pages in National Weather Service website to copy over to the config file weather module section.
                      I didn’t start messing the MM’s too far back and it is one of those type projects that you have an ah-ha lightbulb go off in your head where you feel like you’ve been fighting with MM and then it all comes together as a unified whole.
                      Hard part is persevering through and not quitting.
                        cowboysdude Module Developer @ankonaskiff17
                        @ankonaskiff17 I agree!!! Once you get it, you get it but that can take a bit to understand.
                        I’m hoping things are getting easier for you!
                        My suggestion is this.
                        Once you have the mirror running and working make a copy of your config.js file that way if you add something and it breaks the mirror you have your backup that you know works.
                        Problems persist as they always will. Make backups :)
                        Once you have a running mirror with all the modules you want/need then backup the entire thing and you’ll always have a fresh copy already setup in case you need it :)
                        I’ve been here almost from the beginning so setting this up and getting things running is just a matter of how long it takes the pi to move so I can get it done LOL.
                        My mirror is setup up with quite a few of my own modules running that I’ve built for my use.
                        Weather module
                        [with hourly and daily forecast]
                        My version of Holiday module
                        I’m using someone else’s PIR module [Name cannot mention he gets mad]
                        Sams config module
                        My own clock module
                        Background module
                        Sniles HA module [to get sensors from Home Assistant on my mirror]
                        That’s about it.
                        bugsounetB 1 Reply Last reply Reply Quote 1
